Results 1 to 28 of 28
    Mar 01 2011
    NM
    Going BT! This should spool, yea?
    Found a great deal on this turbo. The serial tag on it says T51r SPL. A little teaser pic:
    Senior Member Four Rings witwer4444's Avatar
    Dec 13 2008
    01 Nogaro S4
    Around
    never seen an HKS on a 2.0 or any Audi for that matter. Good luck!
    Senior Member Four Rings EMAXX's Avatar
    Jul 12 2008
    You need to clean your engine bay.
    What is this turbo really going in?
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    Going for the no-hood-look, huh?
    05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
    Dyno proven 221 whp/302 wtq!
    Driving Style: Strategic Aggressor
    Eric Paul Young: "I just tore down my old boy and slapped the internals."
    Senior Member Two Rings pierranchis's Avatar
    Nov 18 2009
    2007 A4 FWD 6sp, 02 R6
    Pompano Beach FL
    If "LagIsForePlay" as your name states, then call your car "BlueBalls" because that's all she'll give you with that turbo...
    APR 93|Greddy FMIC|Carbonio|AWE hpfp|Pulley|TP|SB stg 3 clutch|Ecode 11lbs flywheel|Koni Coils|Hardwired V1|B&B Exhaust|RS4 Sway bar
    Active Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    ^BAZINGAH!!!!!!
    Scott
    I don't even have an audi....i just love me some 'zine
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Active Member Two Rings RAudiB7A4's Avatar
    Nov 08 2010
    Rochester/MN/Mid West
    ^Hahahaha! That thing is fuckin huge! Built motor? Cuz if not, I'm with these^ guys. Forplay is about it...
    APR Stage II (Stock, 91, 93, and 100 octane) - APR Carbonio CAI - APR Test Pipe - APR Down Pipe - 034 Motorsports Turbo Inlet Hose - Apikol Snub Mount - Debadged - Paint Matched Side Markers - DTM Bumper - DTM CF Lip - RS4 Grill - RS4 Rear Sway Bar - Custom RS4 HID Fogs - OEM "D" DV - New South Performance Boost Gauge - Podi Gauge Pod - Vogtland Sport Suspension - 19x8.5"F & 19x9.5"R Avant Garde M310's - Hankook Ventus V12's - CC'd Bi-Xenons - CF Rear Valiance
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T
    NC
    Countdown until full spool in 30..........29.........28........27.......26...... .......
    vizi
    05.5 B7 A4 6sp AWD Quartz Gray 173,000mi I like to drive!
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20,Wossner Pistons 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, Eurojet VC, EJ S3 Dv Flange, Custom STASIS Exhaust, Precision 600hp FMIC, RS4 injectors, Tial 38mm, APR HPFP, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mount, DO 4 port w/m direct injection, HPFPUpgrade 142bar fuel relief valve
    Absolute Automotive Tuned to 373+awhp (Corrected)
    Mar 26 2007
    Colorado
    the motor will need to rev to 8500 RPMS for that turbo to even have a chance
    A Fully Catless JHM tuned S4.....
    Active Member Three Rings A42007's Avatar
    Jan 12 2011
    07 A4, 1989 Jeep Cherokee
    Phoenix, AZ
    Haha, well that got brutally honest real fast....
    My Build Thread - http://www.audizine.com/forum/showth...di-07-A4-Build.
    2007 B7 A4 - APR Stage II / Magna Flow Cat Back / 2.5" TP / ST Coilovers / 19x8.5 ET 32 RS6 Reps / Aftermarket Navigation / 235/35 Hankook Ventus V12 Evo's.
    Active Member Three Rings Ed Gein's Avatar
    Sep 21 2011
    is nonexistant
    Location, Location!
    Beautiful turbo though
    2008 Ocean Blue A4, Turbo, AWD
    REVO stage 2|2.5" test pipe|B8 DV|K&N drop in|NewSouth boost gauge
    Active Member Four Rings CorneliusRox's Avatar
    Jul 19 2011
    Warrenville, Chicago, IL
    I say grab a K0R and pair them up, otherwise, I doubt you'll spool this unless you are pushing more fuel than anyone on this forum.
    2008 A4 6MT, Quattro, VAST Stage1 Tune, Cupra R Lip, VAGCOMed, Hawk Pads, RNS-E, 10f/15r Spacers, Eyelids, Black Vinyl, RevD DV, JOM C/O's - 24.75" FTG, 255/35-18 Ventus V12's, 80000miles+
    359awhp/K03-GT
    Thumper - 97 12V Cummins
    Lady Killer - 03 600rr
    Senior Member Four Rings viperdsa's Avatar
    Aug 28 2007
    '06 Dolphin Gray A4 2.0T
    west of the equator
    hope there is a 2jz swap planned to go along with that turbo lol
    2006 Dolphin Gray A4 2.0T Quattro
    Sep 21 2011
    is nonexistant
    Location, Location!
    This should be in the general section unless he's joking...
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    Haha, I wish this guy the best of luck. Beautiful turbo, but your going to have to be pretty innovative if your going to make that setup work.
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Senior Member Two Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    If rediculous post is serious, you're gonna need a serious motor, and maybe a pre-turbo to help spool that big ass one. I think a twin turbo, built 2.0 would be sick. Definitely smoething different. Fueling and tuning will be a bitch though.
    Edit: I'm thinking you could almost let the K03 spool that thing.
    Silver 05 2.0t B7 APR stage 2+ w/ RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Palmetto State Defense
    YouTube PSD
    http://www.jamesfirearm.com
    Senior Member Four Rings Operator's Avatar
    Feb 06 2009
    Audi A4, Mit. Montero, Escort
    Wellington, CO/Cheyenne, WY
    Quote Originally Posted by viperdsa View Post
    Troof!
    K0R-GT Maestro tuned
    Info:
    Build
    History
    Senior Member Two Rings GAIC Husky's Avatar
    Nov 24 2009
    NW Chicago
    Isn't the OP's weekend car a Supra?
    Revo Stage II - 034 HFC - RS4 RSB - 35% tint
    Mar 01 2011
    NM
    Alright guys, I am getting a little scared now with everyone saying that it wont spool. I bought it because it said it was a .57 trim turbo and I thought that it was a decent size turbo. Here are the specs: http://www.hksusa.com/products/?id=817. I got manifold back from the powdercoaters. I will update my progress tonight.
    Active Member Three Rings Jay-Bee's Avatar
    Feb 25 2011
    North Alberta
    If you got a good deal on it hell yeah you're gonna flip it for a bonus, it's a mid 3grand turbo new.
    The trim means nothing it's got a 1.00 A/R.
    But have a look at some compressor maps, over lay this one with some turbos that are regular around here, you'll see why.
    -Jon
    2007 A4 Avant 2.0TQM
    Jul 08 2010
    tucson
    danbury
    you realize that the turbo itself is almost the entire size of your valve cover right?
    its a bummer that your bought a turbo that really does not have a practical application for this 4 cylinder car, well... allow me to rephrase that, its a bummer that you bought a turbo that would require a lot of monies in order to make it work, but you do have some options
    you could sell the turbo for more monies then you paid for it and use those funds to try and get something a little bit more practical like a gt30 or something
    Scott
    Feb 06 2009
    Quote Originally Posted by GAIC Husky View Post
    Yes. http://www.audizine.com/forum/showth...-A4?highlight=
    Also, OP you have a CVT, you sure you want to add all the power that turbo can provide.
    Still not sure if serious
    Info:
    Build
    History
    Nov 24 2009
    NW Chicago
    I really doubt he is going to put this on his A4, even if he got the turbo for a steal price. I have a feeling this guy is not a noob on turbos and this is going on the Supra.
    Mar 01 2011
    NM
    Awww you guys caught on too quickly... Yes this is not going on the A4. Here it is on the supra, testing fit and making new intercooler pipes.
    Senior Member Three Rings QUATTROA4B7's Avatar
    Oct 26 2009
    New Jersey
    ^^ That is awesome What kind of numbers you shooting for??
    -B7 Ricer
    Show: FK grill/ Fly's custom dectanes/ HIDs/ LED tails/ Colormatched reflectors/ Black fog plastics/ 15% tint/Sunstrip/ Debadged/ S4 valance/ 19x8.5 + 19x9.5 Riviera S
    Go: Carbonio/ TP/ AWE quad tips (silver)/ APR Stg II+ (100 Oct)/ APR HPFP/ Forge switchable DV/ VAST w/m injection/ Bilstein PSS9s/ ARII over-slot rotors/ Hawk HPS pads
    -"if you were anywhere near a teenage age you would understand that my hair is fucking sick, so go fuck yourself."
    Aug 28 2007
    west of the equator
    Having looked around, Titan motorsports sells a kit with that turbo and says its proven to 1000hp. Looking forward to see the results
    Sep 21 2011
    is nonexistant
    Location, Location!
    Where is sprode in all of this...
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    purtty turbo
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Mar 01 2011
    NM
    Looking for 600+ on pump and 800+ on race gas. And once we get another E85 station I will be switching to corn. 1000 wheel is pretty hard on this setup without supporting mods. I am still on a stock long block minus cams and valve train.
    Updates: New oil lines are on, new cooling lines plumbed, and I took off a oil cooler system that I really did not need.
