OEM rubber turbo inlet boots do the job OK on a stock application, but are prone to problems once boost is turned up and performance increased.
Due to the lack of reinforcement, it's common to see the stock hose collapse under vacuum created by the turbo's suction. The OEM rubber hose is also a common area to see cracks and leaks with age, which can throw off MAF readings.
Since the 034 hose is not corrugated, and maintains a larger inside diameter than the stock hose, it flows much smoother and flows more air than the OEM hose, and its a direct fit to boot.
2007 Audi A4 S-Line Ti - JoM, Carbonio, Ecodes, RS4 Black Optic Grille, Tint, whole bunch of APR stuff, Forge, and AWE stuff, Devils Own Methanol Injection, just your run of the mill B7 that's been "tinkered" with
I understand that the silicon doesn't collapse like rubber, but is there some numbers or video to prove that it's 75$ of added performance?
And at what stage i will start to see an advantage?
Drive It Like You Stole It! 2006 A4 Avant 2.0t FSI 6spd silver/blk
Unitronic stage 1+, black Recaro, RS4 swaybar, 18" A8 wheels, Koni Yellow + eibach (not installed yet). K&N drop in, APR snub mount, latest DV revision with Forge spacer, sirius retrofit, CIM vent boost gauge, RNS-E and oem BT retrofit, B8 style led headlights with xenarc HID ..
will this also fit with the carbonio airbox/filter?
Yes, this will work with the Carbonio airbox.
Originally Posted by DrZEUS
same deal free shipping to Canada?
Use coupon code intship2012 for international, it will give 40% off the normal rate.
I don't have any dyno numbers, but it is the same old concept that has been proven as the 1.8T hoses. http://forgemotorsport.com/content.a...duct=FMGOLFIND, dyno sheets toward the bottom showed a 12whp gain. Granted the MK4 1.8T hose is larger, but even half that for $75 is worth it IMO.
I've been rockin' this for a while now, it's a superior product to the OEM rubber piece. Put the performance formula aside and just look at it as a quality upgrade for a piece of mind. The instal is easy and the price vs value is spot on, just my $0.02.
What size is the TIP at the turbo end? I need it to fit my TD05-18g which had an OD of 57mm I believe...
Is it the same as the one on the 034 site for $195
