Results 1 to 11 of 11
    Active Member Two Rings NewB7's Avatar
    Nov 15 2011
    Bay Area, Ca
    Car Ramps Anyone?
    Anyone have 2 car ramps I can borrow or even better a car lift lol? Trying to swap in a stock cat. I've heard it can be a pita to replace a cat if you don't have plenty of space under the car. Thanks in advance.
    De-badged Ibis S-line Quattro 6MT, APR Stage II, 034 HFC, Carbonio CAI, Apikol Snub, 034 CC, STaSIS exhaust, Zimmerman cross drilled rotors/Hawk HPS
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    drive to sac and i will let you use my lift
    Senior Member Four Rings 97B518TQM's Avatar
    May 31 2009
    02 S4 Tial605'd
    Bay Area, CA. USA
    If you are talking about regular ramps you buy from Kragen or Walmart that won't give you much space at all, especially if you are lowered. Whenever I need more space I jack up my car as high as possible with my floor jack until my jack stands are on the highest position. That usually gives me enough room to work on everything I need to reach to pull the engine,.. at least it worked for me the last 3 times I pulled my engine.
    574HP 02 S4 6sp - Tial 605 snails with meth; 2.5" Custom Inlets; AWE SMICs; EVOMS DVs; KW V3 Coilovers; 3" DPs with Magnaflow HFC; Dual 2.5" Catback Exhaust (First quad exhaust in the US); 18" Oettinger RZs; AWE DTS; Front 350mm Cayenne 6 piston kit & Rear 321mm Cayenne 4 piston Kit; Custom-fitted RNS-E; H&R Sways; etc.
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    ^Same as above. Getting the front of the car up on the highest setting on the stands allowed enough room to get the cat out on my B7.
    2005|A4 3.0 Quattro UltraSport
    2006|A4 Avant 2.0T Quattro S-line
    Nov 15 2011
    Bay Area, Ca
    Quote Originally Posted by infinkc View Post
    Thanks for the offer, but too far of a drive for me.
    Nov 15 2011
    Bay Area, Ca
    Quote Originally Posted by 97B518TQM View Post
    Looks like I need to upgrade my floor jack then.
    May 31 2009
    02 S4 Tial605'd
    Bay Area, CA. USA
    Get one that has at least 20" lift, most only raise the car to 15" or so.
    Nov 15 2011
    Bay Area, Ca
    Thanks for the heads up.
    Nov 15 2011
    Bay Area, Ca
    What jacking points do you guys use besides the ones directly under the doors? Is there somewhere I can safely lift on the frame/subframe?
    Aug 03 2007
    03' A4 1.8t - Denim Blue
    NorCal
    If you're looking to get a set of ramps, take a good look at these:
    http://www.ragepowersports.com/?s=1066
    They work great for low clearance cars like ours.
    Nov 15 2011
    Bay Area, Ca
    Quote Originally Posted by veloracer View Post
    Thanks, but I was able to borrow my coworkers heavy duty floor jack. Got the parts swapped out in no time. It's soo much slower now. Going to look into an HFC+Stasis kit next!
