Results 1 to 16 of 16
    Active Member Two Rings noorcali's Avatar
    Nov 20 2010
    vallejo
    please help no more options.... b5 a4 wont start
    Hey everyone, i need some major help with my audi.
    B5 a4, 2.8L 12V.
    It doesn't start!!!
    It's not the starter cus i can hear the crank, the battery is fine.
    I replaced the following:
    1)Coil Pack
    2)Fuel Filter
    3)Ignition conrol Module
    4)Fuel Pump Relay
    5)Fuel Pump
    6)Computer
    7)spark plugs NGK Platinum
    8)Mass Air Flow
    Any ideas of what the problem might be?
    Please i need as much help as i can get
    Active Member Two Rings philds01's Avatar
    Nov 08 2011
    1998 audi a4 1.8t
    indianapolis indiana
    sometimes man its the simplest problems i wasn't getting any pressure in the car and sometimes the levels change its hard to figure out try your best to troubleshoot id be willing to help
    Feb 26 2010
    NOVA
    thats a lot of parts.
    well do you hear the fuel pump priming when you open the door?
    can you feel fuel pumping through the fuel rail when you try and start the car?
    with the spark plug wire out of the car and with the spark plug in it, can you try and start the car and see a spark?
    are all the fuses intact?
    do you have access to vagcom? run through the output tests.
    how are your grounds in the car?
    when did the car last run?
    Senior Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by noorcali View Post
    B5 a4, 2.8L 12V.
    It doesn't start!!!
    1)Coil Pack
    2)Fuel Filter
    4)Fuel Pump Relay
    5)Fuel Pump
    6)Computer
    8)Mass Air Flow
    You missed the most important and simpliest part, the battery. I understand you said you tested it and its fine, however, battery testers can have a lot of false positives etc that I'd try a new battery or have the current one tested on a couple of testers to make sure its fine.
    1999 Audi A4 1.8TQM AVANT (Current)
    CXracing FMIC | APR Ecu | Podi Gauge Setup | eBay SS kit | DieselGeek Skid Plate | ST Coilovers [slammed at 23" gtf]
    Soon to be installed: FT Kit | 440cc Green Top | GIAC 440cc File | CM FX300
    1997 Audi A4 1.8TQM (SOLD) | 2001 Audi A4 1.8TQM (SOLD)
    Active Member Three Rings SS92's Avatar
    Jul 11 2011
    Charlotte, NC
    If you replaced the fuel pump, make sure you didnt hook it up backwards. I've read several threads where people did just that.
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > Stockpiling for BAT
    Active Member Two Rings -:vw:-'s Avatar
    Jun 25 2010
    1998 GTi Vr6
    Algonquin, IL
    I bet its fine just flooded to shit. Try cranking the shit out of it with the pedal to floor. This will disable the injectors and help blow the excess of fuel out.
    His:
    1998 GTi-Vr6 Tornado Red - Turbo'd (too much to list).
    1999 A4 Avant 1.8T Melange Beige - APR Stg I, Godspeed FMIC, Forge Split-R Valve, N75 "J" (Race) Valve, 3" Test Pipe, 17" Sport Wheels, OEM Sport Suspension, 034 Adjustable FPR.
    Hers:
    2008 Jetta I5 Campenella White
    Oct 06 2004
    Minnesota
    Check all your engine grounds.
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    Oct 20 2010
    Bridgewater, MA
    fuel, spark, air.
    One is missing.....
    Start with the easiest and check for spark and then compression and fuel.
    It makes no sense to throw parts at it if you can't even isolate in what area the problem is.
    Registered Member Two Rings
    Oct 16 2011
    Columbus, ohio
    were you able to fix it and if so; please to let us know what was the cause; I replaced the engine in my A6 and running into the same issue.... thanks
    Nov 20 2010
    vallejo
    Okay guys, so the battery is fine... I just checked.
    I don't think it would be a fuel pump problem cus I had installed properly. I checke the coils and they are not getting any spark. It's not the coils, spark plugs, or wires because I replaced all off those. So I think it might be the can shaft sensor since that's where the coils get their power from.
    Feb 26 2010
    NOVA
    did you vag com the car?
    Nov 20 2010
    vallejo
    not yet
    May 30 2011
    Massachusetts
    Check fuses.
    Active Member Two Rings hazard860's Avatar
    Aug 22 2011
    1984 gti
    Lebanon, CT
    Fuses x2^
    also not sure if its possible but could the tb alignment go so far off when the battery dies that it wont run at all?
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    For the pump, my black wire was posotive and the brown wire was ground. Had me baffled for like an entire day, till I discovered that. If your wiring is correct, I would not be surprised if you goofed on your ignition coil wires when doing your spark plugs. My mechanic had a fully custom Coupe Quattro inline 5 BAT, and the guys brought it to his shop because they could not get the thing to start for weeks after a whole bunch of custom work done to it. Took my mechanic like 5 min to start her up. They simply placed the ignition wires on improperly.
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Oct 30 2009
    '99.5 A4 2.8QM
    Toronto, ON
    Really? You're trying to diagnose a no start issue and you haven't even scanned it? That's the very first thing you should do before throwing parts at it.
