Page 1 of 3 123 LastLast
Results 1 to 40 of 101
    Senior Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    time to get crazy
    ok guys its time to park the b5....
    LONG term project will be starting within the next two months. the project will be as follows:
    Pulling interior completely again (fix a few parts of suede)
    pulling all the glass out of the car
    pulling engine again
    move battery to trunk
    move abs module where battery goes
    move power steering tank to behind secondary firewall
    re-rout A/C lines
    Re rout fuel Lines
    Remove pcv and evap
    complete bay shave and wire tuck
    s4 front bumper with rs4 mod
    s4 side skirts with shaved lower door moldings
    shaved side marker light
    fix 2 dents
    shaved exhaust cut out on rear bumper and painted lower valance
    complete respray same color (melange metallic) door jams, trunk, engine bay, EVERYTHING.
    matte black painted roof and mirrors
    refinish Flik Artics (if i keep them) matte black with color matched lip
    Slam her on her ass again
    3 inch custom exhaust
    roll cage while keeping full interior still (color matched to car) then looking for another 1.8T AEB to throw in while i rebuild mine on the side Its finally time and at my new job it will be much easier to accomplish this
    Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
    its only just begun...
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    roll cage?
    why?
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Because race car
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 10 2009
    Denver CO
    I work at a shop that builds custom roll cages, mandrel bent exhausts and custom headers... Why not its dirt cheap and will look mean as f*** and If its coming apart again, I'm doing it!
    Jun 10 2009
    Denver CO
    Quote Originally Posted by biketsai View Post
    Because race car
    Spot on Haha who knows after the engine build I may need it ;)
    Senior Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 1.8TQM 00 A6 Widebody
    Lombard, IL
    Because Jordan crashes.
    Brilliant Black B5 ..... 15k on Street Built Engine
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
    Will work on Audi/VW in Chicagoland
    Jun 10 2009
    Denver CO
    Quote Originally Posted by NeedingAnAudi View Post
    even better reason
    Active Member Three Rings crazexr7's Avatar
    Sep 10 2011
    1998 A4 2.8 Quattro, 1968 Cougar Xr7
    Bristol, CT
    Awesome plans.
    Jun 10 2009
    Denver CO
    so..... i know i said within the next couple months but i got the famous oil pressure light today. im F***ing done haha im tired of burning oil and problem after problem. engine is coming out today f it.
    Jun 10 2009
    Denver CO
    Turns out the plug came loose from the sending unit, so no tearing apart yet Haha need the 2.8 in my garage back together and then ill be parking mine for a long time. Hoping to have it ready for wuste but can't make any promises Haha
    Oct 13 2010
    colorado
    get to it... i wanna see it when its done...
    Jun 23 2010
    Athens, PA
    Can't wait
    Complete '98 A4 1.8TQM PART OUT
    Stock 16" Wheels w/ BRAND NEW tires
    Goodyear Eagle LS2 Grand-Touring 17" tires- NEED GONE!
    PM ME!
    Jun 10 2009
    Denver CO
    shouldnt be long before i get started. i just set the engine and trans back into the 2.8 in my garage and just gotta finish that project up and sell it so i have my garage back and some more money in my pocket. then ill pull my 1.8t in the garage and pull the engine, trans, interior, all the glass. first project will be welding up holes in the bay and building sheet metal sides like rob did as well as welding up side marker lights and holes from where lower door moldings use to attach. this friday i am picking up a set of s4 side skirts and a new rear bumper, so those will be in the mix here soon as well. once i get the bumper, ill be starting to shave the exhaust cut out on the rear valance for the 3rd time. this time it will not be going on until my exhaust is done. im still on the hunt for an s4 front bumper so thats going to be the only hold up as of now. i need some advice on how to make some new A/C lines that run in the fender well. I plan on purchasing some ss fuel lines that i will re rout in the same method rob did. as well as using robs method of running the wiring harness behind the pre firewall and cutting a hole over the bell housing to run all of my wiring out of sight. PCV and evap will be deleted, although i need to leave some sort of access to re attach them when it comes time for emissions. the power steering tank will also be moved and a bracket built to hold it behind the pre firewall. i do plan on keeping my windshield washer tank as this will still be a daily driver but i will find a clean method to hide it.
    Oct 13 2010
    colorado
    euro scrap yard on 470 and santa fe may have an s4 bumper. last i was there (some time ago) he always had some b5 bumpers stored.
    Jun 10 2009
    Denver CO
    Quote Originally Posted by SomeDayAS4 View Post
    good to know! I work at sante fe and c470, where is this place?
    Jun 10 2009
    Denver CO
    Got some work done today. Pulled my passanger seat as well as headliner and all the pillars. Gonna slowly work on it and still drive it till the 2.8 is back together and out of my garage
    Jun 10 2009
    Denver CO
    id say today was pretty successful!:thumbup: engine will stay in currently while i figure out the wire tuck and re routing everything
    Jun 10 2009
    Denver CO
    i love it when shes naked
    Senior Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Facelift 1.8t
    Tampa
    Quote Originally Posted by ThatA4T View Post
    Weight savings bro….
    Jun 10 2009
    Denver CO
    Quote Originally Posted by the_pirate View Post
    haha wish i could leave it this way haha its only goona be heavier when im done. dynamating the entire car, caging it, and full interior back in
    Sep 10 2011
    Bristol, CT
    that's a nice seat haha. And jealous of your plans to dynamat it. I want to do my car some day
    Jun 10 2009
    Denver CO
    Since every single thing is out, I almost feel like I have to Haha ill really enjoy not having tons of road noise and drowning exhaust sounds when I build my exhaust.
    Mar 16 2009
    Lombard, IL
    I need an exhaust.
    Alex
    Jun 10 2009
    Denver CO
    Me too hopefully soon!
    Senior Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    that sunroof is pretty heavy you should think about getting a carbon fiber replacement ... put all that weight down low yo
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Jun 10 2009
    Denver CO
    Quote Originally Posted by discontained View Post
    Thought about it... I just use it way too much :/ can't decide
    Jul 09 2007
    '01 A4 1.8t
    GA
    $395 for 27lbs... USE THE WINDOWS :P
    Jun 10 2009
    Denver CO
    I know I know Haha I should sell my sunroof to help fund the build.
    Jul 09 2007
    '01 A4 1.8t
    GA
    are you going to run a Slim-Fan pulley fan delete?
    Jun 10 2009
    Denver CO
    Yes sir mechanical fan will be replaced with electric. Already have the smaller belt but need a fan.
    Mar 16 2009
    Lombard, IL
    Alex Patented DOUBLE OEM fans.
    Alex
    Jun 10 2009
    Denver CO
    Mar 16 2009
    Lombard, IL
    Gunna pull the engine ever year around the same time now??
    Alex
    Jun 10 2009
    Denver CO
    Well its tradition now Haha I guess I have to. This is a lot more than pulling an engine Haha I hope I can get it back together :p its amazing how audi can fit all those parts in one car but I can't fit them in a 2 car garage Haha
    Active Member Three Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    ^Lol aint it the truth
    2001 A4 1.8TQM. Custom turbo back (eBay test pipe, LaBree downpipe, 2.5 inch piping back to a MagnaFlow muffler). Stage 1 tune. K&N Cone filter. RS6 Wheels painted dark gray with Continental DWS tires. ST Coilovers. Coming soon...2.0 coil packs.
    For sale...Brand new, never used, still in box Bosch rear o2 sensor.
    Jun 10 2009
    Denver CO
    Senior Member Four Rings flynnr's Avatar
    Sep 22 2008
    1969 chevelle SS 454 convertible
    Minnesnowta (Roch)
    damn, do work son.
    will you post up info on the shorter belt?
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Jun 10 2009
    Denver CO
    Just left my house ill snag a part number tomorrow.
    Jun 10 2009
    Denver CO
    forgot to grab that part number on the belt. ill check tonight when i get home. ill sell it to u if u want since im going vr. but as of now i have a few questions on vr6 swap. for those of you who have done the swap and kept power steering and A/C i need details. ive seen pictures but i need info. here is a pic i found from this thread http://forums.vwvortex.com/showthrea...B5-Information
    What is that motor mount bracket off from on the drivers side that attaches to the stock motor mount, holds the A/C compressor, alternator, and power steering pump? is that the stock 1.8 bracket? If so, any details on how its modified to fit the vr? or link to this persons build thread would be great.
    By the way, ill be buying the adapter plate for the stock trans soon so that i can mock up the engine and trans in place and begin to fab up some motor mount brackets to utilize my existing 034 street density mounts. i dont have an engine i can use in the car yet, but my bro has a spare vr6 laying around (that he wont give me) but hell let me borrow it to mock up for mounts.
    Jun 10 2009
    Denver CO
    new placement of ps tank and abs module. need to make some brackets still
    dirty ass garage before i cleaned it today
    she got some sun today
    raised and slammed
    she runs! still need a throttle cable (2.8) if anyone has one. and fill trans
    just for fun. teachers car
