Originally Posted by
Poopie
you got a nice set up. what alt/bracket set up is that? did you remove the viscous clutch fan?
That isn't mine. Its a 06A block w/ AEB head. Its just an example of what can be made. I still run the stock AEB manifold on my 058 block/ AEB head. I ported the opening and made an adaptor plate for a v6 tb.
Poopie
did you see a noticeable gain? once my car is running well enough for me to start tweaking things i think i will go that route and add a large throttle body. what did you go with?
The whole idea of adding volume to the intake manifold is to create a larger reservoir for charged/compressed air (potential energy). Thus it is waiting behind the valves to enter the cylinder rather than as a flow that has to enter the intake through the TB, distribute in the plenum, down the runner, and into the cylinder (all kinectic). This is the scenario prior to the turbocharger producing position pressure. Or more air flow through the compressor than what you flow through the engine.
You may know this already.
