Results 1 to 40 of 50
    Aug 10 2011
    murrieta california
    no start issue after timing belt job?
    Whats up guys my names andrew, I did a timing belt job on my a4, well timing belt, new radiator, water pump, thermostat, serp belt, ect... and when i put everything back together last night, i have a no start issue, today i figured out that im getting no spark, not sure what to do now or where to look... i am pretty sure i didnt touch anything igniton related, are there any particular wires or sensors on the front of the car i could have missed to cause a no spark? im so confused... its a 96 2.8
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    Maybe left the ICM unplugged?
    2001 Laser Red A4 1.8TQM, APR 93, 710N, electronic oil pressure gauge, B6 Sport 17's, OEM Sport Shocks, H&R Sport Springs, My 5-Speed Swap
    Need to borrow a Cam Chain Tensioner Tool? Just pay shipping ($4 total). PM me.
    "If i had a manual for my commuting, i would literally...LITERALLY...kill myself in the face. Kill myself dead... right in the face." -toaster
    Oct 06 2004
    Minnesota
    Might sound dumb, but did you disconnect your battery and forget to re-connect it?
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    Aug 10 2011
    murrieta california
    at this point feel free to ask all the dumb questions you want as long as it hasn't been asked yet haha, but no battery is def plugged in, also its holding a charge of 10v when cranking so i know my battery is good, and my icm is def plugged in as well, im also getting voltage to my coils, all fuses are good, no related codes, SO CONFUSED AND STUCK :( please someone lol its been down for almost a month
    Senior Member Three Rings prizmatik's Avatar
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Do you have the camshaft sensors plugged in?
    Aug 10 2011
    murrieta california
    Quote Originally Posted by prizmatik View Post
    yes i also checked voltage on all 3 pins and all were to spec
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Dammit, I'm rackin' my brain with visualizations trying to figure out what may of happen.
    Perhaps the timing is off....
    Everything could have the correct voltage....
    but if the timing is off.....
    Aug 10 2011
    murrieta california
    i also checked vacuum with a vacuum gauge while turning the motor over, it is also to spec which is a small amount of vacuum, cant make vacuum w/o compression.
    im getting no spark, for some god forsaken reason D:
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Quote Originally Posted by Quattromang337 View Post
    Oops, I forgot you stated no spark what so ever. I have a spare 2.8 engine from a 1996 A4 laying in my garage. I will check it out tomorrow to see if I can see anything obvious.
    Aug 10 2011
    murrieta california
    I also was under the impression that Audi's are very good about throwing codes when timing is off, not sure though, correct me if im wrong, also that they are zero clearance motors so if i did manage to f up my timing during the timing belt job, my valves would have been bent days ago.
    Aug 10 2011
    murrieta california
    thanks man i appreciate it!!! the guys on vortex aren't so knowledgeable with drive-ability issues (with the exception of a hand full of people, which most are on here), so i didn't get much help from them haha, my cars been sitting for 3 weeks.
    Feb 26 2010
    NOVA
    how are you determining no spark? you could pull all the coilpacks and put a spark plug in it....ground it then remove the fuel pump relay and unplug the injectors. crank the engine and see if the sparkplugs spark...when the all work, check fuel pump fuses and relays
    Aug 10 2011
    murrieta california
    Quote Originally Posted by guy022077 View Post
    wait wait, so taking just taking a coil out putting a spark plug on it and ground it out alone wont cause spark? because that's what i was doing to determine spark, basically hooking a spark plug up out of the cylinder (with all 6 plugs still in) and cranking it when it was grounded.
    Aug 10 2011
    murrieta california
    also all fuses are good, where is fuel pump relay?
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    I checked the spare engine I have sitting on the floor, but couldnt find anything that would cause this issue.
    Feb 26 2010
    NOVA
    it will, the rest was so youre not shooting fuel into the cyl for nothing.
    Active Member Three Rings ianwpb's Avatar
    Dec 11 2010
    West Palm Beach, Fl
    Take a few pictures of the engine bay and post them up.. Maybe we can spot something amiss.
    1999.5 2.8m
    Active Member Two Rings Nollywood's Avatar
    Nov 03 2011
    2001 Audi S8, 2008 BMW 120d M-Sport
    Aso Rock!
    Possibly a crank sensor issue.
    Are you getting fuel? As in can you hear the pump priming when you release the key? If not, then it's possible by sheer coincidence your crank sensor died when you did your timing belt job. Dead crank sensor won't allow spark or fuel.
    If you're 100% sure you're not getting a spark, try spraying some gas into the intake, and getting someone to crank the motor. If it tries to run on the sprayed fuel, then at least you've narrowed down where to look. A can of bug spray would also work for this test. I'm not too keen on easy start, though I guess a little won't do any harm.
    2001 Audi S8 Quattro 4,2 V8 40V (AVP) - Daily.
    1996 Audi A4 Quattro 4,2 V8 32V (AHC) - S8-Powered DTM Race Car Build In Progress.
    2008 BMW 120d (N47) 5-Door M-Sport
    Dec 11 2010
    West Palm Beach, Fl
    On the Ignition coil there are 4 bolts that secure it in. The Front passenger side one should have a little ground type wire. Is that connected? Could that cause a no spark issue?
    1999.5 2.8m
    Aug 10 2011
    murrieta california
    Quote Originally Posted by ianwpb View Post
    i dont see one, but i also never have... are you sure this is true for the 96? ill take a picture
    Aug 10 2011
    murrieta california
    small green connector on the bottom isn't connected to anything, would that cause a no spark? couldn't find another end and don't ever remember disconnecting it, so I don't believe this is the issue.
    Active Member Four Rings bman005's Avatar
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    That doesn't look timed right. Did you use the cam lock bar when you did the belt?
    05.5 B7 under construction finally
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Cant see it in the picture, but a small green connector on the bottom will be for the A/C compressor.
    Jun 30 2008
    Erie, Pennsylvania
    WHOA there cowboy. The belt timing is *way* off in that picture.
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    I figured he cranked the engine numerous times, how can you guys tell?
    Is it because the cam gears arent aligned right?
    They never mis-align at all during rotation?
    Jun 30 2008
    Erie, Pennsylvania
    Correct. The cam sprockets have the exact same diameter and tooth count. The belt length is constant. Therefore, the cam gears will always rotate together, at the same speed. This is the entire purpose of the timing belt: to keep everything rotating together in perfect time.
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Dammit, sometimes I can feel really stupid.
    Quattromang337, it may be too late, but I have the timing tool you can borrow, and I am located just north of you. Also, if needed, I have a spare 1996 2.8 engine for sale.
    Aug 10 2011
    murrieta california
    how in the fuck could i have messed up the timing? i know for an absolute fact that they didn't move, does it happen when you turn it over? fuccckkk I have done this job 3 times! well this is my first time on the 2.8... also wouldn't i hear my valves hitting my piston? especially considering i have my air box disconnected so i can hear inside the engine alot better.
    Dec 11 2010
    West Palm Beach, Fl
    Both times I've done my TB I accidently turned the cam gear too much as I was trying to fit the belt. As I gave the wrench a little too much force it moved the cam gear about 70* left or right, dependent obviously on which way I was turning it. It seems like you may have had the same thing happen, but instead of correcting it you just put the belt on anyway?
    That picture looks extremely similar to what happened to me. It looks like it was moved too far to the left, so I would take the belt off and reposition that cam to the right about 70* so that the big holes are both towards the center. Find something long and flat enough to almost work as a cam lock bar, but instead use it to line up the big holes.
    Who knows, maybe once you realign it it'll start back up?
    Even though this is a 30v it should look like this
    1999.5 2.8m
    Jun 30 2008
    Erie, Pennsylvania
    A successful t-belt job does not rely on the cams "not moving". That's just asking for problems. Sidenote: I personally find all those emergency mid-tbelt-job threads absolutely hysterical (OMG, the cam gear *moved*! HALP!! What do I do?!)
    If you are attempting to do these audi V6 t-belts without the cam lock bar (which I've done many times), you must (must, must) *MARK THE BELT* to the sprockets before removal, transfer said marks to the new belt with accuracy, and simply install the new belt as the old one was. The cams can move all they want while you aren't looking, and there is still no way to mess it up. Additionally, you should also make a second set of reference marks, which mark the sprockets to the head/engine block. This is just to double check that everything ends up in the same position, relative to the engine, when you are all done. If you look at ianwpb's photo above, it is apparent that all of these steps were taken. Very nicely done.
    Aug 10 2011
    murrieta california
    yupppppppp lesson learned right there... damn i hope my valves arent bent. everyone pray for me.
    Active Member Two Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Don't leave home with out it
    99.5 1.8TQM > 034 Ic Standalone / CompT4-5562 / Built Head / Built Block
    My Build http://www.audizine.com/forum/showth...-8-build-Enjoy
    AKA: Pete3071
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    I got his back, I will be going to his place to help him out.
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    Good luck but if he cranked it...its probably a paperweight
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Maybe, but you never know. Fortunately, I have a spare engine compatible with his car I would be willing to sell.
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    Hopefully you'll give him a good deal
    Dec 15 2009
    2001 A4 1.8TQM
    Ontario, California
    Quote Originally Posted by bman005 View Post
    I'll hook him up, cause he's an Audizine member....
    And, if he has an Audizine license plate frame or sticker(s) on his car, an extra discount..
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    Nice
    Aug 10 2011
    murrieta california
    prizmatik is my hero thanks so much man, huge life saver
    Aug 10 2011
    murrieta california
    AND he sold me some face lift taillights for hella cheap (not in picture)
