Results 1 to 3 of 3
    Senior Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    Edmonton, AB
    Post Hubs & Brakes Swap Complete!!
    So, now that I'm rolling I figured I'd provide a retrospective of the work required to perform this swap.
    Cliff Notes precede an illustrated walk-through of the headaches (read: time wasters ) encountered along the way.
    Front:
    ==> Porsche BoxsterS calipers (Brembo 4 piston), pins filed down 1mm each as per 90quattrocoupe's DIY
    ==> 034/Apikol RS2 caliper bracket, + 3mm spacer machined to fit
    ==> S/S lines (custom made locally, Edmonton Brake & Clutch... highly recommended)
    == Euro A/S8 rotors (323x30mm), spun down inside to clear control arm, and 3mm spacer machined to fit behind rotor on hub
    ==> UrS4 hubs with new bearings, machined to fit (5mm off the radial axial shoulder)
    ==> H&R 5mm hub spacer to fit 235/45-17 rubber (225 max without spacer) up front
    ==> Installed front upper strut mounts... while I'm in there...
    Rear:
    ==> B5A4q rear hubs, with new bearings
    ==> New lower ball joints, while I'm in there...
    ==> B5S4 rear rotors/pads, calipers & caliper brackets... e-brake cable bracket reamed to fit
    ==> S/S lines (custom made locally, Edmonton Brake & Clutch)... existing were 2" too short
    If I would have used the entire B6 rear hubs and brakes assembly with new bearings I would have been okay.
    B6 rear caliper & bracket:
    Some machining is required on the inside shoulder of the rear B6 hub but it would have been cheapest overall. (Because I had them sitting there.) Since I didn't know if they'd match up or not I went the online DIY route.
    However, I misinterpreted what I read and encountered a few surprises.
    First, a lower rear ball joint boot was torn and required replacement.
    Next, I thought that I could just re-drill the rear rotors to fit B6A4 rear calipers/brackets. Or even use the B6 rotors too.
    No. :( The hat-offset (=B5) was all wrong.
    So.
    My friend Mike sourced a set of B5S4 rotors and pads for just $40 from a local with a monster 3L S4.
    Lots more heat-sinking meat on these rotors...
    B5S4 rear (left) vs. B6A4 front (right):
    ECS wanted $180/bracket, $270/caliper + shipping & duty. Shokan wanted $180/caliper+bracket with a $35 core-charge. FTL.
    So I phoned/surfed local at euro-wreckers ($75, but only one caliper), and eurodrivers.ca to no avail... then genuineaudiparts, audifans, and AZ, Motorgeek, and finally the object of last resort... vwvortex classifieds. Where I promptly found a set for $100 plus shipping, and another for $180-shipped. I used the former deal for leverage on the latter. Expedited international shipping at $80, for a cost of $180 delivered. Deal.
    Of course... drama ensues and long story short I waited two weeks before asking WTF? He says 'no money, no calipers.' So I send a PayPal confirmation number, his excuse is he forgot to check his 'other' email. The brakes arrived in a week and change.
    Upon fit up, there are a couple issues. The e-brake cable bracket needs to be notched to allow for the thicker diameter OEM Cq cable.
    And the OEM brake lines are too short. There are a couple options to deal: 1) bend & re-mount the OEM hard lines to maybe gain enough slack & re-use the OEM rubber lines, or 2) disassemble at the OEM hard line and have custom braided s/s lines made about 2.5" longer.
    Custom lines it is.
    Meanwhile, as hangups would occur in the rear, the fronts were in full flight themselves.
    Clearance, clearance, clearance! That's the number one issue up front.
    The Apikol/034 machined RS2 caliper bracket (which is a very nice piece) needs a shim to clear the gap between the upright and caliper. They're made for Big Reds, 996TT calipers, not 993TT... and certainly not 996C4S/BoxsterS calipers. At this point I'm going to suggest that if you're going to do this mod, it's cheapest and easiest overall to have your machinist make this bracket for you out of steel (or aluminum should you be feeling spendy). You'll be bringing in a few parts for machine work anyways. Including the caliper bracket, for shims. Unless you cheap out and opt for stacking washers, which is cheap.
    Of course, the hubs themselves need machining to fit. I opted to use UrS4 hubs. To eliminate any confusion I supplied the original Cq hubs and told him to make the new ones fit the same. Worked like a charm.
    Among the parts needing machining at the same time is the euro A/S8 323x30mm rotors. They'll need to have a couple mm's turned off the inside to clear the control arm. Next, a couple mm spacer in-between the hub and rotor is necessary to line up inside the caliper.
    During all this time under the car, I did notice it looks pretty fresh underneath. <3
    Since the strut housing is essentially hanging, this was an ideal time to finally fix the existing ones which are beyond worn out. Fragments come out, 034 Street Density upper strut mounts go in.
    And then, the other thing (which I half expected) was my 235/45-R17 winter tyres *just* rub the control arm. Half expected because the max size I typically read of people installing is 225s... so that's not exactly a blindside. Luckily, the 5mm wheel spacers cleared enough... but I think I'll send them rearward and get 10mm up front to keep everything flush looking.
    She does look pretty good to my eyes, even for all the road grime on the wheels.
    1990 Coupe quattro /// Project
    Euro :: RS2 :: 034 :: ARP :: K&N :: Stebro :: Koni :: Brembo :: Dunlop
    Buy my B6 A4 parts: for sale thread here
    Veteran Member Three Rings jbrentd's Avatar
    Oct 31 2005
    '01 A4 Avant, '91 CQ, '08 FX35, '95 YJ
    Tulsa, OK
    Nice write-up. Someday, I might get to this mod. Glad I found some 4 lug wheel to buy me some time though.
    Registered Member One Ring OzDasher's Avatar
    Jan 29 2012
    79 B1, 79 Mk1 (both dailies), 59 Beetle, 2 more Mk1s, 02 Bora 4mo.
    Melbourne, Australia
    Lovely work! Sounds like you had a few headaches along the way but what a great result!
    VWDasher.com - B1 fans!
