Results 1 to 3 of 3
    Aug 23 2011
    Allentown,P.A
    Starting question. Delayed
    3 Days ago my Car Died in the middle of the Road on the way to work. It would crank but no Go. So I was stuck in a bad spot and I ended up calling AAA. I knew it was the Fuel pump but I did not have time to replace it so I had it towed to a local mechanic. After 1 Day they confirmed that it was the Fuel pump so I told them to go ahead and replace it. After $600.. Ouchhhhhhh The Car Starts and I drove home again. Normaly I change my own parts but this was one of hose situations.
    However, Now after 2 Days when I let the Car Sit in the cold for a couple of hours, It takes the Car 4 to 6 Cranks before it gets going. They changed the Fuel Filter and Fuel Pump and I have no Codes. So, has anyone any suggestions on what could be the cause of this Delayed start. It is almost like it takes a while for Pressure to built. I don't have a Gauge and I don't know where to check the fuel pressure on this. I don't think it is my battery either.
    Any suggestions, I would appriciate it. I don't want to take the car back to the mechanic yet.
    Active Member Two Rings MadAudi's Avatar
    Jan 20 2011
    Bicycle
    Downers Grove IL
    Do you hear it prime for a second when you turn the key?
    It sounds like your coolant temp sensor is starting to go bad and flooding the engine a bit. It wont throw a code, but that's where I would start.
    -Adam (Formally Koselowiec)
    1995 Audi S6 Plus
    ASE Master Certified
    Subaru Certified Specialist
    European Service Tech
    *VAG-COM Equipped* PM For Audi/VW Repair and Diagnostics!
    *BMW CarSoft Equipped* PM for BMW Repair and Diagnostics!
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    98.5 1.8TQM Sport
    Columbia, SC
    try a new fuel pressure regulator. that is where the check valve is located that keeps line pressure in the rail to assist in quick starting.
    most guys who've upgraded have a stock one lying around.
    http://img380.imageshack.us/img380/7320/sigswhf6.gif
    Parting out 99 A4. PM me for info
    Mika GTRS 440cc file FS
    Low mileage AEB head FS
    Evil Black Rifle Owner
