It is not required to use VCDS to retract the brake. you can do the samething by buying a Disc-Brake Caliper Wind Back tool. Here is the one i have.
http://www.amazon.com/gp/product/B00...ms_ohs_product
Just release the parking brake, jack up the car, remove the wheel. Remove the two bolts holding the caliper on. Then wiggle the caliper free, remove the old brake pads, install the new ones, then use the tool.
You need to put on the correct adapter (one for our car is medium circle with the single bar coming out, you will see it in the kit if its the one from amazon), then attach it to the tool, and start to wind back the caliper. It will take a little while and it will sometimes not go at all. Just take the tool off and reposition the adapter and turn some more. You will start to notice after checking if it fits back over the new pads, that it is getting more clearance. Keep this up until it is fully retracted. And again, it may feel as if its not going back any, but I assure you it is, just keep spinning, and if it gets stuck, take off adapter and reposition and keep on spinning. If after you reposition the adapter and it doesnt spin anymore, check fitment and it will slide right on.
Repeate for the other side.
You may need to open the lid for the brake reservoir to let any air out before you do this though, i have done it just from experience though. And replace it when your done changing the pads.
Also when you have your back brake pads on both rear tires, get in the car and pull the ebrake. It will make the noise and will take longer than usual for it to fully engage. (about 3 times longer). Once you see it is engaged, disengage it. I like to engage/disengage it a couple more times.
Front pads are easy, just watch those clips, they are dangerous and pop off at a high rate of speed which once it hits skin it equals blood blister. (from experience)
