Results 1 to 39 of 39
    Active Member Two Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    To B8 S4 owners: How many KM's do you get on a tank of gas?
    I just came from a B5 S4 in my current B7 and am getting used to visiting the gas station more often.
    Curious on how many KM's are B8 S4 owners getting on a tank of gas? City/Hwy?
    The B7 and B8 have almost the same tank size (63 and 64L respectively).
    Thx
    2007 S4 Avant MT - RNS-E - BBS RE/Bridgestone RE11 - GIAC - Stoptech ST60 - KW V3 - Milltek Non Res - RS4 Rear Sway - JHM SS - 6000k mains and fogs - Dension 100 - JL Audio Amp - Image Dynamics IDQ10
    Veteran Member Four Rings BryanR's Avatar
    Sep 08 2004
    1974 Audi Fox
    Ottawa
    Normally if you're at the pump filling up, and can see the next gas station down the road with the naked eye...
    (at least, that's what I've heard )
    Active Member Four Rings tomh009's Avatar
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    475 km on my last fill-up, about 50-50 city-highway. How about your B7?
    2012 S4 · 6MT · Glacier White/Black Nappa · sport diff · navigation · black optics
    Mar 12 2010
    Quote Originally Posted by tomh009 View Post
    Last tank the low gas warning came on at 330kms and I took it to 390 to the last line on the gas guage. 50/50 as well.
    Jun 12 2011
    I'm getting about 440, sometimes a bit less, 50/50. I'm usually on the highway, but I have to drive past 404/DVP everyday...
    Best tank ever - 520, all highway.
    Worst tank ever - 390.
    Not seeing much disparity between different gas stations, although I haven't really been keeping track too closely.
    2012 S4 6MT | Sepang Blue | Titanium | Sport Diff
    Apr 07 2006
    Burlington, Ontario
    My 05 A6 with the 4.2 used to get near 600km with a 75% ratio being highway. My RS6 however is horrible. I was expecting that however.
    2003 RS6 - ecu/tcu chip, varient 3, wagner intercoolers, phaeton brake ducts, recaro seats, body mods.
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by B_S373N View Post
    Supposedly Shell has no Ethanol and thus will provide better mileage. I normally use Petro-Canada but will attempt to switch back and forth to see if there is any truth to that. (Petro-Canada has the Ultra 94 which I would probably run with the ECU tune ...)
    Senior Member Two Rings Mr. Goodwood's Avatar
    Aug 23 2009
    How do you guys measure tank mileage. From full tank until the light goes on?
    What I do is fill up, reset the odo, run it to about 1/4 tank, fill up agian, recard the number of Litres used, divide that per 100km.
    On my B6 S4 Using that meathod, I get about 19L/100km in the city, and about 10L/100km hwy.
    Senior Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    I drive mostly local (4km commute to work daily in slow slow traffic with stop signs). I get around 400km a tank. I am prone to occasionally floor it for no reason.
    I have gotten more like when I made a trip to niagara.. mostly highway, even A/C off for some period of time (nice weather day) and that got me up to 500+.
    I started using an android app called fuel log to keep track but it varies too much to help me much. I am trying to switch to Shell and see if it helps. Before that, I was mainly using Esso and Petro 94.
    2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by Mr. Goodwood View Post
    That's it - - km driven vs litres added to the tank. Will sometimes run to almost empty, other times fill up ahead of time to make sure I have fuel for the drive the next day. But as long as you record actual km and actual litres it doesn't really matter.
    Aug 23 2009
    So what's the B8 S4 real world milage like, in terms of L/100km?
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    My only measured tank (so far!) was 475 km on about 55 L of fuel, or 11.6 L/100 km.
    Commuting to work (~15 km, half highway, half streets) I probably get 12-14 L/100 km, based on adjusted trip computer readings. Your 10 L/100 km on the highway is actually quite good - what speed do you cruise at?
    Apr 26 2010
    Toronto, Ontario
    Maybe it is because of winter tires or I just drive too fast... I can never get 10L/100km on the highway. It's usually around 11...I also drive between 120-140. =\
    I think a good real world number is around 12.5-13 L/100km on mixed driving. I get around 14L/100km.
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by ahcow View Post
    The speed makes all the difference - air resistance increases with the square of the velocity, so at 130 km/h you're probably using 30-35% more fuel than at 110 km/h. (I, too, cruise at around 130 km/h, and it's pretty hard getting 10 L/100 km at a steady 130 km/h based on the trip computer.)
    Jun 12 2011
    My real world since I got the car 4,000 kms ago has been about 12.4L/100km.
    Senior Member Three Rings Deep Sea S4's Avatar
    Nov 06 2009
    I get on average 425-450 on a full tank, but i run in dynamic all the time and have an ECU tune. I'm 40/60 city hwy.
    2010 B8 S4 / Deep Sea Blue / Black Nappa / 6MT / Premium / Nav / B&O / Sport Diff
    Apr 26 2010
    Toronto, Ontario
    APR tune is supposed to improve fuel efficiency. =)
    Veteran Member Four Rings Tanner's Avatar
    2006 A4 2.0T quattro
    Markham, ON
    Except you end up pushing down on the loud pedal more often to take advantage of the aftermarket tunes :) Speaking about APR, they released a newer version of their program for the S4... more powah!
    Mike
    Nov 06 2009
    Quote Originally Posted by Tanner View Post
    When its out for sure my ECU will be in the mail. Had a chance to be a beta tester for the v2 but I wasn't down for that. Should be available for the masses next Monday.
    I'm going from APR Stage 1 (91 octane) to Stage 2+ with the ECMS program switching and the version 2 software.
    The care is already super quick with the 91, with pulley and the advancements with the v2, it should be crazy.
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    I'm waiting until I can get the new tune locally installed - I figure that'll be March/April, soon enough for me.
    Apr 26 2010
    Toronto, Ontario
    ^Same..
    or I will just get REVO or GIAC. I am not going to bother shipping it out.
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Nothing against Revo or GIAC as such, but the APR v2 power is plenty for me, and I trust them to do the programming right. And I'll be able to take the car to H2Sport to get it installed, so that's another plus for me.
    Nov 06 2009
    I think it will be several months if not more until we see onsite flashing for ECU's. You're far more patient than I was!!!!!!!
    For what its worth my car was only down from 3pm on a Monday afternoon until 10am on Wednesday all in when I sent it down to Alabama. Pretty damn efficient.
    Do you know if the onsite flash thats coming and the tools they have made for their dealers still require the ECU still be cracked open and modified, I am pretty sure that's what is being done down at APR as you can see the marks on the outside of the component, I felt confident that they were well versed in this procedure. Flashing via a OBD port is one thing, prying open the cars brain and working on the board is another all together!!!!!!!
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Yes, the ECU still needs to be opened, only in this case APR provides the (APR) dealer with the tools and training - so I'd really want a dealer I can trust to open my ECU.
    Jul 29 2007
    Toronto, ON
    You're not doing bad Bruno. I usually only get ~330kms on my B7. 80%+ city driving.
    2006 Black S4
    AZ Members' Properties Bought/Sold: 6
    Aug 23 2009
    That was during the summer, all hwy crusing at 120km all the way to Belleville. Just to clarify it was more like 10.5L/100km. I would imagine that winter mileage would be much worst.
    Markham, ON
    knew that temperature affects mileage, and geeked out yesterday and graphed my 2.0T mileage (L/100km) with the daily weather from the toronto airport...
    Can't imagine driving a 4.2L V8 right now :)
    Mike
    Jun 12 2011
    Agree - just got 529 kms with another 10 left per trip computer averaging 89km/h to Hamilton. Had guests in the car and stuck to 110 on the highway - huge difference.
    Senior Member Three Rings TeflonS4's Avatar
    Toronto, Canada
    Sorry to the OP for hijacking but where does everyone go for tunes? Aside from Pfaff.
    Toronto, Canada
    I will assume your AC was on during the summer and therefore attributed to higher avgs. You will have to take it for the team and leave your Ac off this summer inorder to support your hypothesis.
    Nov 06 2009
    Quote Originally Posted by TeflonS4 View Post
    H2Sport in Georgetown, Ontario (APR Dealer)
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by Deep Sea S4 View Post
    I'll second that.
    And to get the thread back on track, last fill-up was 492 km (11.3 L/100 km). Not as good as Tanner's 2.0T, but very reasonable and for sure a lot better than the V8.
    Toronto, Canada
    Thanks for the tips guys.
    Right now my L/100 on a 4.2 is showing a 13.2 average. Seems odd.
    Markham, ON
    I'll second that.
    Test drove the S4 a while back, seeing similar consumption on the highway, at about 10L/100km. Comes in between the 4.2L and the 2.0T, not bad for the torque/power of that engine.
    Mike
    Toronto, Canada
    My previous M5 averaged 1litre for every 4-5km driven so the S4 4.2 and 3.0 are like humming birds.
    Senior Member Three Rings egalley's Avatar
    Nov 22 2009
    2010 S4, 2010 Volvo XC60 R Design
    Ottawa, Canada
    I have an app on my BB that I have been track my mileage for the last 10,000km
    I'm currently averaging 12.7L/100km
    My best was 10.2L/100km 90% Hwy
    Worst was 14.9L/100km I's say 50-50 Hwy-city. But I had just gotten the APR stage II ECU tune and pulley. So I was having fun! :D
    I've always had 94 octane from day one and I'm tuned. I also find my mileage is a bit worse in this cold weather right now.
    2010 S4, S-Tronic, Premium, Ibis White
    Navi, B&O, Carbon, ADS with Diff. APR Stage II ECU, APR Pulley, Hyperflow Intake, 35% tint
    APR exhaust with Diamond Black tips. Alu Kreuz. H&R OE Sport Springs. AP Racing BBK, ADV07.TS Wheels
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    b7 2.0t quattro sedan 6speed
    350-375km tank winter
    450-500km tank summer
    70% city
    30% highway
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    557 km on my tank today, MMI showing 20 km left. Two trips from Kitchener to Yonge/401 and back made up 80% of the distance, cruising at 130 km/h or somewhat less, depending on what the traffic allowed.
    Incidentally, it's amazing how big the difference is in the two directions: Toronto-Kitchener will easily use 1.5L more than Kitchener-Toronto. It's not a big elevation change but it's enough to make a difference ...
    That's it? That's horrible!
