Results 1 to 21 of 21
    Feb 09 2009
    chicago
    Coolant/oil fittings
    Can somebody help with a line kit I'm putting together. I need to know the type and size of fittings needed for the lines engine side of all turbo feed and return. I haven't got the time to go tearing into it . let me know but if you know it already that would save a bit of hassle. I'm about to go look on ETKA but I need to know lengths for a tidy route to a turbo mounted to a PSI ex. Manifold. All input and suggestion appreciated!
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    I am assuming this is for a ball bearing turbo? Just wanted to let you know, Jeff does discounts for AZ members. I have his line kit, and the parts are really nice.
    http://www.audizine.com/forum/showth...***?highlight=
    But the item description below will tell you what you need. Not all parts are actually needed, and you will be able to tell which ones you do and don't.
    http://www.psiconcepts.com/store/ind...t_detail&p=177
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
    Feb 09 2009
    chicago
    It's for a water/oil cooled j.bearing turbo. All I need right now is the type and size of fittings to put on the end of each line. The lengths of the lines also. Thanks for the link.
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Quote Originally Posted by Urtorsen View Post
    Pretty much all of it is listed on the PSI line kit, all but the T3 drain flange you will need. Here is a list
    Oil Feed
    1 x 4' long -4 AN braided stainless steel Teflon oil feed line
    1 x M12 x 1.5 to -4 AN adapter fitting (Audi Engine Oil Supply)
    1 x M11 x 1.0 to -4 AN adapter fitting without restrictor (for Garrett T Series)
    4 x copper crush washers for adapter fittings
    1 x 4 AN male to -4 AN female 90-degree adapter fitting with swivel
    Oil Drain
    1 x 11.5" long -10 AN braided stainless steel Teflon oil drain line
    1 x Aluminum - Oil Drain Flange (T3/T4) ATP part number ATP-FLA-009
    1 x Gasket for drain flange ATP part number GRT-GSK-007
    1 x -10 AN to 1/2" NTP adapter fitting
    1 x -10 AN to 1/2" NTP 90-degree adapter fitting
    1 x Audi/VW 1.8T oil pan drain flange
    1 x Audi/VW 1.8T oil pan drain flange gasket
    2 x M6 x 1.00 pitch fasteners for oil pan drain flange
    Coolant Supply
    1 x 20" long -6 AN braided stainless steel Teflon coolant return line
    1 x 13" long -6 AN braided stainless steel Teflon coolant supply line
    1 x -6 AN to 13mm barb adapter fitting (for 058 AEB/ATW block supply)
    1 x -6 AN to M14 x 1.5 pitch banjo adapter fitting (for 06A AWM/AMB block supply)
    1 x -6 AN to 10mm barb adapter fitting (for coolant return)
    2 x -6 AN to M14 x 1.5 pitch banjo adapter fitting (to turbocharger)
    1 x -6 AN male to -6 AN female 90-degree adapter fitting with swivel
    6 x 13mm copper crush washers
    Active Member Three Rings
    Jul 27 2010
    Brisbane QLD Australia
    Ok thread resurrection,
    Just wondering if anyone here has installed psi concept's coolant lines?
    Notice the long'ish line that goes back to the coolant pipe...but what I've got is a short'ish line just like the ones on their website :-
    Am I missing something here?
    Dec 05 2007
    Is it not long enough to barb into the rubber line going to the hard pipe? The short one is for the block (obviously) and the longer one is for the rubber line. I have not installed my kit yet, but seems rather straight forward. thenj3 just installed his, so you can send him a PM or ask in his build thread.
    Feb 08 2011
    Murrieta
    A picture from his thread. You can see the coolant line attached to the stock rubber hose right in front of the cam pulley.
    You could always replace the stock rubber hose with a braided hose that you then slip over the nipple on the coolant pipe and over the fitting that came with the PSI kit.
    Jul 27 2010
    Quote Originally Posted by M-Hood View Post
    Thanks Mike. Thanks explains everything. As always you've been a good contributor here.
    Btw, is Jeff still active at psiconcepts(or psiconcepts still in business?)? I recommended a friend to get a TD05-18G turbo kit through Jeff and somehow my friend said it took ages for Jeff to get back to him. Only got back to him after he emailed paypal about some stuff he ordered. I may create a dedicated thread on this.
    Senior Member Three Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM, 03 A6 3.0QA
    Danville, KY
    I wanted to bump this thread since I have the same question, but for my Frankenturbo setup. Ive already got an aftermarket oil feed line, just need one other fitting to install it, but Im not sure if there is a certain fitting I need to limit the amount of oil going to the turbo. Id like to replace the bulky oil return line as well with something better. The coolant lines, Im not too worried about, but if I were to do so, could the kit above be used, or would I need different fittings. The FT utilizes the same lines as the K03/K04, so if someone has a list of fittings, that would help out a lot.
    1998.5 A4 1.8TQM / FrankenTurbo F4H-L / C2 Motorsports Tuning / 440cc Injectors / C2 Billet 3" MAF Housing / Cat Delete / Vibrant Muffler
    2003 A6 3.0QA
    Feb 08 2011
    Murrieta
    Quote Originally Posted by xdewaynex View Post
    No you dont need a restrictor fitting.
    Oil feed fitting at the turbo.
    1 x M12 x 1.25 to -4 AN adapter fitting
    May 24 2009
    Danville, KY
    Thanks M-Hood. I was looking at the kit from PSI and trying to dissect everything I need. Hopefully what I got down is right, if not please correct me.
    Coolant Supply Line:
    -6 an line
    -6 an to 13mm barb fitting for AEB block
    -6 an M14 x 1.5 banjo adapter
    Coolant Return:
    -6 an line
    -6 an male adapter
    -6 an 10mm barb fitting at the upper coolant hard pipe
    Oil Feed:
    -4 an line
    M12 x 1.5 to -4 an fitting at the filter housing
    M12 x 1.25 to -4 an fitting at turbo
    Oil Return:
    -10 an line
    Universal flange for turbo
    -10 an to 1/2" NTP adapter
    -10 an to 1/2" NTP 90* adapter at the oil pan
    Audi/VW oil pan flange
    2003 A6 3.0QA
    Apr 22 2007
    98 A4, 73 914 v8, 89 CRX SI, 62 F100, Ninja 250
    Modesto, Ca
    Mike,
    Does it matter which side the coolant inlet is?
    98 A4 1.8TQM 160k miles
    Apr Stage 3/ FMIC by Greedspeed/ Cone intake/ Borla exhaust/ Test pipe/ Apexi boost controller/ Stage 4 SB clutch/ Spec 16lb FW/ Koni Coil overs/ H+R rear 22mm rear sway with welded mount support/ In dash GPS mount (hackjob)/ VDO boost guage/ RS4 reps/ AWE Drivetrain stabilizer/ Urethaned trani, motor, and rear end mounts/ 255awhp, 0-60 4.9, 1/4mile 13.57@100mph, 1.04 G's See it in action
    May 24 2009
    Danville, KY
    Was hoping someone could clarify that my last post above is right for my setup, or what needs to be changed.
    2003 A6 3.0QA
    Dec 05 2007
    Seems right to me.
    May 24 2009
    Danville, KY
    Sourced all my lines from a local race shop today, along with the blue/red anodized line ends, and the 2 male joints for the oil return line, all for $98. I didnt think that was too bad of a price. Ive still got a few things to order to complete the kit. Much cheaper than buying stock replacement lines.
    2003 A6 3.0QA
    Dec 05 2007
    That's a damn good price. Hope they are quality, because that is what we are mainly buying. For example, ebay fittings will leak on you...badly.
    May 24 2009
    Danville, KY
    Everything seems legit. He said they order everything from Summit/Earls. Its a big time race shop that has a good reputation, so I doubt theyre using anything thats not good quality.
    2003 A6 3.0QA
    Dec 05 2007
    I was going to say, Earls are really good fittings. I buy stuff from Summit when needed. There or Jegs.
    May 24 2009
    Danville, KY
    Im waiting delivery on 2 more fittings I had to order from Summit, that the shop didnt have. They dont carry a lot of metric stuff. There are 3 other fittings I need from PSI's kit, but there is no number to call, and waiting on them to reply to my email seems like its taking forever.
    2003 A6 3.0QA
    Dec 05 2007
    Which fittings are those?
    May 24 2009
    Danville, KY
    The ones I need from PSI are the 2 barbed fittings for the coolant feed and supply lines, and a banjo bolt for the coolant. I actually found them on ebay along with the oil flange adapters for the pan and turbo.
    2003 A6 3.0QA
