Results 1 to 21 of 21
    Active Member Two Rings wws's Avatar
    Mar 21 2011
    X-Terra, Specialized S-works, Giant TCR, Pinarello Dogma
    San Mateo, Ca
    What should I do next!
    I have about 5 Benjamins to spend. What should the next mod be for the car or should I just save up more money? Current mods listed in sig.
    2008 Dolphin Grey S4 6MT
    Mods: RS4 shift knob, RS4 E-Brake, RS4 Pedals, Hotchkis RS4 Sways, Stern Rear Endlinks
    Mar 21 2011
    San Mateo, Ca
    Not sure why it posted twice. Can moderator delete this one?
    Active Member Two Rings Hrushka's Avatar
    Sep 19 2011
    Arlington, VA
    God where to start, ha. Would you do the work yourself?
    Suspension/Brakes: Big Brake Kit and Coilovers
    Wheels: Go with BBS 19's or a Mesh wheel
    Engine: Chip tune, Cold Air Intake, Diverter Valves, TIP, Exhaust, etc.
    There's alot you can do with your S4, not sure if you would rather the muscle or look at this point..
    Senior Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Honestly, if it were MY car. . . I'd probably sell the RS4 shift knob and RS4 pedals and pick up the JHM weighted shift knob & pedals and then still make some profit (maybe throw that extra cast at JHM SS kit).
    From there, if it's power you're after, piggies & JHM tune is the outright answer. Then magnaflow catback (then JHM shifter if ya didn't do it above as it's a great cheap mod). That's not a ton a money, but more then covers your current budget. Also, if you're doing the work yourself, do the apikol front snub mount & 034 zero clearance snub bracket
    Quote Originally Posted by Hrushka View Post
    Check which forum you're in before posting. . . (i.e. BBK & c.o. more than double his budget, and your engine options are mostly pointless)
    2005.5 S4 MT6 l JHM Parts: Stg 1 Supercharger, Long Tube Headers, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I. Res B6 Exhaust, Pedals &Weighted Shifter l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Active Member Two Rings adioman6000's Avatar
    Jan 12 2011
    slc/ut
    Haha diverter valves and cai. Not being a dick just saying
    Mar 21 2011
    San Mateo, Ca
    I do plan on doing the work myself. There is so much I have planned but have to do it in baby steps. This time around I was thinking of doing the Stern Motor Mounts, Stern Tranny Mount, Rear Diff Mount, and snub mount. Then next doing the JHM short shift Trio.
    I would like to do the JHM tune but want to do the intake manifold, exhaust, and tune at the same time. I could do the tune now but I do not have the money for exhaust.
    I do want coilovers but again I would need to save up for a while and decide which ones to go with.
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    ^I would do tune with piggies, then exhaust when ya can. Get the tune on there before manifold on though, you don't realize what you've been missing out on till ya get it.
    Jan 12 2011
    slc/ut
    x2 on piggies totally worth it and not to hard to do if you have the right tools.
    Mar 21 2011
    San Mateo, Ca
    I am going to wait on the tune.....I will be moving out of california within the next few months then I will get the 93 octane tune.
    Mar 21 2011
    San Mateo, Ca
    Is there a big difference between the street and race density stern motor mounts and trans mount?
    Active Member Two Rings karsty's Avatar
    Dec 10 2010
    2007 Imola RS4
    Edmonton, Alberta Canada
    Quote Originally Posted by wws View Post
    Definitely a good way to start things out! Hold onto the rest of your cash until you're ready for the tune, and get the exhaust and intake manifold at the same time.
    Active Member Three Rings Apat's Avatar
    Jul 04 2011
    Minneapolis, MN
    Whether getting the tune now or not piggies should be on your list of mods to do next. Your car will thank you
    2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // 19" MRR GT1 summers // 18" VMR V710 winters // PSS9 Coilovers // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Totally confused by this, the OP said $500 and you are recommending wheels, brakes, C/O's...we must shop in very different places.
    Secondly you state go with 19's in mesh....what if the OP does not want mesh wheels and the only reason to go 19's is for vanity,,,why not get 18's and save weight, money, and ride quality?
    Then you go on to recommend a CAI and Diverter valves, first of the B6/7 S4 does not have diverter valves and secondly a CAI does nothing for you.
    I see you are new to the forum but before you go spouting off about what to get maybe you should do a little research and know the platform a bit better before giving recommendations.
    To the OP, I personally think the best upgrade I have done to my car are the H-Sport RS4 bars, totally within your budget and makes a noticeable difference.
    EDIT: And I guess I should have read your mod list and have checked to see what you have done...LOL. With that said I am not usually a SSK's but my car came with the JHM Trio and I like it a lot,
    Cheers,
    Jim
    Registered Member Two Rings kevinzarif's Avatar
    May 02 2010
    KNOXVILLE TN
    I'm in the process of doing a complete vinyl wrap in matte black, I've spent about $350 for the vinyl and supplies.
    Zarif
    Registered Member One Ring BigJohn4.2's Avatar
    Nov 27 2011
    ct
    save the money for an exhaust and do the piggies on your own.
    Mar 21 2011
    San Mateo, Ca
    I am saving.....now up to $1200.
    Senior Member Three Rings BWT's Avatar
    Feb 27 2009
    Sprint Blue B7 S4
    Boston, MA
    First 3 things you should do for adding power:
    -piggies (free)
    -catback ($650-1200, depending on new vs used and which brand you pick)
    -tune ($550)
    So, if you were to get a used catback or even retrofit a Magnaflow, you'd be at right around $1200 with exhaust and tune. The IM can wait til you save up another $1200. The tune will adapt to the IM without needing an update.
    Or if you're thinking more towards handling, $1200 will get you a set of H&R coils.
    Active Member Four Rings Axel-'s Avatar
    Jan 29 2011
    Toronto, CA
    Quote Originally Posted by BWT View Post
    -piggies (free)
    -tune ($550)
    Pretty much in agreement. Do the piggies (really cheap), get a Magnaflow X-pipe catback (can be had for like $650 new) and then the JHM tune ($500).
    You'll fall in love your S4 all over again.
    Sprint Blue B7 S4 Avant 6MT - Dynos
    JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - Apikol snub mount - RS4 Pedals - TT-RS MFSW - Dectane LED tails - 19" O.Z. Ultraleggera - 35% Huper Optik tint - Zada Tech Gauges - Dynavin D99 Android
    Mar 21 2011
    San Mateo, Ca
    I do have a question about the exhaust. Everyone mentions to get a 2.5 in catback, but what is the purpose of having a 2.5 in catback when piggies are 2.25 in? I will plan on getting 2.5 in downpipes and 2.5 in catback with tune. So I have to save up a bit more.
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    You're correct in that the bottleneck is still the 2.25" flange on the piggies. It's okay to step from 2.25 to 2.5 and it shouldn't cause any extra turbulence in the exhaust tract. Piggies are free (except your time) so some are willing to accept they won't squeeze every last HP out of the car.
    2.5-->2.5 is better, especially if you are running 2.5" cats.
    2005 S4 saloon 6MT
    Senior Member Four Rings beemercer's Avatar
    Aug 14 2008
    05 Jeep GC 5.7 Lmtd. QDII - Oh-One Fat-Body Four-Two
    Central Mass
    its still less restriction overall having the 2.5" on the backend... having one section of smaller pipe (a neck down, etc) doesn't completely negate the benefits of the rest of system. Its a flow system from air filter to exhaust tips, and you want the shortest effective length that still provides good pulse tuning in the motor's powerband. Neckdowns, bends, baffles, valves, smaller piping all increase the effective length.
    RIP Sway
    _________
    JHM
    AMA
