Results 1 to 12 of 12
    Jul 21 2008
    Boston
    Place to bed-in the brakes in eastern MA?
    Need a place to bed-in the brakes which requires multiple 60-5mph runs.
    Any recommendations for an empty road where this could be done, preferably in a 50+mph zone?
    Jul 21 2008
    Boston
    starting to wonder if the service shops actually bed-in the brakes for you after pad/rotor replacement.
    Feb 09 2011
    Beverly, MA
    North Shore or south of Boston?
    Sent from my PC36100 using Tapatalk
    04 Nogaro Blue S4
    Jul 21 2008
    Boston
    preferably north of boston...moved here about a year ago but still not familiar enough with all the roads in the area
    Feb 09 2011
    Beverly, MA
    I use 133 in between Ipswich and Essex at night. After 7pm that road isn't too traveled. Speed limit is 50 or 55. Adjacent to it is many fields so you won't be bothering anyone.
    04 Nogaro Blue S4
    Jul 21 2008
    Boston
    hmm, bit of a drive for me (medford area). will have to find a nice restaurant around there as an excuse to head up. thanks for the info though!
    May 21 2007
    07 A4 Ibis White/S-line/Ti/2.0T Q
    Northshore, MA
    you dont need to do that. just drive normally for a few hundred miles and you will be fine. dont ride the brakes, and dont slam on them. just stop like a normal person.
    -Nate
    07 Ibis White A4 S-Line Ti Package
    GTRS'd 04 6SPD 1.8T A4 Quattro SOLD
    http://www.cardomain.com/ride/3037832
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    PM me with youre H&R Parts needs!
    Active Member Two Rings RSblood's Avatar
    Jun 29 2010
    2001.5 Vast Stg 2+ S4
    Needham, MA
    What doublezero said..
    Jul 21 2008
    Boston
    Actually looking to cleanup the brakes to figure out what to expect from the entire braking system before choosing what pads/rotors to install next. It's not a new set of pads/rotors. Currently running stoptech posi-quiets with powerslot rotors.
    May 21 2007
    Northshore, MA
    So if theyre used brakes then there is nothing to bed in. I now do not understand this thread.
    -Nate
    Jul 21 2008
    Boston
    From what I've been reading, I'm seeing the bed-in process as a method to coat the rotors with material from the brake pads. However, contaminants may adhere to both the rotors and pads throughout the life of the brakes or if the brakes were never bedded-in in the first place.
    I'm going by the assumption that rebedding the brakes can burn off these excess contaminants/deposits.
    May 21 2007
    Northshore, MA
    you can not "rebed" brakes. once theyve been used, theyre used. which is why many shops dont recommend a pad slap (just doing pads without replacing or turning rotors).
    -Nate
