Results 1 to 18 of 18
    Veteran Member Three Rings ratherb1's Avatar
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    front tire wear both front tires bald on outside edge why?
    so i replaced my CA's about 6-7 months ago and got my alignment done but i just had to replace both my front tires
    because the were so bald on the outside edge the metal was showing all the way around and was wondering if anyone else has had a similar problem and why its happening i searched and some ppl were saying inner TRE's but i wanted to ask the experts what will cause this BOTH front tires bald on outside edge inner part of front tire was great rear tires also in great condition
    tires were toyo versado
    -----Romie------C5-A6-2.7T-STAGE 2-SELFTUNED-ST-TSW
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Items for Sale
    if they did alignment and still you get wear then possibly you need to replace the control arms , tie rods etc,
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    ^^^^^^they did the control arms and i think TRE's and after i got an alignment
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Quote Originally Posted by ratherb1 View Post
    this may be generic but have you checked if the tires are properly inflated?
    Feb 07 2008
    04 silverado V8, 06 Touareg V8, 03 S6 V8, 03 RS6 V8TT
    The boonies, near Seattle
    Quote Originally Posted by 2.7taudi View Post
    This.
    -dre
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    air pressure was good i always checked it ...... ok so this doesnt seem like something that happens too much
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Fort Worth, TX
    It sounds like they botched your alignment.
    Did they provide you with a before and after print out?
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    they gave me a print out but i dont think i have it anymore i got the alignment done at townfare tire
    Veteran Member Four Rings Widebody4.2's Avatar
    Jan 08 2012
    S6 Avant
    Central MA
    Well there's your problem there hacks, I used to be one I've seen guys there bang on the sensors to get them to read in spec and shit they're a joke.
    May 30 2008
    Honda HRX
    Fort Worth, TX
    ^ I was kinda thinking the same.
    They probably just set your toe and didn't touch the camber.
    An alignment is not something you skimp on.
    Jan 31 2010
    S-Line A6
    East Haven, CT
    I'd go back and complain, there should be some kind of warranty on the tires. Especially since you had purchased them, mounted and balanced, and aligned all at town fair, I can't imagine that they wouldn't help you in some way, even a pro-rated replacement or something.
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    i found the print out can anyone tell me if its good?
    [IMG][/IMG]
    Senior Member Three Rings Audi4.2's Avatar
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    I only have limited knowlege of this but to me it looks like the guy messed up. Everything that is red is unacceptable?
    Oct 11 2011
    Kawasaki Ninja
    Bountiful, UT
    The red is all on the before picture. It looks in spec, so theoretically it's all good...Assuming, of course, he set the machine properly and used the proper spec in the computer.
    Sep 01 2009
    1999 VW Jetta TDI 48MPG!, 1998 F150
    New Jersey
    Alignment Specifications
    Front Axle Suspension Sport Rough terrain Rough terrain Level control
    (1BA, 1BH, suspension suspension suspension system
    1BP, 1BC) (1BE) (1BB) (1BT, 1BJ) (1BG)
    Camber -50'25' -105'25' -35'25' -45'25' -50'25'
    Maximum permissible 30' 30' 30' 30' 30'
    difference between
    sides
    Toe per wheel 10'2' 10'2' 10'2' 10'2' 10'2'
    (adjustment value in
    start position)
    Toe per wheel (control 10'5' 10'5' 10'5' 10'5' 10'5'
    value in start position)
    Toe constant per wheel 7'2' 7'2' 7'2' 7'2' 7'2'
    (setting)
    Toe constant per wheel 7'7' 7'7' 7'7' 7'7' 7'7'
    (control value)
    Toe-out angle at 20 130'30' 130'30' 130'30' 130'30' 130'30'
    Rear Axle
    Camber -40'30' -40'30' -40'30' -40'30' -40'30'
    difference between
    sides
    Toe per wheel +8'5' +8'5' +8'5' +8'5' +8'5'
    Maximum permissible 10' 10' 10' 10' 10'
    deviation from
    longitudinal axis of
    vehicle
    They have too much toe in! Here is the proper alignment specs from all data.
    Sit Down, take a look at it, take it apart, and FIX it!
    Sep 11 2009
    NE
    Items for Sale
    too much toe will do that to you and you have 2x as much as permissible.
    Also, camber is not adjustable in our cars except for evening it out between wheels by means of shifting the whole frame and making is equally bad on both sides.
    Now, the 100 point question. How was the car aligned? Did the tech put your AR into Level 2 and locked the suspension from changing? And what level are you usually driving at? Always make sure the staff knows how to handle the car and ensure it is at the level you're normally drive at most of times to get the toe right as toe changes with levels.
    Jun 07 2010
    Lincoln navigator
    Rhode Island
    Items for Sale
    Quote Originally Posted by Siricospeed View Post
    difference between
    sides
    start position)
    (setting)
    (control value)
    Rear Axle
    difference between
    sides
    deviation from
    vehicle
    is this for 2001 a6 i have an A6 (if that matters)
    thanks for your help you guys have been very helpful as usual
    Sep 01 2009
    New Jersey
    It is for the 2000. 01 is the same.
