    Registered Member Two Rings
    Dec 19 2011
    New York/NY
    Serious problem with interior!
    I have a 2007 Audi A6 with a stain or remainder of a sticker image on the dashboard on top of the glove box. Their used to be a "No Smoking" sticker on the dashboard and now because of long sun exposure I'm assuming I can still see the letters on the material. Is their any way I can remove it?
    Active Member Two Rings OTDetailer's Avatar
    Oct 13 2011
    NNJ/LA
    You can clean it with OPT powerclean
    and if that doesn't work, then lastly you can use 3M adhesive cleaner
    Dec 19 2011
    New York/NY
    This is so confusing. Its not sticky residue, its just like tan lines on the dashboard. Can I use Goo Gone or Goof Off? Maybe WD 40?
    Oct 13 2011
    NNJ/LA
    sure you can try that, but I never tried it. I always have my luck with OPT powerclean for interior stains, but sometimes not all can be removed as the damages are permanent :(
    Active Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2006 Audi A3, 2008 Jetta 2.0T, 2008 Taureg, 86 VFR 750
    About the tan line, I have an 06 A3 and have had a radar detector in the same position on my dash without any evidence of fading ((tan line). I did have a problem similar to what you describe on my son's Jetta. I washed the entire dash with Eco Touch DBC22 Dashboard and Trim Cleaner which I got from Amazon.
    Good luck
