Results 1 to 6 of 6
    New Member One Ring colbybender0's Avatar
    Dec 08 2011
    california
    Exclamation TT 1.8t Starting issues
    Lately my 01 tt with 120k on it has been having random starting problems. at first it would start and not hold an idle and just die. that stopped but now in the mornings when its really cold sometimes it just cranks but wont start. could it be a fuel pump? or moisture in the lines? i dont think its the starter. any ideas? only had the car 4 months.
    Dec 31 2011
    brattleboro vermont
    probably best to get code scanner to diagnose this problem... but ignition system and fuel delivery components would come to mind first.
    Dec 08 2011
    california
    they scanned it and nothing came up. everytime i start the car it checks out OK.
    Registered Member Two Rings TheMuska00TT's Avatar
    Nov 17 2004
    2000 Audi TT
    Lubbock
    My 00 TT did something similar and I changed out the crankshaft positioning sensor. There would be times that it would take 3-5 times to get it to start and then other times it woud just start fine. Its not a hard sensor to replace and not to much $$. Hope this helps.
    Dec 08 2011
    california
    Quote Originally Posted by TheMuska00TT View Post
    i ended up having the fuel pump changed and that solved the problem. thank you though!
    Dec 31 2011
    brattleboro vermont
    Happy ending... enjoy your ride!
