Results 1 to 15 of 15
    Active Member Three Rings Amsterdamned's Avatar
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Getting into DA polishing
    So I've decided to tackle some swirls on the hood of my Dolphin Gray S4. I have already tried using Swirl X by hand with no luck. I really like the Meguiar's DA Microfiber Correction System and think it will be a good entry into DA detailing. I plan to use this 2 step process to get my feet wet and get a feel for the machine. Once I get more comfortable and get over the learning curve I plan on getting into other pads, polishes, LSP's etc. I have already heard that Audi paint is quite hard and I might need something with a little more cut. The swirls aren't that bad so I'm going to start with the least aggressive approach and work my way up as neccessary. Here's my shopping list from this afternoon, I should receive my G110v2 any day now.
    Feel free to recommend anything that will help penetrate the Audi paint or works well with gray metallic paint like Dolphin Gray. This car is my daily driver that is always outside exposed to the Florida elements. It has the potential to see lots of rainfall, sea salt, and tree sap etc...
    I also bought some other stuff to help clean up the Ol' S4. I just remembered I forgot to get some iron cut. That will have to wait until the next round. I have plenty of clay so didn't pick any up.
    1 Einszett 1Z Perls Shampoo - 500 ml
    1 Meguiar's Professional DA Polisher Backing Plate W67DA - 5"
    1 Meguiar's DA Microfiber Finishing Wax - 16 oz
    1 Meguiar's DA Microfiber Correction Compound - 16 oz
    1 Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack - 5.5"
    1 Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack - 5.5"
    1 Meguiar's Pad Conditioner Brush
    1 Microfiber Waffle Weave Drying Towel - 36" x 24"
    1 Microfiber Ultra Plush Two Sided Towel - 16" x 16"
    3 Microfiber Black General Purpose Towel - 16" x 16"
    1 Squash Air CS-X3 Refillable Air Freshener Dispenser
    1 Grit Guard Grit Guard Insert - BLUE
    1 Stoner Trim Shine Vinyl & Plastic Coating - 12oz
    .:2004 DG S4 6MT:.
    Clear Corners // 6000k HID Fogs & Lows // Hardwired V1 // 3M 35% Tint
    Trexturk Cat-less DP's // 2.5" Magnaflow // K&N Drop-in // JHM LWCP // JHM 93 Tune
    Apikol Snub & 034 Bracket // Stern Pro Mounts // 034 Street Trans. Mount // Apikol Rear Diff Mount
    Active Member Two Rings OTDetailer's Avatar
    Oct 13 2011
    NNJ/LA
    I will leave Meg MF finish pads and polish out. replace with Menz SF4000 and Detailersdomain Blue pad or LC blue pad.
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Quote Originally Posted by OTDetailer View Post
    I'll definitely consider the Lake Country pads all I hear are good things about them. Menz is great too. Whats a good foamer at a good price? How is the Gilmour at $60? The Cam Spray foamer is nice but a little too pricey for me.
    .:2004 DG S4 6MT:.
    Oct 13 2011
    NNJ/LA
    If you decide to get LC pads, get the flat ones. The Gilmour is what you'll need. The cam spray cannon is for powerwashers, so its more expensive. If your plan of attack is use Megs MF compound to cut, it will leave a good finish on your color, but if you want it to be great then follow it with MenZ SF4000.
    Oct 13 2011
    NNJ/LA
    and you'll need more towels.... like 10-20 of them for paint corrections .....but its all up to you
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    I have a bunch of MF those are in addition. I'm going to add the LC Blue pad and Menzerma SF400. Thanks.
    .:2004 DG S4 6MT:.
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Iron cut and Gilmour Foamaster will have to wait until later.
    .:2004 DG S4 6MT:.
    Oct 13 2011
    NNJ/LA
    sounds good! it's all about having fun and not breaking the bank... enjoy!
    Active Member Three Rings M|R's Avatar
    Aug 11 2011
    For what its worth OP I bought the Megs DA kit with the PC 7424XP and some other stuff a few months back. It is a great machine and my shoulder thanks me everyday haha. Let me tell you the car I used it on (my vette) never looked so good ** after some time of course.
    There is a learning curve, quite a big one depending on your detailing experience. It takes some time to get used to the machine and its speeds as well as the polishes and pads - but it will become secondhand nature over time. My suggestion to you...read read read as much as you can - the more knowledge the better. Although this forum is mainly occupied with professional detailers that I couldn't hold a candle to in comparison, if you need any insight or anything from me feel free to shoot me a PM, I was in your shoes a little while ago.
    Sent from my Galaxy Nexus using Tapatalk
    B7 S4
    034 Tranny Mount • Apikol Snub • DBA 4000 • Fast Intentions • Hawk HPS • JHM SS • Trexturk 2.5" Catless • Vag'd
    034 Tranny Mount for sale: http://www.audizine.com/classifieds/...?product=71719
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Thanks guys!
    .:2004 DG S4 6MT:.
    Active Member Two Rings JoeyZ's Avatar
    Oct 10 2011
    Just picked up 2008 CPO S4, Dolphin Grey.
    Washed with Adams Shampoo, Clayed, and hit with Meguiars DA and 300A. Followed up with Menz Power Finish on a green pad.
    If you work the 300A properly, some go right to LSP, but with the Dolphin Grey, I was trying to really get it to pop so i followed up with the PF.
    LSP was 1Z Glanz. 3 coats.
    Rims and Bottom panels all hit with Collinite 476s. Winter is coming!!
    Id post a pic, but not sure how.
    Senior Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    '05 S4 MT6 pollution machine
    Chicago NW Burbs
    Dolphin grey can look awesome with full correction. Here is mine after full correction, 2 layers of power lock, and a coat of Lusso Oro
    GO: 2.5" trexturk catless dp's // 2.5" x- piped cb // JHM Stg 3 // 034 LWFW // JHM 93 // JHM SS // JHM LW Rotors // Apikol Snub // Stern Street Motor // Stern Trans // JHM LWCP // 034 MAF hose // RS4 Sway
    SHOW: 18" Enkie RPF1 // FK Coils // 35% Tint // Ecodes // HID fogs // Pioneer F90BT // RS4 Shifter // RS4 Pedals // B7 Console // Valentine 1
    AudiRevolution.net
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    That looks great Joe. Hand waxing just ain't cutting it anymore. I'm looking forward to results like that.
    .:2004 DG S4 6MT:.
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    Just read these threads. Thanks.
    .:2004 DG S4 6MT:.
