Results 1 to 4 of 4
    Active Member Two Rings flashovermac's Avatar
    Apr 07 2009
    LC-1 Wideband Wiring
    Where are you guys getting switched power and ground for your Innovate LC-1 Wideband setups? Thanks.
    Apr 07 2009
    Quote Originally Posted by getslideways View Post
    75x terminal?
    Thats good for power.
    Any problems grounding the LC-1 to the fuse panel screw??
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    That is where I have all my little electrical parts grounded to (2 electrical gauges, turbo timer, and will place my LC-1 there also). It is recommended to use an in-line fuse holder off there for safety reasons. I have not had one there for years, and will get to it maybe this summer. It is best to have all the grounds grounded to the same spot (if adding anything else to your car that needs to be grounded), but I think the LC-1 instructions says that it should be placed on it's own ground.
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
