Results 1 to 40 of 44
    Registered Member One Ring 2000AS4's Avatar
    Dec 21 2011
    Portland/Oregon/USA
    2000 S4 wont Run
    hey Audizine users i got a tuned s4 with stage two clutch chipped ecu bigger wastegate and all the good stuff. idk if ull mind or not or if u would know why my car doesnt want start. the car trys to start but doesnt wanna turn all the way over and start. i though it was timing belt but i guess its not and someone said something about camshaft sensor, if you can help me some how that be great thanks
    serge..
    Active Member Two Rings mkemk3's Avatar
    Oct 11 2010
    Charlotte NC
    Moar info
    avants do it better
    CF interior trim, GIAC-X, 034 motor/snub/tranny mounts, 034 endlinks, forge 007's, full samco kit, 034 silicone accordion, ss brake lines, hawk pads....
    Coming soon-
    Euro hatch!
    Dec 21 2011
    Portland/Oregon/USA
    2000AS4
    I picked it up from some one that said it had low compression in cylinnder 5 but i dont think low compression isnt gonna start the car. I looked throught the timing belts and they seem fine and in good order. Some one said about cam shaft sensors but im not sure. The guy that i got the car from said it was his daily driver. after the low compression he went in to autozone and ever since it wouldnt start. IDK but if anyone know what it could be please let me know.
    Thanks.
    Active Member Three Rings Monty23's Avatar
    Oct 27 2011
    S4, R6, Raptor 660, 2011 Jeep Wrangler Unlimited, 2000 Dodge Dakota 4.7
    Near Philly, Pa
    So you bought a very expensive car to work on that doesn't run and you don't know how to work on cars? You are doing a very poor job of describing the issues with your car. If you want any kind of meaningful help, your are going to have to do a better job describing your issue(s). You also need to VAG your car. Is your check engine light on? From you original description of the motor not wanting to turn over, it sound like a weak/bad battery or starter issue...
    Active Member Two Rings force fed's Avatar
    Mar 20 2011
    Albany
    Gotta vag it. Could be cam sensor... or battery, tb, wiring, fuel pump, ecu or any and everthing else that could cause a no start, does it have gas in it?
    Registered Member Three Rings Peter1.8t's Avatar
    Dec 03 2009
    2000 s4, 1969 mustang coupe
    Seattle, Washington
    Huh Bigger wastegates????
    Senior Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    stage 2 b5 s4silver,stage 3+ b5 s4 santorin tial 605.
    in a audi
    Quote Originally Posted by Peter1.8t View Post
    exactly my question
    Tial 650's, CM850 Twin, ER SMIC'S AWE Twin, KW V3, TDI TRANS with RS4 3'rd gear, 034 Adjustable everything, Hotchknis Sway Bars, 034 track engine and trans mounts, Apikol rear diff carrier, JHM trio < dont do it its going out asap, only keeping the ss, 18x9.5 et 25 bbs lm's , sexy clean santorin <3
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    Previous-01 A4 1.8TQ, 90 G60 Corrado,97 Jetta GT,91 Jetta ecoDiesel,90 Coupe Quattro
    PA
    From the information provided it seems you may have the same problem I had last
    Month. The fuel pump went in mine. Can you hear the fuel pump when you turn the
    key prior to start. Also the relay is behind the driver knee bolster.
    Tiptronic Self Canceling Ring For Sale
    Samco TBB For Sale
    Dec 21 2011
    Portland/Oregon/USA
    How do i VAG it im new to Audi?
    Jan 13 2007
    PA
    Quote Originally Posted by 2000AS4 View Post
    http://www.ross-tech.com/
    Or buy a cable from eBay or find someone local that has it. Maybe check the regional forums for that.
    Do you have a CEL? Autozone can scan for free.
    Did you check the fuel pump, relay and fuse?
    Samco TBB For Sale
    Dec 21 2011
    Portland/Oregon/USA
    I was told first to chech my cam sensors and crank, my cam sensors did have some white film forming on the magnet. could that be it??
    Dec 21 2011
    Portland/Oregon/USA
    and i cant check the check engine light becasue the car wont start so all lights are on, and i cant drive it to autzone becasue it it wont run, i ordered cam and crank sensors hopefully that will help me out a bit
    Active Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    go to autozone and buy a cheap obd2 reader.. run about 30$ up here in cali.
    far cheaper than the vag(which i just ordered) and it will give you the codes that you need to get your car running..
    also, try putting a charger on your battery.
    Senior Member Three Rings CELison's Avatar
    Feb 23 2010
    state college pa
    pull codes and check for fuel and spark. and more info on those big boy wastegates!
    J-Fonz tuned Frankenturbo Stg III, JHM fmic, Vast stage 3 clutch,Fidenza lwfw, JHM SS/linkage, Borla exhaust, piggies, catless kittens, vogtland C/Os, full mounts, vmr v710s, some rs4 goodies ect
    Dec 21 2011
    Portland/Oregon/USA
    lol there actually downpipes lol not wastegates
    and Thanks for the help guys!!!!!!!!!
    Dec 21 2011
    Portland/Oregon/USA
    NO HOMO
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    Scan the codes with a code reader. We have one available below. It could be a number of things, Fuel pump, fuel pump relay, crank position sensor..
    Click HERE to order or for more information.
    I hope this helps!
    Jason
    Dec 21 2011
    Portland/Oregon/USA
    So i changed my cam sensor and my crank sensor and it still wont run? fuel is pumping and i just changed the sparks, and the coils, no check engine codes are given? im stuck anyone ideas?? thanks
    Active Member Three Rings csosnowski's Avatar
    Sep 05 2010
    00 A4 Avant 1.8TQM, 77 Chevy 4x4 454, 88 Pathfinder
    Bend, Oregon
    what are you scanning the car with that you are getting no codes?
    how do you know fuel is pumping?
    if the fuel pump relay is bad it can disable the injectors, so even though the fuel pump may be working the ecu will not be able to fire the injectors. are your spark plugs wet with fuel after trying to start?
    do you know if you have spark at all?
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - APR Stuff, Piggies, Darintake, 710N's, 034 Track density stuff, Vogtland - GONE
    2000 A4 Avant Sport 1.8TQM - Silver - Black - GIAC, Darintake, H&R / Bilstien
    russianguy.2007 - "Oh tight! thats the S4, A-Line"
    Dec 21 2008
    A.A CO Maryland
    just stop throwing parts at it now and pay someone to fix it
    Dec 21 2011
    Portland/Oregon/USA
    i know the fuel is pumping i unplugged the cable and tried turning the car and fuel was squirting. i rented the 400 dollar new machine from o'riellys and had the fuel injector circuit come up, i realized the injectors were unplugged so i plugged them back in and now there is now codes being read. its a can obd2/obd1 and abs machine.
    Sep 05 2010
    Bend, Oregon
    ok so you wont have any vag specific codes unless you have a vagcom or gecko (dealer) machine.
    so you have codes now? which ones?
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    Lower it.
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Sep 05 2010
    Bend, Oregon
    Quote Originally Posted by A62TURBO View Post
    Lower it.
    lol
    Active Member Two Rings B5S4Life's Avatar
    May 29 2011
    Laurel, MD
    I feel like this is bad a joke........lol
    Senior Member Two Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    Quote Originally Posted by B5S4Life View Post
    This..
    when you say it doesn't crank all the way over, can you rotate the motor fully by hand?
    3v0m
    Jan 06 2012
    California
    check timing?
    Jan 06 2012
    California
    or caress her gently..
    May 29 2011
    Laurel, MD
    Quote Originally Posted by zrider91r View Post
    Most certainly this. She'll start right up.
    Dec 21 2011
    Portland/Oregon/USA
    lol no there are no codes being read. the timing is in place i chacked. the motor revs up just doesnt start. i can explain but it like its starts but it doesnt. as if its something little. And ive caressed her enough and she still dont wanna make me happy lol
    Sep 05 2010
    Bend, Oregon
    its hard to believe that theres no codes being thrown.
    does it feel like its firing at all? are you able to take video?
    Dec 21 2011
    Portland/Oregon/USA
    ya ill post a video when i get home. if anyone has ever had a fuel cut off switch or i guess a bad fuel pump thats what the car sounds like. it wants to start but seems like something is missing.
    Also if anyone has a vagcom for sale or lives in portland oregon and wants to help me out that be great, or ill buy one if anyone has one.
    Dec 19 2011
    could it be a kill switch???? i know i accidently turned it on in my car once and was baffled for a few min why it wouldnt start lol
    Mar 12 2007
    01 S4
    3v0m
    Dec 21 2011
    Portland/Oregon/USA
    where is the cut off switch located? i didnt install one, is there one that comes from factory?
    Stage 2 Banner Advertiser Two Rings Sales@EPL's Avatar
    Jun 23 2011
    Nope, unless the previous owner installed one.
    When I ran into a similar issue on my S4, it ended up being the crank position sensor/engine speed sensor. Although I haven't personally seen this, it could also be a bad coolant temp sensor as other members have reported that being the culprit of their no-start issues. I'm not a fan of blindly replacing parts, but the CTS is only a few bucks and a relatively simple DIY. Part number 059 919 501A.
    My CTS has gone bad as well, but I never caused my car to not start. However, neither my CTS or my crank position sensor threw codes when they failed.
    European Performance Labs
    (203-345-6499)
    Sales@eplabs.net
    http://www.facebook.com/EPLabs
    Please feel free to contact us with any questions!!
    Senior Member Two Rings schusters4's Avatar
    Dec 13 2007
    Portland
    What kind of ecu tune does it have? Is it possible that the "kill" program was accidentally selected? It seems as though if there were an issue with the engine turning over...... There would be a code associated with it. GL
    Dec 13 2007
    Portland
    Trailer it to Matrix and be done with this thread.....
    Jan 06 2012
    California
    OH my APR tune had a anti theft mode that left me trailering my car home.. Turned out I had to enter my code and she started up..
    Is your check engine light flashing, and the EPS light on?
    If it is it will crank forever but never start.. at least mine did anyways..
    Feb 23 2010
    state college pa
    does the engine sound like its cranking faster than it should? This happened to my buddy. Prev owner faked receipts for the tbelt. snapped trying to turn it over at 140k.
