Results 1 to 2 of 2
Thread: Sam's B6 A4
    Active Member Two Rings Sam091990's Avatar
    Dec 22 2011
    Burbank, IL
    Sam's B6 A4
    2005 Audi A4 1.8T Quattro 6MT Black/Black (Bought on 12/22/2011 with 60,288 miles)
    Maintenance
    - Glove box hinge repaired (12/25/2011 - 60,2xx)
    - Replaced wipe blades (12/29/2011 - 60,2xx)
    - Replaced all exterior light bulbs (01/05/2012 - 60,2xx)
    - Replaced front pads and rotors (01/05/2012 - 60,2xx)
    - Replaced rear pads and rotors (01/05/2012 - 60,2xx)
    - Replaced air filter (01/05/2012 - 60,2xx)
    - Replaced cabin filter (01/05/2012 - 60,2xx)
    - Changed oil and filter (01/10/2012 - 60,2xx)
    - Replaced fuel filter (01/10/2012 - 60,2xx)
    - Programmed key fob (01/10/2012 - 60,2xx)
    - Performed brake fluid flush (01/11/2012 - 60,2xx)
    - Performed fuel injection service (01/11/2012 - 60,2xx)
    - Cleaned throttle body (01/11/2012 - 60,2xx)
    - Replaced spark plugs (01/11/2012 - 60,2xx)
    - Replaced all four tires (01/17/2012 - 60,3xx)
    - Replaced valve cover gasket (02/01/2012 - 60,7xx)
    - Replaced cam adjuster seals (02/01/2012 - 60,7xx)
    - Replaced drive belt (02/03/2012 - 60,7xx)
    Performance
    - Installed Magnaflow mufflers (04/06/2012 - 62,4xx)
    Suspension
    Interior
    - XM module installed (12/29/2011 - 60,2xx)
    - Installed LED's for all light bulbs (01/05/2012 - 60,2xx)
    Exterior
    Engine Oil: Castrol Synthetic, OEM VW/Audi
    Tires: 245/45/17 Yokohama AVID ENVigor
    05 Audi A4 1.8T (Quattro, 6MT, Black/Black)
    "This has to be the worst example of American-German collaboration since a chap called Adolphus Busch arrived in the States, tasted the water and thought: 'Mmmm, I could make beer out of this'". And we ended up with that headache in a can called Budweiser." - Jeremy Clarkson (Top Gear) on Chrysler Crossfire
    Dec 22 2011
    Burbank, IL
    Some first photos when I got the car.
