Results 1 to 7 of 7
Thread: Almost done!!!
    Active Member Two Rings Short4Law's Avatar
    May 25 2009
    Jacksonville, FL
    Almost done!!!
    Just a few more things to finish and a few things to figure out and she is back on the road.
    Got a vacuum line I can't find a home for. ( hard line coming from a valve just under the drivers side on the intake. Has a rubber fitting on the end.
    Start back ok my intercooler install. The ones I had made are
    Also have to figure out the best way to bleed the clutch... ??
    Tapatalkin that ass...
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    2001.5 s4, 2001 porsche 911 996
    near the abs module, youll find the connecter for it
    Stage 3 2001.5 Silver S4
    | RS4 K04's | ASP | SSAC | AWE | Darintake | EV14 | Forge | Southbend | 034 | JHM | Fidanza | Avic | DuH | 10SecS4 |
    Need your transmission rebuilt around the Tri State area? PM me
    Audizine IRC Chat
    buy my Porsche 911, you know you wanna.
    May 25 2009
    Jacksonville, FL
    Thanks. I'll check it out when I get to the shop tomorrow.
    Senior Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    did you stick with the k04's?
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    May 25 2009
    Jacksonville, FL
    Yes!!
    Found that vacuum line! Also found another homeless plug..
    Intercoolers are in..
    Just gotta bleed that clutch.
    May 25 2009
    Jacksonville, FL
    So what was that vacuum line that plugged in by the abs.. cuz I broke it..?? Need to find one. Lol.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    brown plug looks like fans/fan module
    Nogaro 01 s43.0L GT28rsfinally pounding pavementVAST300/360 untuned 13psi
