Results 1 to 19 of 19
    Veteran Member Four Rings Rhynolite's Avatar
    Sep 11 2007
    Whitish milkshake substance on oil cap
    Hey guys,
    Girlfriend's got an 07 2.0T with 51k miles on it. Recently coolant warning light has come on multiple times, checked coolant, level is fine, maybe a minor slow leak (couple of dried droplets visible on the AC lines running underneath). The warning goes off after a few minutes of driving, but this isn't really what I'm worried about.
    Got back from Coffee Bean this morning and it was making some strange noises, so I poked around the engine bay. Coolant was still fine, checked oil, little low but not at the minimum, but upon taking off the oil cap I noticed this (upper rightish part of the cap mainly):
    Any ideas on what could cause this? I believe this is coolant and oil mixing but I wanted to verify this before I start investigating further.
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    It could also be moisture collecting in there due to a bad PCV
    New Build, 2010 Tiguan. Details to com
    Established Member Two Rings Longfist86's Avatar
    Nov 01 2008
    08 MkV GTI, 09 Jetta
    Dade county
    looks like a coolant/oil mixture to me... could be mixing at the oil cooler, Ive seen this happen on VW's and Audi at the shop.
    GERMAN CAR DEPOT
    2130 Fillmore St.
    Hollywood, FL 33020
    954-921-1515
    www.GermanCarDepot.com is your dealer alternative.
    Dec 29 2011
    Milwaukee
    Most likely moisture build up. Happens when you take lots of short trips in the cold. Engine doesn't get warmed up enough.
    Senior Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2012 Audi A3, 2006 Audi A3, 2017 Touareg, 86 VFR 750
    Bergen Co. NJ USA
    Condensation mixed with oil on the cap, looks like sludge.
    It's a common occurrence here in the NE, I just wipe it off.
    If you see that same crap on the dip stick, or in the coolant reservoir get it looked at.
    Established Member Two Rings Countryboy's Avatar
    Jun 05 2011
    2010 Toyota Tundra SR5 CrewMax 5.7L V8
    Edenton, NC
    Another vote for moisture. No biggie. Wipe it off.
    2012 Glacier White A4 Prestige 6MT, Sport Package, S line Plus, Debadged, Tint
    Sep 11 2007
    Thanks for the replies everyone! I wiped it off and will be keeping an eye on it, hoping that it doesn't show up on the dipstick.
    Hopefully her car's gonna be going through some changes here in the next couple of months, getting a chip/drop/wheels etc. so I'll take some pics and post up the progress
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    I believe this is by definition, santorum.
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Feb 05 2011
    B5 a4 avant, b7 a4 avant
    phila/PA/Northeast
    I started up my car on one of these cold winter days after it had been sitting for a few weeks and Car sputtered and check engine flashed too, but then it seemed to be ok. I had the same thing after that under the oil. Hoping its just moisture build up too.
    Aug 24 2011
    Lauderhill, Florida
    Is the car overheating that look like a signs of oil n water or coolant mixture, which can mean blown head gasket or going head gasket... And smoke from tail pipe
    Sep 11 2007
    Quote Originally Posted by B708blk View Post
    I agree it looks like the two mixing, but I'm hoping not. 50k service was just done so I'll see if the milkshake conjures itself again.
    Jul 21 2011
    FtC COlorado
    This happens on quite a few fsi I have encountered. Honestly, I was a little panicked when i first discovered this milky stuff on and under my oil cap. It reminded me of when I blew up my Acura legend with NOS. Now I am not so worried because it goes away in the warmer months here in Colorado.
    With much thought, I want to believe it is extra moisture (obviously) in the engine from the built in oil seperator that works with the PCV valve. Although I have even seen a slight residue of the emulsion on my dipstick, I am not worried and I am sure it is not coolant unless the car makes its own coolant. The coolant bottle has only dropped about 2-3mm in a couple years.
    Most likely your car is fine.
    Jan 25 2010
    1986 VW Quantum Syncro Wagon, 1987 VW Scirocco 16V, 1982 VW Quantum Coupe 2.0T FSI Project
    Woods Hole, MA
    Quote Originally Posted by agkellyboy View Post
    Nice.
    Apr 10 2012
    Virginia Beach, VA
    If it's just on the cap and you don't see the mixture in the rest of the oil or in the coolant it's just the moisture which has been the same thing reported on these types of engines since like 2005-2006 when the 2.0T first started seeing lots of use. No worries just proceed as usual unless you start seeing other bad symptoms.
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Before you even think about head gaskets, take the car out on a trip drive it atleast 30-40 miles. The longer the better. If it goes away, good.
    My guess is this is from short trips like stated previously. Your oil is not getting hot enough to boil out the moisture and what not. Drive the car hard and long for a while.
    Sent from my iPhone.
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    moisture unless its on the dipstick too. santorum buildup if the engine/car has been engaging in anizzal sizzex. mmmm frothy discharge....
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jan 02 2013
    08 A4, 07 Ram Diesel, 96 Cobra, 06 R1, 05 R6
    my old vr6 used to have that same sludge on the oil cap. I always wondered what the sludge was but the car ran like a champ. I drove about 60k without any issues and then sold it with 190 on the odo
    Registered Member One Ring Zolly014's Avatar
    Aug 26 2010
    03 Allroad 2.7t Auto, 97 Jetta GLX, 01 Chevrolet 2500 Base w/ HD grade suspension 2WD (Work Truck)
    Ephrata
    I'v been seeing this alot lately under my oil cap as well. what with it being 19 degrees in Pa as of all but today (53+). I did see some on the end of my dipstick but I wiped it away, waited a day and went with the daily routine of work and errands, nothing to report as of today. Looks like I'll rechecking the PCV lines. Thanks for the info everyone.
    I dreamt I killed all the douchebag guys with mad swag and all their duckface girlfriends..... I realized i had a dream about the yolocaust
    Oct 15 2008
    Dayton, Ohio
    I've had this recently too, however mine(only on two occations) has been pouring excessive white smoke out of the exhaust after about 10-15 mins of warming up. I'm praying its not my turbo :/
