Results 1 to 11 of 11
    Active Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Weird boost issue?
    So for the past few months, i have been having almost a fluttering while under boost. I can be just cruising around in 4th or 5th, and then mash on the pedal, and all i get is a fluttering of my boost from between 6psi and then back to around 15psi. I have no codes, so i have no clue what to check.
    I was thinking it is my diverter valve, but i was told it isn't. My mods are ebay tp, air box mod, Giac flash, rac tech fmic, 710n, and thats it. My car is a 99 1.8t aeb. I read that it could be the gapping of the spark plugs, messed up maf, over boost, or a boost leak. So, i do not have any codes, so where should i start? Any other things i should check? It is a little bit frustrating when you are trying to accelerate and you get pretty much nothing.
    Thanks in advance.
    chris.
    Senior Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    Built A4, 08 Charger R/T
    Detroit Metro Area
    I'd start with a boost leak test and change the plugs with BKR7E gapped to .026 to .028 (about $2 a plug). You really shouldn't be mashing on the gas in low RPM while in high gear.
    B5 Casa A4 with a built motor that isn't in the car and a PTE 6262 BB .83 A/R that going sing lag city b*tch lag lag city b*tch.
    Jan 02 2011
    I will check for leaks later, everything on my boost gauge seems right, 20psi of vac, and 16psi boost.
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    Does in consistently go 6-15-6-15...? If so, that is sign of a bad N75.
    If not, it is most likely a boost leak.
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    Jan 02 2011
    Yea, it is pretty consistent on the drops, when it happens. It doesn't occur often, but when it does its annoying. I am going out in a few, so i will verify the drops, i was thinking o getting a n75j anyway
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    98.5 1.8TQM Sport
    Columbia, SC
    I use BKR6E's gapped to .028.
    the BKR7E's are a higher heat range and can foul quicker on a stock-mild engine.
    This sounds exactly like what I get when I need to replace my plugs. If one has misfired severly enough, re-gapping may not help, as the spark has started leaking through the insulator.
    A set of plugs is cheap insurance before you start fault tracing to the moon.
    http://img380.imageshack.us/img380/7320/sigswhf6.gif
    Parting out 99 A4. PM me for info
    Mika GTRS 440cc file FS
    Low mileage AEB head FS
    Evil Black Rifle Owner
    Oct 17 2004
    98.5 1.8TQM Sport
    Columbia, SC
    Quote Originally Posted by Turbo Nerd View Post
    This is one of the best ways to find faults in your secondary ignition circuit that would otherwise be hidden by normal driving.
    I do this routinely to check for misfires under heavy load, and in a properly functioning car, should not cause any issues.
    Jan 02 2011
    Well i checked for boost leaks and found nothing major. I have yet the check my spark plugs, but they are fairly new, i just got them like maybe 2k miles ago. I also run BKR6E's, and they were gapped to .028.
    Oct 17 2004
    98.5 1.8TQM Sport
    Columbia, SC
    Quote Originally Posted by Turbwhistle View Post
    I would check them regardless of age. I never let an outside issue affect my fault tracing. It can lead you away from obvious solutions.
    It could be a coilpack as well.
    Active Member Two Rings MadAudi's Avatar
    Jan 20 2011
    Bicycle
    Downers Grove IL
    Sounds like an N75 valve. It will not always throw a code for this kind of behavior.
    HOWEVER, I have seen the waste-gate *door* start to come loose on these turbo's and cause the behavior your are showing. You have to pull the down pipe to check. Sometimes you can just weld it back on and your set. Otherwise you need to change your exhaust housing.
    -Adam (Formally Koselowiec)
    1995 Audi S6 Plus
    ASE Master Certified
    Subaru Certified Specialist
    European Service Tech
    *VAG-COM Equipped* PM For Audi/VW Repair and Diagnostics!
    *BMW CarSoft Equipped* PM for BMW Repair and Diagnostics!
    Jan 02 2011
    Yea, i will end up picking up a new n75 eventually, its not to big of a deal currently.
