Results 1 to 12 of 12
    Stage 3 Forum Advertiser Three Rings
    Aug 24 2010
    Cary NC
    BFI - SPC B5/B6/B7 Audi Adjustable Upper Control Arms
    Get your camber back to normal with these adjustable control arms.
    Cast construction give these as close to an OEM fit as possible. By far the nicest on the market. Sold as two pairs to replace all needed in the front of your B5 / B6 / B7 vehicle.
    Click Image to Purchase
    Instructional Video Here
    Senior Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Guess I know which one I'm going with! Looks great! Bushings are the same as factory correct?
    Active Member Two Rings QuattroTi's Avatar
    Aug 21 2011
    Yamaha 50th Anniversary R6
    South Florida
    Modifying the strut tower is required on the b6/b7 platform in order for these to work properly.
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    I watched the video and it shows modification to the upper strut housing. Did I miss where you need to modify the strut tower?
    Aug 21 2011
    South Florida
    The current video on their website is on the B8. Their previous video was on a B7 and they HAD to grind down the strut tower. Not to say they aren't good, I actually saw them today at my local VAG performance shop and they are solid. Just giving fellow AZers a heads up; according to the B7 video it looked as if grinding wasn't done there would be metal on metal contact (between the CA and tower). It doesn't look like they have revised their design, If they have then i stand corrected.
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Thanks for the heads up! I will definitely do a bit more research before I purchase!
    Active Member Two Rings toshi0990's Avatar
    Dec 02 2009
    honolulu,hi
    I have these control arms and I did the install myself I did have to grind the mount a little bit I ended up using a cut off wheel to modify it the area that needs to be grinded is pretty thick so the small amount of grinding shouldn't be a problem in the future. While doing it I had an Audi tech watching and he didn't see any problems with grinding it.
    Black 2006 A4 S-LINE,Nuespeed sport springs w/B5 caps VMR 710, E-code test pipe with custom exhaust with Borlas Mufflers, K&N panel filter/custom intake pipe, ADAMS rotor dimple dimple slot,VMR boost gauge, RS4 dead pedal, SPC control arms, Nuespeed snub mount, rs4 grill with filler plate
    Aug 24 2010
    Cary NC
    Yes, some grinding is required - which is illustrated in the instructional video.
    Senior Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Chicago, IL 60601
    I want these, but I really hate the idea of having to grind the mount to make these fit. You would think they could engineer the arms so the grinding would not be required, especially since other options exist that don't require it.
    Building stage: City monster.......
    Mods: Eurodyne Maestro 7 / Stasis Alcon 355mm Mono6 / 034 Billet Fuel Pump 005 / Neuspeed snub mount / RS4 rear sway / Custom Magnaflow 14581 exhaust / INA adapters with FSI coilpacks / Thor Skidplate / CF S4 blades / DTH CF Roof Spoiler / RD led lp / Smoked sidemarkers / 3k HID fogs / 35% tint / Symphony II+
    Aug 24 2010
    Cary NC
    Our New Year Promotion has ended. Thanks for everyone's orders!
    Aug 24 2010
    Cary NC
    Black Forest Industries
    Active Member Two Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Quote Originally Posted by Black Forest View Post
    PM me with BEST special price lol I want these!
