Get your camber back to normal with these adjustable control arms.
Cast construction give these as close to an OEM fit as possible. By far the nicest on the market. Sold as two pairs to replace all needed in the front of your B8 vehicle
This is nice news and good for consumers as I've heard that the Stern brand one's have been failing. What do you think is the difference between yours and Stern's?
2009 S5 Ibis White-Magma Red Interior
Loaded with stuff
What brand/model spherical bearings are being used in these? Are they Viton sealed?
SPC adjustable control arms are made using maintenance free ball joints and bushings provide factory ride, handling, and NVH performance.
We carrying SPC brand adjustable control arms. The adjusters are larger diameter (18mm) then sterns, which prevent them from bending.
I slapped these on over the weekend. Easy install and it firmed up the handling a little bit, as well as reducing some highway vibes - I'm pretty sure my stock bushings were well worn out.
Thanks BFI!
I have the vibration as well, will getting just the front control arms fix the issue?
mopsta81:"Very nice touch. You got those from bader? Wow, you have a little piece of royalty on your S5. I bet two dudes in black suits rolled up in a black quattroporte to hand deliver."
Audi S5 '09 Meteor Gray Magma Red
Mods: Euro Headlights,AWE track exhaust,AWE downpipes,BC Racing Coil-overs,20" D2 Forged VS1, Adams rotors, Black ops, Carbon Fiber Splitters and Valence,Tune, H&R Rear Sway Bar.
^ Really depends...could be an alignment issue if you're feeling vibration.
did that a few times
also checked in wheels were bent
nothing wrong there
As stated already, it depends. In my case, the factory rubber bushings on the chassis side of the arm, were toast. These arms have the same bushing, but since they're brand new they firmed up the car and got rid of some highway vibes...
