Results 1 to 8 of 8
    Active Member Two Rings vitchie's Avatar
    Nov 14 2010
    2011 Ibis White A4 2.0T
    South Africa
    Question 3-zone climate control retrofit quesions
    Hi guys
    I would be very happy if anybody can help me with these questions, I want to retrofit the 3-zone climate control head unit as well as the sensors.
    1. Do I install the unit first then take it to dealership for them to remove the component protection?
    2. Where are the passenger and rear temp sensors located and maybe part numbers if you have them on hand?
    Thanks in advance!
    2011 Ibis White A4 2.0T / Xenon / Bluetooth / Exterior Aluminium Trim /
    Mods: FRC Stage 2 Software / 3" ALB Downpipe / EuroCode HFIC Pipe / 19" R8 Reps / H&R OE Sport Springs / RS5 Rear Swaybar / Reverse Camera & iPhone GPS on OEM Screen (XCarLink) / Number Plate LED's / Chrome Exhaust Tips /
    Vag-Com Mods: Needle Sweep / Lap Timer / Ambiance Lighting / Phone Voice Control / Battery Level in MMI / ADS Switch /
    Senior Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Deluxe Sunroof Volkswagen
    Northern VA
    Quote Originally Posted by vitchie View Post
    Hi guys
    I would be very happy if anybody can help me with these questions, I want to retrofit the 3-zone climate control...
    You should do a search for DavidB8 - he has started this modification as well as other advanced mods. His site is http://www.audienthusiasts.com
    Tschüß!
    Ðave
    ____________________________________________
    2010 Brilliant Black A4 Sline • Hüper Optik • Alu Kreuz/ÜSS • Hankook V12's • 034 HiFlo Turbo Hose • EC HFC • Milltek • ST-40 BBK
    Pending: Black Grill • Höen H11 • EC Intercooler
    Wish List: New Wheels • ECodes • EC Short Shifter
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Way to extensive a retrofit for real 3 zone. You need to change the duct as well. The best alternative would be to just add ducts to the rear of the car. Sensors are located in the vents. I'm not sure that the climate controls have protection on them. You may be able to just swap them.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    Nov 14 2010
    South Africa
    Thanks David. If i just do the control head and vents without ducts eould it work without errors? Doing it mostly for cosmetic reasons, the 1 zone unit is pretty ugly!
    Sent from my turbocharged iPhone
    Dec 30 2010
    Audi A4 (B8), Suzuki Jimny 4x4 Convertible
    Germany
    Quote Originally Posted by DavidB8 View Post
    ... I'm not sure that the climate controls have protection on them. ...
    Module 08 has component protection.
    retrofitted (OEM+): tow bar, bluetooth&rSAP kit, pdc+, color dis, light&rain sensor, auto dimming mirror, highbeam assist, auto folding&dimming mirrors, charisma switch, alarm, electrical front seats (memory driver side), light package+ambient lighting+illuminated door pockets, heated rear seats, xenon incl. auto leveling+headlamp wash system, side assist, illuminated exterior door handles front+rear, LED taillights, auxiliary heater, powered rear window blinds ...
    next: we'll see
    Nov 06 2009
    I can't say for sure. I am thinking there may be an error for the actuator that's missing from within the vent. but..I honestly don't know for sure though.
    Dec 30 2010
    Germany
    ... I am thinking there may be an error for the actuator that's missing from within the vent. but..I honestly don't know for sure though.
    You'll get a lot of errors because some sensors and actuators (3-zone has 10 actuators instead of 6 used in the 1-zone unit) are missing at all and some of the actuators available are wired wrong from the point of view of the 3-zone AC.
    And no, the system won't work at all with all those errors being present:
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 C HW: 8T1 820 043 C
    Component: KLIMA 3 ZONEN H02 S001
    Revision: C123S000 Serial number: xxxxxxxx 00
    Coding: 36020000
    Shop #: WSC 25477 000 00000
    VCID: 316D729DD141
    12 Faults Found:
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    00713 - Centre Left Vent Positioning Motor (V110)
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 4973
    Count: 3428
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 4973
    Count: 3428
    00711 - Left Footwell Flap Positioning Motor (V108)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 4094
    Count: 0
    01187 - Rear Temperature Flap Positioning Motor (V137)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 3222
    Count: 0
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 3301
    Count: 0
    00714 - Centre Right Vent Positioning Motor (V111)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Voltage: 12.10 V
    Temperature: 22.0°C
    Temperature: 20.0°C
    Count: 4106
    Count: 0
    00359 - Left Front Upper Body Outlet Temperature Sensor (G385)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Temperature: 20.0°C
    Speed: 0.0 km/h
    Voltage: 12.10 V
    00360 - Right Front Upper Body Outlet Temperature Sensor (G386)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Temperature: 20.0°C
    Speed: 0.0 km/h
    Voltage: 12.10 V
    01231 - Right Footwell Vent Temperature Sensor (G262)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    Temperature: 20.0°C
    Speed: 0.0 km/h
    Voltage: 12.10 V
    03037 - Rear Temperature Selection Potentiometer (G538)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 7189 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 16:35:33
    Freeze Frame:
    ON
    Voltage: 12.10 V
    Voltage: 12.10 V
    next: we'll see
    Nov 06 2009
    Now I know for sure :)
    I thought there might be. I had a quick look to see if there was a controller that would work with the single zone and there isn't. Wasn't sure if they used the dual zone design when you have heated seats but no luck.
    Looks like a big retrofit or live with the current design..
    Nov 14 2010
    South Africa
    Wow, thanks for the info guys. Helped me a lot, almost ordered the control unit, glad I didn't! Suppose more money left for other mods then! Would love colour DIS retrofit, but that sounds really expensive!
