Four Rings
Enkei Raijin
Doc, any info on pricing, weight, availability?
Stage 2 Banner Advertiser
Four Rings
Inventory is slowly trickling in, but still very little in 5x112. 18x8.5 is initially priced at $ 233 per wheel, 18x8 at $ 225 per wheel. Enkei was "non committal" about the weights, so we'll know more once we get a better sample size to check. I'm guessing the the 19 lb. range.
Doc Horvath
The Tire Rack
800-428-8355, ext 4665
please do not PM me, but send email direct to me at Doc@TireRack.com
Support Audizine !!
Click on the Tire Rack banner ad or reference >DOC / Audizine< when ordering !
Four Rings
Nice! Is tirerack just getting the black and bright silver? or will any other finishes be available?
Four Rings
Black, Gunmetal and "Hyper"Silver are the only finshes we will stock (or can get)
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
any idea if oem center caps will fit?
Four Rings
never had any luck with Enkei making that an option.....
Doc Horvath
The Tire Rack
Support Audizine !!
Senior Member
Three Rings
Do we have official weights on these?
.:2004 DG S4 6MT:.
Clear Corners // 6000k HID Fogs & Lows // Hardwired V1 // 3M 35% Tint
Trexturk Cat-less DP's // 2.5" Magnaflow // K&N Drop-in // JHM LWCP // JHM 93 Tune
Apikol Snub & 034 Bracket // Stern Pro Mounts // 034 Street Trans. Mount // Apikol Rear Diff Mount
Four Rings
18x8 is averaging 21 lbs, 18x8.5 is 21.5 lbs.
Doc Horvath
The Tire Rack
Support Audizine !!
Senior Member
Three Rings
.:2004 DG S4 6MT:.
Four Rings
will you guys have these running any wider?
Four Rings
and any difference in concavity between the different widths?
Senior Member
Four Rings
Doc any fitment for a 2004 S4?
2012 VW Golf R Rising Blue 2-Door. | APR Carbonio Intake | APR Stage 1 ECU | ECS Tuning Clear Sidemarkers | R Mats | 19x8 TSW Nurburgring | 235/35/19 Michelin Pilot Super Sports |
2012 Volvo S60 T-6 Electric Silver/Anthracite. Stock.
Originally Posted by drew
To be honest, if you are concerned about money, a used S4 is probably a bad idea.
Four Rings
Not in 2012, more options may available Spring 2013
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
Nothing that we have measured yet. I would not expect a noticable difference the 8" and 8.5" wheels
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
Just added 18x8 ET35 in black as guaranteed fitment for your application. Sorry we missed it !
Doc Horvath
The Tire Rack
Support Audizine !!
Senior Member
Four Rings
wow these wheels are sexy
not sure if reminds of bbs or vmr
needs moar light + wide!
*Most places have 18X9.5 ET35 !! which is a sweet stance set up
FLAT Black is beautiful
APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|DW300 LPFP|145Bar Rail Valve|Meth Injection Kit|034Catch Can|Stasis Coilovers|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES|Stage 2 Southbend Clutch
Unitronic: Stage 2 HPFP
DRAKES PERFORMANCE
Four Rings
yeah. I havent seen that width on tirerack at all. Doc, any chance the 18x8.5 will be added to the b7's? I've only seen it available for the new Jettas.
Four Rings
I've had that fitment added, sorry for the oversight.
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
Four Rings
no problem! thanks Doc.
No worries, be sure to reference Audizine if ordering online !
Doc Horvath
The Tire Rack
Support Audizine !!
beautiful wheels, though i am not a fan of bigger wheels prone to damage with the rubber band tires needed for bigger diameters, pa roads can be pretty rough, i would go with a 17" setup if available, spacers can be used to push them out if necessary, although it adds cost but little weight compared to using wider wheels to get them out on my 01 TT that seems to swallow the wheels and tires like the old 60-70's cars did
Four Rings
doc, will you be carrying these in 9.5s for any 5x112 applications?
Four Rings
18X9.5 in 5-112 will be ET35 in black or silver
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
Four Rings
Centerbore of 66.6?
Wheel is bored to 72.6mm, so we'll need a centering ring like normal
Doc Horvath
The Tire Rack
Support Audizine !!
Registered Member
One Ring
what is the backspacing for the e45? will these fit with a big brake kit?
Four Rings
We'd need the PDF template to know for sure if we can clear any BBK
Doc Horvath
The Tire Rack
Support Audizine !!
Senior Member
Three Rings
Is it me or is the 18x8.5 not an option for a 2008 Audi A4 Avant 2.0T quattro S-Line Titanium Package?
Four Rings
I'll see if I can get that cleared up by Monday........
Doc Horvath
The Tire Rack
Support Audizine !!
Same, is there 18x8.5 for 2003 A4 1.8t?
Four Rings
Fitment added, sorry for the omission !
Doc Horvath
The Tire Rack
Support Audizine !!
Senior Member
Four Rings
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
– Thomas Jefferson
Is there a reason why the Enkei Raijin 18x8 ET 35 (5x112) is not shown as an option for the B8 S4 (2010+)? Other 18x8 ET35 wheels are offered.
Four Rings
Looks like the design of the wheel makes for a tight fit at ET35, so we recommend ET45 for a "safer" fit
Doc Horvath
The Tire Rack
Support Audizine !!
Tight in what way? Isn't the rubber of the tire in the same absolute place in the wheel well with any ET35 wheel? Or is there some area of the metal of the wheel that's a problem?
Four Rings
The design of the wheel (thickness and shape of spokes, location of the "drop center" on the barrel, etc can dictate fitment, so not every ET35 wheel will fit exactly the same. I had our wheel techs look at the drawings on the Raijin again and they are willing to add that wheel to the list of approved wheels for B8 with the understanding that the lower offset may cause a little rub at the fenderlip if the car is lowered (by more than 2").....
Doc Horvath
The Tire Rack
Support Audizine !!
Four Rings
how about these in a 19x8.5 with et 35??
"The important thing is not to stop questioning. -Albert Einstein"
"Treat everyone like a million bucks; and always have a plan to kill them"
2007 A4: APR, STaSIS/Alcon, VMR, Hankook, Ohlins
...they are willing to add that wheel to the list of approved wheels for B8 with the understanding that the lower offset may cause a little rub at the fenderlip if the car is lowered (by more than 2").....
So that's the tire rubbing on the front fender lining / screw?
By the way, I sent you an e-mail with a few other questions.
Reason: Adding something
Unless I missed something Enkei doesn't make them in a 19"
Four Rings
in 5x112, we will have ET42 coming late Summer for 19x8.5, but nothing else until next Spring....
Doc Horvath
The Tire Rack
Support Audizine !!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
