Stage 2 Banner Advertiser
Three Rings
Free shipping on 034 Turbo Inlet hoses @ USP Motorsports!!
034 Turbo Inlet hose - $75 + FREE SHIPPING!
OEM rubber turbo inlet boots do the job OK on a stock application, but are prone to problems once boost is turned up and performance increased.
Due to the lack of reinforcement, it's common to see the stock hose collapse under vacuum created by the turbo's suction. The OEM rubber hose is also a common area to see cracks and leaks with age, which can throw off MAF readings.
Since the 034 hose is not corrugated, and maintains a larger inside diameter than the stock hose, it flows much smoother and flows more air than the OEM hose, and its a direct fit to boot.
Click here to order
Use coupon code "usp10s " during checkout
International customers use coupon "intship2012 " during checkout for 40% off the normal shipping rate.
Four Rings
Get this, it rocks! Improves throttle response a bit and makes it a little nicer to drive.
Three Rings
Originally Posted by
Stubek
Thanks for the feedback!
Three Rings
Still in stock ready to go!
Active Member
Two Rings
Stubek
Agreed. For the price, and relative ease of install, a nice little mod.
2009 A4 Quattro, Manual, Prem Plus, Sport Package
Mods: APR Stage 1, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. Vag.com mods.
Three Rings
Still have some in stock!!
Four Rings
Stubek, let me stop by and drive your avant so I can see if I want to purchase this. Also we can do a run and compare our tunes.
-Thomas
US P CLUB MEMBER #16
B6 A4 CVT -APR Stage1+/Forge TIP/neuspeed exhaust/Eibach springs/Hyperboost DV/Ecode FMIC/B5S4 brakes/vdo boost gauge/Podi/APR snub/rs4 rear sway/
B8 A4 AVANT -REVO stage 2 (stock CAT)/DMH electric cutout/Stud conversion/Enkei 18x9.5 ET40/VMR 710 19X9.5 ET33/H&R OE Sports/
Three Rings
TCHUN003
Revo vs. APR! I would like to hear the outcome
Four Rings
Loma Linda is a bit far my friend, but if I get out that way, I will let you know. Let me know if you get up here to the Bay Area
Four Rings
Shoot, I forgot you were up north haha. I thought I read Santa Ana
-Thomas
Three Rings
Still got some more
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
