Results 1 to 24 of 24
Thread: Break issues.
    Active Member Three Rings williamr91's Avatar
    Feb 11 2011
    Vast stage 2 s4, Vast stage 2 allroad
    I've traveled some.
    Break issues.
    Good morning fellow AZ'ers today I went to leave in the allroad. It was outside last night (28 ish degree's F) and I had the parking break on, parked up the driveway (slight incline). When I went to drive and took off the E-break the light would not turn off. I then went to drive and it started to flash and beep. I drove for about a mile at slow speeds (after attempting to turn it on and off and pulling the E-break on and off a few times). The light continued flashing for about 1.5 miles. Then it turned off. Any ideas? My break pad wear indicator is on btw (its been on for a week or so).
    2002 S4 Stage II Vast
    2004 allroad 2.7 (402, Stage II Vast)
    My grandma's 186. I'd like to connect (and verify!) If you understand that pm me.
    Senior Member Three Rings Black3.2's Avatar
    Jun 02 2009
    B7 S4, B6 S4
    Atlanta
    I hate when my breaks wear out, they are never long enough. On a side note i have no idea why your BRAKE light was flashing, never heard of that before. Just messing with you, i could not pass it up. Hope you find out what the issues was.
    Active Member Two Rings G0to60's Avatar
    Oct 25 2011
    90 Corrado, 02 allroad
    Milwuakie, OR
    I'm not sure if it's a problem with Audi's but on my Corrado I had the e-brake cable freeze up and stick on in the winter time. Water had gotten into the sheath somehow and had become frozen. The fix was not use the e-brake until spring when I could replace the cables.
    Also, I don't believe that the rear brake pads have wear sensors. Only the fronts.
    Senior Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    Might be your ABS control module.Do a scan.
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    Usually when the word BRAKE appears on the dash, it is low brake fluid. Low pads have a different warning light, which looks like this (O).
    Feb 11 2011
    I've traveled some.
    I know the rears don't have sensors, those are only about 10k old any how. The (o) I know is the pad, that error has been on for a week or so. The "break" light was flashing, I am assuming it is just the line frozen or something as the fluid is good. I really hope it's not the ABS I'll run Vag on it. Thanks guys!
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf
    Ontario, Canada
    I had this problem, but the hand brake icon would stay on,
    after checking my car, I was low of brake fluid, but during this I have learn much about this problem, I had to fix my rear calipers
    the hand brake icon is connected to two sensor devices, one is brake light switch which is located where your brake pedal is and hand brake sensor located in the hand brake area linked to cables which connect to rear calipers,
    if your pedal sensor is good, then it leads to hand brake sensor, I suspected that possibly your rear calipers or cables are slowly seizing, and slowly they return to disengaged position which is possibly why when you drive the hand brake icon on dash disappears.
    Cluster Repair Solutions: www.pixelfix.info
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Active Member Two Rings Audi_Tech's Avatar
    Sep 21 2007
    C5 S6 Avant, 00 boosted Civc Si (FOR SALE!!!), 85 MR2, 00 ZX-12R, 85 C10, 07 Acura TL Type S
    Greenville, NC
    Quote Originally Posted by williamr91 View Post
    Brake fluid reservoir level is low due to pads wearing out. As the fluid warms up from driving it expands and the fluid level rises to the minimum mark on your reservoir and the light goes out.
    Oct 11 2011
    Kawasaki Ninja
    Bountiful, UT
    ^ +1. Replace your pads, turn the rotors, then check your fluid level. Your problem should be solved.
    Feb 11 2011
    I've traveled some.
    ^ thanks guys great advice I didn't even think of the level fluctuation at different temps (that was stupid haha). I'm going to take care of the pad's this weekend, maybe rotors too. How many miles does one have typically after the sensor goes. I've driven about 300 miles.
    Stage 2 Banner Advertiser Two Rings
    Aug 19 2011
    1998 Audi A4, Quattro, 2.8/30v, Tip; 2001.5 VW Passat GLS, 2.8/30v, 5spd, w/Unitronic
    Groton, CT
    I believe it all depends on the type of pads, the type of driver, and how your rotors are. The thing to do is visually inspect your pads, both inside and out to see exactly how much meat you have left on the pads when the light comes on.
    Vendor Support
    Powered By Cars...Driven By People
    sales@fcpgroton.com
    FCP Euro on Facebook FCP Euro on You Tube
    Use Code "Audizine1" and save 10% off your next order!
    Oct 11 2011
    Kawasaki Ninja
    Bountiful, UT
    Agreed. Check them out visually.
    Even so, replace them ASAP because they'll be more prone to cracking and fade now-even if they're still legal. And besides, you can get some good ceramic pads and rotors; it'll be like a new car :D
    Feb 11 2011
    I've traveled some.
    So while ordering the pad's and rotors I realized their are two options for pads. They have 4, and 8 pad per side design's. With out taking off my wheel just yet how do I know which type I have, or are the interchangeable? Sorry for the noob question but please help. Btw my car is a 04' allroad 2.7 tip.
    Sep 22 2004
    Massachusetts
    You probably do not have the HP2 calipers (4-pads per caliper) but the caliper with 2 pads.
    Feb 11 2011
    I've traveled some.
    Thanks Boston, what decides the difference, the v8's v. 2.7? Or the year?
    Jul 08 2007
    Ohio
    Yes year and engine.Earlier 2.7's had hp2
    Feb 11 2011
    I've traveled some.
    Ahh that makes sense I know the earlier had S4 brakes(b5) What is hp2 though?
    Sep 22 2004
    Massachusetts
    This is the HP2 caliper, which has the 4 pads. Found on the 2.7T through 2001 (although a few 2002 2.7Ts came with them as well). My 2002 4.2 came with the HP2 calipers as well. They are a beast to find wheels to fit over them!
    My 2001 2.7T front calipers (before paint)
    ...and after paint...
    Feb 11 2011
    I've traveled some.
    ^ Looks good, so the HP2 are the brakes found on b5 S4's and such. I believe I don't have those on the allroad I know from the past I've looked at the calipers on my S4 and ar and there was a difference.
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    William91 any update on what fixed your issue? I am currently having the same problem. I have already changed my rear brake pads and it's still intermittently coming on.....TIA
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    Quote Originally Posted by bong2611 View Post
    Check your brake fluid level, mostly is low.
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Newark, Ca.
    does audi use a special brake fluid or can I just get some random brand to top it off?
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    So your Brakes are breaking?
    What happens with the rear calipers is water gets in the parking BRAKE mechanism and freezes, locking the mechanism if the parking BRAKE is left on. After the calipers heat up the water melts and it's all good.
    Also check your fluid, the low BRAKE fluid light uses the same indicator as the parking BRAKE.
    Feb 11 2011
    I've traveled some.
    Sorry man I didn't even look at this thread since my last post. I still haven't taken care of these issues. I bought the rotors and pads but haven't had them installed. My s4's rears went out and the calipers where shot so that was higher on the get it done list. Now the allroad is just waiting. On a side note, I installed a H-Sport rear sway bar on the ar and it handles much better. I haven't drove very much with the brake issues so no worries there.
