    Sep 21 2008
    05 B6 Sedan; 04 B6 Avant
    Derry, NH
    Urgent Help needed pls. Anyone with VAG-COM near Derry NH
    Hi!
    My wife's '05 B6 started flashing CEL and very rough engine.
    Is someone close to Derry NH willing to lend a VAG-COM? I'd owe you lunch or beers.
    Thanks
    2oo5 B6 Sedan Q | Dolphin Gray | SE | Platinum interior | 1.8T | Tiptronic
    2oo4 B6 Avant Q | Silver | Platinum interior | 1.8T | Tiptronic
    May 21 2007
    07 A4 Ibis White/S-line/Ti/2.0T Q
    Northshore, MA
    flashing check engine light means there is a severe misfire. seeing how it is a 1.8t, ide say more than likely the coilpacks need to be replaced. Could also be spark plugs if you havnt changed them in a long time. Those are the two most common. Coilpacks are about $25-30 each at the dealer, and VERY simple to replace. a way you can test this is to start the car and just pull the coilpack up off the plug. if the engine starts to stutter more, that coilpack is still ok. If engine does not change, that coilpack is bad. Personally ide just replace all 4 anyway. if ones gone the others arnt far behind.
    -Nate
    07 Ibis White A4 S-Line Ti Package
    GTRS'd 04 6SPD 1.8T A4 Quattro SOLD
    http://www.cardomain.com/ride/3037832
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    PM me with youre H&R Parts needs!
    Sep 21 2008
    Derry, NH
    Thanks doublezero30. I just changed the plugs and no change.
    I'm going to pull all the coilpacks off my wife's A4 and replace it with coilpacks from my Avant {I know mine works perfectly} :)
    Fingers crossed that'll be it.
    Sep 21 2008
    Derry, NH
    Oh well ........... it's not the CP. I switched all 4 and still very rough idle. CEL is now solid and not flashing.
    Guess need to get it towed.
    May 21 2007
    Northshore, MA
    ah damn, unfortionatly i dont own vagcom. sorry man. if the light turned solid, maybe there was more than one issue? hope its not a big deal
    -Nate
