Results 1 to 15 of 15
    Sep 28 2009
    texas
    4.2L s-flo install
    So I installed mine tonight. It is straight forward. The only tip I have for you all is when you disconnect the 2 hoses, one hose is very easy and the other requires some heavy pulling. There is a plastic tab around it and I couldn't figure out if you were supposed to lift the tab up with a flat head or just pull hard so I lifted it up and broke it apart and only 1/2 remained. Oops. When I went to reinstall it, even with 1/2 tab missing, it was very well secured onto the S-Flo tube. The tab is built for retention, but if you break it, it doesn't appear to be the end of the world. Also don't be like me and drop a torque screw head somewhere into the engine bay and not be able to find it.
    Since it's only 8 hp to the wheel, I couldn't tell any difference. But I had to buy it.
    Now if only JHM will release the s5 ECU from beta!
    700 HP in garage:
    2009 Audi S5 | Miltek non-resonated | kw coil overs | e-codes | AWE S-Flo | Valentine 1 stealth mounted | Laser Interceptor | HID fogs
    2004 Audi S4 Avant with blown engine
    Active Member Four Rings ecrew16's Avatar
    Oct 08 2010
    Audi S5, MKIII Golf Trek
    Granite Bay, CA
    Cool cool. Any pictures of it? You did not notice any difference when driving?
    '08 S5 :: Ibis White
    Build Thread
    _________
    DD: MK4 VW Golf
    Previous: '08 A5 - Matte Gray
    Like ActivFilms on Facebook!
    flickr
    Sep 28 2009
    texas
    Well, I think I can feel something, but I can't tell for sure, so that means it must be negligible in real life. btw, you can't see the hoses in this picture; they are under the plastic cover.
    700 HP in garage:
    Active Member Three Rings motorsports916's Avatar
    Nov 01 2010
    D3 S8/ B6 A4/ BMW E46/ BMW E60/ 55 BEL AIR/ 68 CAMARO/ WRANGLER TJ
    Granite Bay/ CA/ USA
    Nice...
    On JHM releasing the tune, might be a minute. They test things VERY heavy before they release it to the public. Being part of the beta team for the b6 3.0 platform, I can tell you it takes patience. And alot of showed intrest. But in the end, their product is high above any others.
    Best of luck
    B6 3.Ohhh-- JHM ECU & TCU TUNE¦Intake Manifold Spacers¦ Gutted Cats¦Remus Exhaust¦ H&R Sports¦ BFGoodrich
    May 27 2011
    Same as it always was
    Quote Originally Posted by motorsports916 View Post
    Nice...
    Best of luck
    Having an APR tune in my '11 S5 and having done some tuning on my corvette '07 Z06 with HPTuners and understanding how it works, what other parameters do you touch that an APR tune doesn't? just curious.
    In, Out and Around...
    there is a GIAC tune available for the s5, i am getting it this week.
    Nov 01 2010
    I am not affliated with JHM, just run some things for them and was first on the b6 3.0 platform.
    However, from what I know, they touch over 200 items for their tunes. I cant speak for APR, but I do know JHM goes through a lot more then competitors. I as well have a corvette motor in a car, and spent hours with a tuner from GM. The audi formatting is so much more complex then that tho. :(
    And from what I hear about the GIAC tune, might just want to save your money for a little while. IMO tho, you s5 guys know your cars alot better!
    what do you 'hear' about it?
    Nov 01 2010
    That it is more like your typical tune. Timing advance, pedal responese, etc.
    edit: Post number two is kinda my point- http://www.audizine.com/forum/showth...ith-a-JHM-tune
    JHM touches pretty much everything. I am by no means knocking anyone or any tune. I can just speak from seeing JHM work first hand on b6/b7 3.0, and 4.2 motors
    May 27 2011
    Thanks. Where is JHM located? I'm not excited about sending the ECU in for a tune. I found a street tune was the best way to tune a car, under actual driving conditions. Log your driving and tune according to what the computer is saying. A tune can be affected by air density, humidity and altitude. Also, without some bolt-on's, you aren't going to get much I wouldn't think. But then again, the ECU as you mentioned sounds more complex than the GM ECU. For example, on the corvette, timing was pulled as much as 10* when the IAT was hot. You could change the amount of timing that was pulled and that had an affect in performance. Anyway, I thought you might be more involved with the actual parameters that they changed.
    Nov 01 2010
    For sure man. I hope the best for yoiu guys! Like to see all the N/A stuff out there.
    JHM is in Lathrop, Ca. We had a guy on the 3.0 side from Miami send his ECU in, and 2.5 days later had it back!
    Oct 03 2009
    SLC, Utah
    I have GIAC tune its shit.
    Deep Sea Blue S5| Pearl white interior| 19 " Forgestar F14| AWE downpipes| AWE non-res catback| KW V1 coils | H&R DRA 20/25 | GIAC tune| Llumar 20%| vag-com
    do you have anything else or just the tune alone?
    Oct 03 2009
    SLC, Utah
    awe downpipes and cat back, which I noticed little gains. Also forgestar F14s noticed a little bit quicker when i dropped 5lbs per corner in each wheel. But 0 from the GIAC
    odd, i noticed a difference after i put on a few miles and it adapted to my driving... where i had flat spots before i no longer do and now there is a bit more pull 4200-5500 area. nothing like a FI tune but i wasnt expecting anything like that i just want to eliminate the delays and flat spots that came from the factory.
