Results 1 to 3 of 3
    Senior Member Three Rings drjonez's Avatar
    Oct 27 2009
    2003 A4 Avant 1.8tQ0A3, '72 Nova
    The Cheese State
    B6 S4 Rear Brake Install
    Not that this is rocket science, but here are some notes on putting B6 S4 rear brakes on an 2003 1.8T A4.
    First, note the difference in rotor and pad size (yes, it is an iPhone pic and is therefore crappy):
    The parts you'll need:
    1. S4 rotors
    2. S4 calipers
    3. S4 pads
    4. S4 caliper carriers
    Everything bolts up just fine, the lines are the same. There are just a few sticking points:
    1. The S4 dust shields won't bolt up- they have 4 mounting holes and the 1.8T rear knuckle only has 3, 2 are in the wrong place and there's not area to drill and tap new holes. You could drill one hole in the S4 dust shield and have it attached by two bolts, I didn't think it was a good idea given its size/mass. The good news is the 1.8T dust shields can be massaged to clear the rotor and provide some shielding, just not the "wrap-around" that the OEM ones have. You will have to trim a bit off of the 1.8T dust shield for caliper carrier clearance.
    2. The ebrake cable housing will be a bit tight given the longer distance it needs to travel to the caliper. You can get a bit of slack by moving the cable/housings on their hangers, enough to make it work. I haven't checked ETKA yet to see if a different cable is called out between the A4 and S4.
    3. You can't rock 15s anymore. The S4 setup barely fits inside my 16" winter wheels.
    '03 A4 Avant 1.8tQ0A3
    Function > Form
    Forum Moderator Four Rings kristokes's Avatar
    Jan 03 2007
    NNJ
    Thanks for the write-up
    Stokes|Moderator - PM me with any questions/concerns
    [ 2007 ] SLOWHTE
    [ 2005 ] RAVEN R1
    [ 2001 ] TT COUPE
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    This is the original thread with a lot more information: http://www.audizine.com/forum/showthread.php/421215
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
