Results 1 to 20 of 20
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    Full STG III BW K04 Build
    OK guys, I put my full blown 2.8 770 build on the back burner for a future project, and decided to go full stage III on the A6. I was able to pick up the turbos and fueling kit from EPL at a good price. Now I gotta piece together a few more RS4 components and I should be ready for engine removal. Here are a few pics of what I have to date.
    OEM RS4 inlets
    STG III fueling kit
    EPL 85mm MAF
    NGK BKR7E Spark Plugs
    Bosch EV14 52lb Injectors
    and most important, the BW K04's
    I would love to hear comments/suggestions for this build, keep in mind it is my DD and I want to keep it as comfortable and reliable as possible.
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Stage 2 Banner Advertiser Two Rings SALES@RS WORX's Avatar
    Oct 03 2011
    New Jersey
    Greg, Good luck with the build bud. It was nice meeting you the other day. Let me know if there is anything else i can help you out with. I would recommend aquamist! We have them in stock and on sale with 10% off.
    Have a Happy Thanksgiving.
    Cheers
    .:Redline Speed Worx:.
    Tri-State's Premier APR Installation Center
    German Automotive Repair, Performance & Fabrication
    908.223.7477
    Apr 18 2007
    Thanks Ryan, it was nice meeting you too. I'll let you know when I'm ready to pick up the Meth kit. Happy Thanksgiving to you too!
    Greg
    C5UNION
    Apr 18 2007
    Got a few parts in today.
    Some RS4 love
    One of the ER shrouds
    Greg
    C5UNION
    Apr 18 2007
    I got a lot of work done today. Removing the lock carrier was not as hard as I thought, here are some pics of my progress. I'm also currently waiting for my 034 DP's with test pipes, Spec stg3+, OEM DM flywheel, and some other misc. hardware. I should have the engine out within the next week.
    This is how I started out today:
    Fan removed and put to the side:
    Draining the coolant was also really easy:
    Lock Carrier off:
    Intercoolers and piping out of the way:
    Very interesting, I didn't know the trans cooler was behind the DS intercooler. No need for that anymore:
    Greg
    C5UNION
    Apr 18 2007
    So I got a nice package from UPS yesterday. Finally got my 034 DP's, poly snub mount and cage, 034 track motor mounts, turbo mounting hardware, and SAI delete plates. All I have to say is that these DP's are of amazing quality and construction, I will definitely continue doing business with 034 on future builds. Now I'm waiting for the clutch and flywheel from EPL, and the I have to order a timing belt kit and bunch of seals so I can do everything with the motor and trans out. Here are some pics of what I got from 034.
    I also decided to remove my spare block from the engine stand so I can get it ready for my engine:
    This made block removal from the engine stand a breeze, I'll also be using this hoist for transmission separation when the motor is out:
    034 goodies:
    Bye Bye SAI:
    Greg
    C5UNION
    Active Member Three Rings Danza's Avatar
    Jun 28 2010
    PAX River, MD
    looks like good stuff
    -Ian
    Apr 18 2007
    Getting closer, drained the oil today so I can get the AC compressor and lines out of the way but I ran into a snag when I didn't have a big enough socket to remove the oil cooler (does anyone know the size?). Since I couldn't do anything about the compressor I just decided to start clearing the top of the motor, SAI pump and hoses are now gone and for sale. I'm surprised how much space the SAI takes up in the back of the motor, good riddens.
    Greg
    C5UNION
    Active Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 Silver S4 , 03 Grey Passat
    Waukesha Wisconsin
    What are you doing for a clutch?
    Sure it's a Stage 3 S4
    I BUY IPHONES
    Looking for White Armrest, Catalytics, 15mm Spacers, Rubber Mats, 18Z Brakes, Sidemounts, Aquamist, Fuse Cover, Rear View Mirror
    Apr 18 2007
    Spec stg3+ and stock DM flywheel, should be in by the end of the week from EPL.
    Greg
    C5UNION
    Apr 18 2007
    Got some work work done yesterday and today.
    Got the AC compressor detached, just held up with a zip tie until the motor comes ou:
    Disconnected the engine ground and peeled back the positive battery wire as well:
    Removed the ECU and accompanying wires, was easier than I expected:
    Greg
    C5UNION
    Apr 18 2007
    Finally pulled the motor/trans on Saturday all by my damn self, I started around 2:30 and motor was out by about 6:00. Other than having to remove the PS axle and down pipes it was pretty straight forward. It did wear me out though, which is why I'm posting this a few days later. Here are some pictures, didn't take too many as I was by myself .
    Trans bolts in order from top to bottom.
    This is how she sits until I remove the clutch and flywheel so it can fit on the engine stand.
    Greg
    C5UNION
    Apr 18 2007
    Finally got the engine on the stand after a week of trying to remove the last three flywheel bolts, I had to resort to cutting them off. I can finally get to swapping out parts, cleaning the engine bay, and going stg 3 already.
    Greg
    C5UNION
    Apr 18 2007
    Started doing some tear down work today, removed and broke the Spyder hose, all of the SAI system, and some other lines connected to the fuel rail. I also got a package from ECS today with a lot of good stuff. Next is removing the turbos and associated lines, gonna try and start that tomorrow. Here are some pics for your enjoyment.
    ECS goodies
    Removing SAI
    A lot of lines
    Peace!!!
    I need more space!
    I'm surprised at the amount of dirt all over the engine, I gotta get cleaning!
    Greg
    C5UNION
    Apr 18 2007
    Turbos are pretty much in:
    Started getting to work on the top end, fuel rail is off. I gotta make sure I blow all the crap off the top of the engine before removing the injectors, don't want anything falling in those holes.
    Greg
    C5UNION
    Apr 18 2007
    Started doing the timing service today. Swapped out the water pump and thermostat. Next I have to pull the cams and do the rest of the seals. Here are some update pics.
    Greg
    C5UNION
    Apr 18 2007
    Progress, progress, progress, finally looking like a finished engine again. I finished all the seals up top and painted the valve covers flat red. Turbos and lines are completely installed, here are some update (iPhone) pics.
    Greg
    C5UNION
    Apr 18 2007
    Some updated pics I took today:
    Greg
    C5UNION
    Senior Member Three Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and an old benz
    Harrisburg, PA
    looks good man
    Apr 18 2007
    Thanks yesmar, Wrapped the Dp's with some DEI titanium wrap, and got the er's ready.
    Greg
    C5UNION
