Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 165
  1. #121
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    01 allroad, 01.5 A4 TQM
    Bellingham, WA
    Yay.
    -Matt-
    B5 S4, C5 A6 Moderator
    Murdered out and coilovered 2001 allroad stage 2+ on a diet
    2871r'd 2001 A4 1.8t - powered by 034 Motorsport - Build thread
    Low cars are faster than high cars. It's science. -8520
  2. #122
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Great news Greg..
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
  3. #123
    Veteran Member Three Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    So what's the good news Greg.
    Sick 6s C5 Enthusiast
  4. #124
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    There's good news and bad news. The good news is I got the car started and it sounds sick, the bad news is I can't get it into gear so I think there is an issue with the flywheel bolts. I gotta think of how I'm gonna get this done now. Here's a quick video of the first startup.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    Greg
    C5UNION
  5. #125
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    Flywheel bolts doesn't make sense Greg. If that were the case the engine wouldn't turn over as they would jam on the rear main seal. I would be looking at the slave cylinder positioning, making sure that you have the shift fork lined up.
    I know that doesn't sound like good news, but at least it won't require a engine/trans separation
    I don't think I care anymore
  6. #126
    Apr 18 2007
    Actually Ryan there's an issue wit the new spec stg3+ setups, using oem flywheel bolts will cause the friction disc not to fully seat onto the flywheel. I wish I knew this before installing the trans, I would've just used the bolts spec provided with the shorter head. Unfortunately it will require removal of the trans again. I'm gonna just flatbed my car to epl this week, have them finish it off.
    Greg
    C5UNION
  7. #127
    Aug 04 2007
    Wow, I stand corrected. That sure is shitty. Hopefully my spec triple disc isn't the same, because I used 33mm OEM bolts instead of 43mm OEM bolts, so the heads are the same
  8. #128
    Veteran Member Two Rings
    Nov 15 2004
    Brunswick, ME
    you sure its the bolts, I ordered my spec 3+ also from EPL at the same time as yours and used oem bolts, car shifts and drives fine. The clutch is definitely grabby and will take some getting used to, but I would hate to see you pull everything apart just to find out its not the flywheel bolts. On the same token I am going to be pissed if I have to pull mine apart. Who told you the oem bolts wont work?
  9. #129
    Apr 18 2007
    Here's a video of the clutch pedal movement. Honestly the more I think of it if there was any contact between the friction disc and flywheel bolt I'm sure I would be able to hear it. I'm gonna take vinnys advice and just give bleeding the slave another shot.
    Greg
    C5UNION
  10. #130
    Nov 15 2004
    Brunswick, ME
    clutch pedal should spring all the way back.
  11. #131
    Apr 18 2007
    Quote Originally Posted by slick50 View Post
    Would not bleeding fully cause that, or am I looking at removing the trans?
    Greg
    C5UNION
  12. #132
    Feb 06 2012
    Nice vent pod, #a6guyproblems i see.
    01.5 A6 6MT Stage 3 built bottom end on Frankenturbo F4s > JHM RS6-Rs > SRM K24s
  13. #133
    Nov 15 2004
    Brunswick, ME
    not bled
  14. #134
    Feb 07 2008
    00 stg 3 6mt a6, 91 f150 4x4 5mt, 01 4.2 A6
    Quote Originally Posted by A62TURBO View Post
    Bleeding the clutch on these cars sucks. If not fully bled, the pedal can stick to the floor easily.
    Are you sure your shifter is aligned correctly?
    -dre
    Being different means nothing if you don't have taste
    WTB: 2001 4.2 A6 Transmission code FBC
  15. #135
    Aug 04 2007
    Shifter alignment is suspect
  16. #136
    Apr 18 2007
    Quote Originally Posted by Mantis View Post
    But what would make the clutch not come up the way it should? You think I just need to bleed the shit out of it?
    Greg
    C5UNION
  17. #137
    Nov 15 2004
    Brunswick, ME
    shifter alignment has nothing to do with the pedal, but it can cause gear selection issues.
  18. #138
    Apr 18 2007
    Just got off the phone with EPL, it was actually the bolts causing the problem. They were great about getting it fixed ASAP and they have definitely got a new customer for life.
    Also, thanks a lot to vinny who kept me up to date this whole time, I owe you a lot of beer lol
    Greg
    C5UNION
  19. #139
    Nov 15 2004
    Brunswick, ME
    Ug, shitty. Now I am wondering if I need to pull mine apart to swap in the crappy SPEC hardware.....
    Glad you got it figured out though!
  20. #140
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Beer is good.
    When do they expect it to be back together?
    04 2.7T S-Line A6 6MT
    (Build Thread) <-Click
    (Featured Article) <-Click
    My Photo Gallery - MyPhotoStash.com <-Click
    Originally Posted by 8520
    You're in high school, and chipping a 2.7t is like poking the bear with a tazer.
  21. #141
    Apr 18 2007
    Vin, rich told me its pretty much back together, they need the lift ASAP so they're finishing it up quickly. I'm guessing I'll pick it up on Thursday. I'll probably hop on metro north and pick it up.
    Greg
    C5UNION
  22. #142
    Feb 07 2008
    So at that stage will it be break it in then come back to get it tuned?
    -dre
  23. #143
    Apr 18 2007
    PRetty much dre, I gotta give it atleast a good 500 miles to break in the clutch.
    Greg
    C5UNION
  24. #144
    Apr 18 2007
    Got an appointment for July 31st at EPL, can't wait to squeeze out some more power.
    Greg
    C5UNION
  25. #145
    Stage 2 Banner Advertiser Three Rings Sales@EPL's Avatar
    Jun 23 2011
    13 days and counting...
    European Performance Labs
    http://www.facebook.com/EPLabs
    (203-345-6499)
    Sales@eplabs.net
    Please feel free to contact us with any questions!! - Rich
  26. #146
    Feb 06 2012
    Quote Originally Posted by Sales@EPL View Post
    Zing! Maybe I should come by and view this vehicle. I'm down the street.
  27. #147
    Apr 18 2007
    Quote Originally Posted by aysix View Post
    Awesome, Ill be there by 9am.
    Greg
    C5UNION
  28. #148
    Apr 18 2007
    Can't wait till tomorrow morning, EPL here I come.
    Greg
    C5UNION
  29. #149
    Senior Member Two Rings ilikeaudis's Avatar
    Feb 15 2009
    Manchestrr NH
    Winning! Can't wait to see, please post videos afterwards!
    For Sale: Oem 4.2 upper and lower grilles - $100 | 0em all red c5 taillights - $100 | 4.2 rear bumber cover- $350 | Oem 4.2 sway bars|
  30. #150
    Jan 31 2010
    S-Line A6
    East Haven, CT
    I'll be at work
    Better send me a video once its strapped down!
  31. #151
    Active Member Two Rings DJPoochi's Avatar
    Jan 15 2012
    Atlanta, GA
    Any updates on this? I'm curious to see how well everything is running after the tune...
    '01 A6 2.7t, Tip-to-6 01E Swap, Piggie Pipes, Stage 1 Custom Tune.....more to come...
  32. #152
    Feb 07 2008
    Greg is loving the new power. He's out of town for a month right now though.
    -dre
  33. #153
    Jan 15 2012
    Atlanta, GA
    Awesome. I'd love finished pics / vids, and possibly a total cost in parts of this build (if that's not a problem). Looking through everything he did, I wanna go that route...although I may look to get hybrid RS6 turbos instead of the K04s.
    Awesome thread, Greg!
  34. #154
    Apr 18 2007
    I'm back from a month in Greece, and as much as I loved the trip I missed my car badly. I drove it for the first in a month today and wow what a difference in power compared to the 1.6 liter rental I had. Djpoochi, as far as the total cost I haven't really sat down and put the numbers together but if I were to guess a ballpark figure it would probably be in the $10k+ range. A lot of people would think twice about spending that kind of money on a 9 year old car but for me it was definitely worth it. Here are some pics and video.
    Greg
    C5UNION
  35. #155
    Active Member Two Rings DNDBOSSHOG1's Avatar
    Apr 28 2007
    BAY 101
    Very nice! Congrats!
  36. #156
    Jan 25 2006
    A4 2.0T
    MD
    Nice runs, car looks good.
  37. #157
    Apr 18 2007
    ^^^ Thanks guys! Damn I hate when projects are over, now I'm scrambling around trying to find another one that'll keep me busy.
    Greg
    C5UNION
  38. #158
    Feb 06 2012
    Get meth injection yet?!
  39. #159
    Apr 18 2007
    Not yet, I'm gonna wait until spring time to do the install. I need to start saving some cash instead of dumping it all into this car.
    Greg
    C5UNION
  40. #160
    Jan 31 2010
    S-Line A6
    East Haven, CT
    8 days until spring, not much time left to finish your meth install
