Page 1 of 6 123 ... LastLast
Results 1 to 40 of 208
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    lazer viking build thread
    i guess i will start a build thread here for my most recent incarnation of the car.. if you dont know the car i will catch you up.
    bought the car in august of 2006
    looked like this:
    clear corner and homemade rs4 grille:
    bought some new wheels, and a real rs4 grille.. and some h&r race springs
    bought coilovers:
    got new wheels:
    put ST's on it, and drove it STUPID low
    decided to go eliminator :
    bought another:
    gutted the interior:
    filled it with black stuff:
    and white stuff:
    decided not to go eliminator:
    http://www.audizine.com/forum/showth...im-t3-t4-build
    along with a whole bunch of other shit, stay tuned.
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    anyway.. the current list of modifications to the car is as follows:
    valeo ecode headlight
    ddm 55w hid kit
    painted front valence
    s4 side skirts
    s4 rear
    s4 interior
    creme s4 seats
    double din console swap
    ebay short shifter
    euro a3 shift knob and boot
    podi column pod and gauge
    awe pedals and dead pedal
    2.5" magnaflow exhaust with turn down tip
    3" catless downpipe
    ATP knock off t3 manifold
    tial 38mm wastegate externally vented
    50 trim t3/t4 turbo
    atp oil lines
    3" inlet with 3" vr6 maf housing
    aem dryflow
    hallman MBC
    southbend stage 4 ofe clutch
    racetec FMIC with custom piping
    550cc injectors
    eurosport adjustable FPR
    unitronic 440 ecu
    forge 004 BOV
    ST coilovers
    18x8.5 et18 borbet type A
    42 draft designs LED's
    im sure im missing stuff, oh well.. whats in store you ask ?
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    okay, so with the past out of the way.. its time to move forward
    here is what will be going on with the car over the winter:
    swapping the car from me5 to me7
    maestro tuning
    aeromotive a1000 FPR
    034 fuel rail
    044 or aeromotive stealth 340 fuel pump
    custom intake manifold with aeb runners and cnc'd velocity stacks
    65mm vr6 throttle body
    injectors are still undecided
    treadstone TR11 intercooler
    custom piping
    atp manifold
    3" downpipe
    3" v-banded exhaust
    tial 38mm wastegate
    spec 12lb 240mm flywheel
    clutchmasters fx400
    supertech springs and retainers
    81.5mm 8.5:1 Mahle Forged Pistons
    Scat 144m x 20mm Forged Connecting Rods
    Rosten Main bearing girdle
    ACL High performance Rod bearings
    ACL High performance main bearings
    ARP Main studs
    ARP head studs
    new pcv system
    turbo.. i dont know, 3076 maybe ?
    and a bunch of little stuff, and lots of re arranging and cleaning while in there.
    outside
    s4 front, unless i can find a good deal on an oem or dietrich bumper
    s4 door trim
    finally shaving the rear valence
    front end respray
    under the car
    new axles
    new control arms
    s4 uprights
    toureg calipers up front
    s4 rear brakes
    apikol rear mounts and such
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Senior Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    One Fast Twinkie /1969 Stingray/1988 notchback mustang (sold)
    City Of Roses
    NICE!
    Travis-
    2001.5 6mt Imola B5 S4 Avant - GIAC - FMIC - Vast stg3 clutch - Piggie pipes - Muffler delete - Tein SS coilovers - 15 mill spacers in back - nuespeed Front & Rear sway bars - E-codes - Tint - 18x9.5 privat kup's.
    Air ride build coming soon!
    Senior Member Two Rings colombian301's Avatar
    Jun 05 2010
    2000 bmw 328ci
    DMV, Maryland
    Amazing.
    Even the homemade grille was looking good.
    Any plans on the silver b5?
    Senior Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 1.8TQM 00 A6 Widebody
    Lombard, IL
    Vortex build thread getting boring?
    Brilliant Black B5 ..... 15k on Street Built Engine
    Strictly Pleasure/Zero Clearance/Stretch Your Legs
    Alex
    Will work on Audi/VW in Chicagoland
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Nah, it's just cluttered with a bunch of chit chat.. And I wanted another thread to document the new build
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Veteran Member Three Rings Aliel's Avatar
    Feb 26 2005
    '99 Audi A4 1.8TQM
    Tirana, Albania
    Your car has to be one of the cleanest in here. I love it. Can't wait to see what you do to the silver one.
    Active Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    IMO your car looked perfect with the flat fives (but I'm a bit picky on wheels). I so want a set of those on my car, I'm just having trouble sinking anymore money into my car at this point.
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    Although I'm sure most will look at this as a downgrade, have you considered going to a .48 A/R 4 bolt turbine housing with a stage 3 turbine? If you look at my build thread you'll see that they're not as small as you might think. What's interesting though is that the 5 bolt Ford style with the internal wastegate provision are a lot smaller than the 4 bolt non-internal. So that's where people may get that impression.
    Hell, if I can run 25 PSI on a 60-1 through my .48 housing you should be able to run the same, if not a little more on the .48 and it may very well make the car a lot more liveable. Besides, it's not like it would cost a whole lot, $200 or so. Call Jess at pureturbo.com (or net) and ask him what he thinks. The guy knows what he's talking about, especially when it comes to the T3/T4.
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    I will most likely not be staying with the 50 trim.. Or a journal bearing turbo for that matter, but I have thought about putting my .48 housing on it several times and never ended up having to pull the turbo off so it didn't happen.. I think for the price and the power it's a great option, but in order for it to perform how I want I believe I will need some newer technology
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    Is this a different car/build to your 50trim T3/T4 one?
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Nope, same car
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Oct 06 2004
    Minnesota
    I have always liked your subtle style. Keep it up.
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    Feb 19 2011
    Brisbane
    So what has changed since the T3/T4 in your other thread on here ?
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Not much yet.. I will update what this winters plans are in a little bit
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Mar 27 2010
    Quote Originally Posted by Lazer Viking View Post
    Fair enough, there are so many new offerings on the market that I can see where you're coming from. However, if you wanted to keep that exact same turbo footprint and throw some rods in, may I suggest a 60-1 with a stage 3 turbine and a .48 A/R 4 bolt housing? I know that Jess at pureturbos.net can hook you up with one for a really good price. However if you have your heart set on something a little more 'nouveau' see what kind of deal Jess will give you on a BB Billet Precision turbo. He's a Precision dealer, so he can shoot you some pretty good deals. I know I may sound like I'm schilling for him, but I honestly found that he had the best prices and really good customer service.
    Jun 14 2005
    Irvine, CA
    Your cars have come quite a long way! Looking forward to the next update.
    JB @ VMR | Wheels
    (714) 442-7916 ext. 108 | jb@velocitymotoring.com
    www.velocitymotoring.com | | | Blog
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    I thinks I know what is in store
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Quote Originally Posted by ZimbutheMonkey View Post
    will keep that in mind fo sho'
    updated the 2nd and 3d posts with more info on whats going on
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Quote Originally Posted by 1NaudiA4 View Post
    yes you do
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Quote Originally Posted by colombian301 View Post
    Amazing.
    eh.. its chipped and has a forge 007.. i bought a set of coilovers for it, and have some wheels laying around but who knows if or when they will make it on the car
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Feb 19 2011
    Brisbane
    Looks like you bought Joey's block then hey?
    Your car should be near bulletproof once its all together.
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    yes i did, and thats what im hoping for :thumbup:
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Feb 19 2011
    Brisbane
    Im sure you will have no problems.
    Built block + built head + GT3076R + W/M injection + 870cc Maestro tune + launch control and 2 step = ALOT OF FUN.
    Senior Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    Built A4, 08 Charger R/T
    Detroit Metro Area
    Still have the flat fives? If so PM me I'm interested.
    B5 Casa A4 with a built motor that isn't in the car and a PTE 6262 BB .83 A/R that going sing lag city b*tch lag lag city b*tch.
    Mar 16 2009
    Lombard, IL
    Quote Originally Posted by Turbo Nerd View Post
    lol don't think he's had those in like 2 years now
    Alex
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Yea, those are long gone
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Quote Originally Posted by jaychen View Post
    Indeed. Have you looked into the Comp Turbo's? Dan is in love with his .. so much that he hasn't texted me back in a long time.
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Have heard mixed reviews but I have no personal experience.. I'll check them out, I'm suprised Dan isn't in here yet gaying it up
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Oct 06 2004
    Minnesota
    Would you like me to move this to the Projects & Builds section?
    R135
    246
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    that would be awesome
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Senior Member Four Rings Dan[FN]6262's Avatar
    Sep 12 2008
    02 A4, 94 GMC, 06 450R
    South Central Pa, Dundalk MD
    I heard my name.....
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    Quote Originally Posted by Dan[FN]5857 View Post
    how do you like your new turbo ?
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Sep 12 2008
    I'd marry it, if that was legal. I'm totally gay-bones for it.
    PTE6262 w/ .63 A/R turbine = 28psi @ 5.3k rpms
    CT4-6262 w/ .82 A/R turbine = 28psi @ 4.8k rpms
    and with the Comp I see 1psi at 2.3k rpms. haha. so when just cruising in traffic, I still have more than enough power to overtake and keep up with traffic.
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    thats pretty awesome.. i see literally 0 psi till about 3400-3500
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Sep 12 2008
    yeah dude, 50 trims suck. lol
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Nov 06 2006
    99.5 BT a4
    southeastern pa
    true dat
    -Nic
    My Car
    99.5 A4 - BUILD
    01 a4 - daily
    00 S4 stage 2+
    Sep 12 2008
    3076 is a good turbo though, if that's what you want
    The Awesome™
    Mostly Stock
    Precision FTL
    BUY MY CAMS
    Mar 27 2010
    That leads me to think it may be related to your tune or hardware. I mean, I'm at 3500 ft and I'll see 1-2 PSI at 3000 on my 60-1. Yes, I don't hit full boost until 5000 RPM. But it's ramping up from, oh, I don't know, 5-6 PSI at 4000 RPM to 22-23 PSI by (or whatever I set my limit to) at 5000 RPM. I know you're running a .63 A/R turbine housing, but at your elevation with the lighter 50 trim compressor, you should be seeing some kind of positive pressure at 3000 RPM.
    What are you running for a manifold? IIRC it's an ATP one right? Maybe that's part of the spool problem. Mashing your exhaust pulses together hurts things most at low RPM. I'd be curious to see if my equal length, 5/16th steel pipe manifold actually makes a difference vis a vis an ATP one.
