Results 1 to 3 of 3
    Active Member Two Rings Trisha90's Avatar
    Aug 07 2009
    Minnesnowta
    Audi 100 automatic transmissoin thinks its in drive, therefore wont start. help?
    My friend has* 1992 audi 100 and sometimes it wont start because the gear indicator on the dash says its in drive, you can put it in any gear and it just says drive on the dash. This has happened before, but after some playing around with the shifter, it would magically go into park. It seems like an electrical problem. Has anyone heard of this problem or have had this similar problem?*
    Registered Member One Ring Quattrokid1's Avatar
    Jan 18 2012
    United Kingdom
    once or twice before, just put it in neutral then it will start. could be the multi function switch on the side of the 'box. I have already changed mine once before.
    Audi 100 S4 saloon
    Audi Ur WR Quattro
    Audi B6 S4 cabrio
    Audi B5 RS4 ( wife's)
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    Or a worn out cable.
