View Poll Results: What Turbo is the better option for Kyle?
Voters
26. You may not vote on this poll
  • GTRS Eliminator
    21 80.77%
  • Frankenturbo F4H-L
    5 19.23%
Page 1 of 3 123 LastLast
Results 1 to 40 of 82
    Senior Member Three Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    B6 Turbo Build, Questions and Updates
    So tomorrow I pull the trigger on a new turbo. I've been going back and forth for a while between GTRS and Frankenturbo, and I've leaned to both sides from one time to another. Anyhow funds are in place. Car is running like total shit and the weather is getting worse every day, so it's time to do something.
    The current situation is this; ko3 is shot to hell, leaking oil into both the exhaust and the intake. It needs to go, obviously. My installed mods are listed in my sig. These are my options:
    Frankenturbo kit, we're all familiar with it and what it comes with. $1,528.00 to my door with all the hardware needed (Franken kit, install kit ($210))
    GTRS Eliminator, to my door for $1498.00, basically just the turbo and gaskets. Again I think most people know what is included with this.
    So here is my dilemma. GTRS is actually slightly cheaper, making it very appealing. However my software isn't exactly optimal for it. Is a GTRS on Uni 2+ going to develop more power than a Franken? Software updating likely won't be in the budget until summer. Should the fact that I'm not getting the high flow manifold concern me?
    I'd like everyone's thoughts. I'm very torn at the moment. Last night I was planning on buying the Franken, but after seeing the duty and brokerage charges on it, I'm having second thoughts.
    Cast your vote.
    I'll turn this in to my build documentary when I receive the turbo. I have a couple other projects planned I'll be including as well.
    Kyle
    2004 a4 1.8tq 6MT > I got a turbo, and a bunch of other shit.
    Senior Member Three Rings Antoinebourdeau's Avatar
    Jul 17 2008
    2005 Audi A4 1.8t Quaslow
    Ottawa Canada
    My vote would go to the GTRS with stock (ported) manifold. You can upgrade from there down the line.
    you should be able to simply upgrade your 2+ to stg 3 and only pay the difference no?
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    05 A4 USP Avant, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Point #1 don't ship via courier and you won't have to pay brokerage or duty. You will still have to pay GST though.
    Point #2 We don't know what your goals/plans are.....so we can't help you decide what turbo.
    Point #3 You're going to need a proper stage 3 tune if you're going to run a GTRS. You're probably going to need larger fuel injectors for both setups......which means you'll need a different tune for the FT as well.
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Uni 2+ will be fine for the FT but I believe you need to upgrade to 415cc inj anyhow. With that being said, those are the same Inj that you would run on the GTRS elim.
    As for software, I believe this is how it goes:
    You bought the Uni 2+ $500
    Uni 3 is $850
    _________
    You pay the difference of $350 for the upgrade.
    These setups are night and day for you. FT will be an instant spool ~230whp car. It will be a fun/quick ride. The GTRS is a slightly more powerful setup that can easily break 280whp with the right mods. It's a M3 eater.
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
    Dec 27 2009
    Edmonton/Alberta
    Well I dont really have any lofty HP goals so much. As far as engine performance parts go. I will be installing an exhaust system and intercooler (intercooler will be chosen to meet the needs of the turbo I go with) I would potentially run W/M in the future as well. Thats pretty well it for engine performance plans. I'll be replacing the coils with the 2.0FSI ones with the spacers Issam was selling. <**- This will be happening in the following weeks.
    As far as software goes. The change from Uni 2+ to BT is "simple", but a $650 cost. I was also under the impression that 2+ was sufficient for the franken. I do currently run the TT225 injectors.
    Kyle
    Active Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    this + send it out to forced performance and have it converted into a HTA or just put a new compressor wheel in it and call it a day .. happy times !
    Nov 29 2005
    Edmonton, AB
    Except then he'd need a manifold
    Jul 03 2010
    QUEENS, NY
    Quote Originally Posted by MmmBoost View Post
    true. i think for the price of the manifold + turbo + converting it, itll come out to about the same and hell be putting down more power :)
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Murrieta
    Quote Originally Posted by Staz View Post
    If he sends it to FP to have a HTA wheel put on that turbo it will end up coming back with a 3" inlet .60 a/r compressor housing. So they actually swap out the wheel and the compressor housing.
    Senior Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    02A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Then he will need rods to prevent in the future
    MODS
    Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
    Are u just going to continue to wing it & keep expecting manna to fall from AZ?
    Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
    JHM>ShortShift-the works
    Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
    SPEC>Stg3+,LWFW
    STaSIS>328/305mm,40/60,SL
    Personal Motto>Walk Softly Carry a Big Stick
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    I'm pretty sure you guys aren't helping the OP at all...
    Do you want instant spool for very useable but modest HP? Get the Franken.
    Do want bigger hp with a stronger pull up top? I think thats GTRS territory.
    I'm no turbo expert though. Hell I'm only stage 1 and will likely never step up above a K04. So take my advice however you will.
    -CP
    2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
    Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
    Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
    2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    May 21 2007
    07 A4 Ibis White/S-line/Ti/2.0T Q
    Northshore, MA
    you could always buy my car, already stage 3 GTRS with IE Rods. ill give you a great price on it too
    -Nate
    07 Ibis White A4 S-Line Ti Package
    GTRS'd 04 6SPD 1.8T A4 Quattro SOLD
    http://www.cardomain.com/ride/3037832
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    PM me with youre H&R Parts needs!
    Dec 27 2009
    Edmonton/Alberta
    Staz - I've looked at your items in the classified a few times. I guess there are 2 reasons I dont really want to go that route. 1st is having to install a different exhaust manifold. This is actually one of the reasons I'm leaning away from the Franken. The second is I need a working turbo right away, yesterday. I dont have the schedule room to send it away.
    I know the franken spools really quick, but I didn't think the GTRS was the polar opposite by any means. My understanding is the GTRS spools only slightly later than the franken would and this is acceptable to me.
    Rods and that are the other issue. I do not currently want to re-build my engine. So I'm really not shooting for absolute hp goals. I think I would be more than happy at around 300. Again, supporting mods are not in place yet for this.
    Kyle
    Nov 29 2005
    Edmonton, AB
    Go with the GTRS on the stock mani. You'll wish you had once you install the FT and go...."that's it?"
    KISS
    Keep
    It
    Simple
    Stupid
    It's a proven setup and has put a lot of smiles on a lot of faces.
    Jul 03 2010
    QUEENS, NY
    ive been driving on a blown turbo for id say about 2 months now 1.8 NA FTMFW !
    Nov 29 2005
    Edmonton, AB
    Just do this and call it a day...
    Dec 27 2009
    Edmonton/Alberta
    Neat-O! Is this your setup Chris? loud I bet
    Kyle
    Jun 27 2011
    Is that plate so squirrels don't get into it?
    -CP
    Senior Member Three Rings BerNur's Avatar
    Jan 31 2009
    TEAM A.C.E - NY, NJ, CT
    i have a frankenturbo for sale... only had it for 2 oil changes 6 months less then 3k miles... my car sits a lot dough..
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    MD
    GTRS!
    Hers 2003 A4 1.8TQ TIP - GTRS Eliminator, REVO, Delphi 440's, ASP FMIC, Extreme TIP, Labree HFC, TT-DP, S4 door blades.
    2012 Mini Cooper - Stock
    Mine '64 Porshe 356, '12 A6 3.0T Prestige - stock
    Our Minivan has 240+ HP and its quicker than STG 1, 1+ A4's
    Senior Member Four Rings Turbavanttro's Avatar
    Jan 24 2008
    Lift, tools, B6 Sportec Avant, Saab 900 Carlsson
    Pennsylvania
    KISS
    Keep
    It
    Simple
    Stupid
    this would be my suggestion as well. dont overthink it, you'll enjoy the power based on your stated goals.
    Wanted: Hood for B6, no rust or dents, any color/paint condition
    So many Audis, so little time....
    Mar 27 2005
    Ducati S2R & Land Rover Discovery 2
    Tampa Bay Area
    Just get the franken. You will be able to run your current software and injectors for now. you will still need exhaust and FMIC over th winter, but it will l,it you out of pocket right now.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin/Swift Suspension w/ H-Sport Sways
    -STaSIS/Alcon 355mm Mono4 BBK & 305mm Rear
    -STaSIS 4:1 Center Diff & STaSIS LSD Rear Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    Quote Originally Posted by A4SoftWalker View Post
    No you don't. You can run a GTRS safely with 300awhp on a stock motor. People who blow motors with a GT28RS/GTRS are greedy. Set it to 21psi of boost and leave it alone. Plenty of power to enjoy driving the car for what it costs to get there.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Dec 03 2005
    connecticut
    KISS
    Keep
    It
    Simple
    Stupid
    THIS.
    9 out of 10 people who do something smaller than a GTRS ultimately go to a GTRS and are then happy.
    -Doug
    Oct 22 2005
    04 A4-Marley / 11 STi-Nami / 93 Mercedes Benz 300SE-Cruiser / Specialized Enduro-lol
    Reppin the Mitten.
    I also vote GTRS. The spool characteristics differences are minimal, why spend all that money for a k04 variant that will fall flat on its face before 5k rpms...The area under the curve for a GTRS is better imo for an enthusiast unless you auto-x and stay in 1-2 gears...
    -Vince
    Stockish 2004 Audi A4
    Senior Member Three Rings misterjj2u's Avatar
    Apr 26 2008
    2007 A6 Avant
    Newport Beach
    GTRS
    Buy my stuff:
    B7 Bixenon Housings (3 pieces--1x Left housing, 2x Right housings, one for parts, the other has a loose piece inside the housing)
    B7 Bixenon Ballasts - adaptive (2)
    B7 Bixenon Ballasts - non-adaptive (2)
    Senior Member Four Rings kneel's Avatar
    Dec 01 2007
    Atlas Gray Revo Stg.3 Avant, MK5 GLI
    Orange County, NY 10918
    GTRS
    I've done the KO4 & FT - not worth it in the long run!
    Neil_
    2003 Atlas Gray Avant w/ REVO STG.3
    PSi Concepts 20g Turbo..... Baby Recaro Seats!
    PODI
    Dubs on Defrost 5 - April 7th, 2012 - Westport, CT
    Dec 27 2009
    Edmonton/Alberta
    Alright polls are closed. Overwhelming win for the GTRS. And not that I'm basing my purchase on the votes entirely, that isn't the case. More importantly the handful of people I consider to be the foremost authorities on this forum have unanimously stated GTRS. So that's basically it, parts have been ordered. Should have the turbo and a few other little goodies showing up in the next 10 days or so.
    Thanks to everyone who posted. I value all of your opinions a great deal.
    I'll update later with my gameplan for the next couple months.
    Kyle
    Nov 29 2005
    Edmonton, AB
    WIN!
    Active Member Two Rings DBM's Avatar
    May 31 2011
    SLC, UT
    I just learned...so much.
    The way most people talk on here makes it seem like a FT is the only turbo to go with if you don't want to have to do rods, which was exactly the impression I was under.
    Great thread, great info
    Dec 27 2009
    Edmonton/Alberta
    Yes. I agree. Which was sort of the impression I was under. Hense why I was leaning FT earlier. The only reason i reconsidered the GTRS was because its available really cheap right near where I live. Which put the 2 very close cost wise. Im glad I went the route I did. And again im really thankful for everyones input. The people who seem to know the most about our vehicles all said GTRS. For me that says something.
    Kyle
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    A word of advice though. Unless you have the proper supporting mods in place like a 3 in exhaust, FMIC, etc... You're not going to see anywhere near what the elim is fully capable of. If you only have a total of $1600 ish to sink into this, get the Frankenturbo. I've ran a K03. K04-015, K04 Hybrid that was just like a F4L, GTRS elim and now a 60-1. The Frankenturbo kit comes with pretty much everything you need and it'll run fine on your 2+ tune. If you go with the elim, you'll be dumping in an extra $1000 by the time it's all over just to get it running right. You'll probably need to spend more to get the max potential out of it.
    I don't work for Frankenturbo, I don't work for ATP and I'm not going to loose any sleep over what you decide. The extent of my caring about it is pretty much limited to this post. But take my advice for what it's worth. I just want to let you know what you're getting into.
    Oh, and by the way, if you do something stupid like leaving a chunk of silicone coupler in your intake and trash the turbo on startup (like I did to my 60-1) Slappy will send you another CHRA overnight for $125. With the elim, you'll be looking at a month and $400-500 to replace the CHRA if Garrett decides it's rebuildable, if not, then you're SOL and paying $800 for a new 2860 CHRA.
    Dec 27 2009
    Edmonton/Alberta
    THE PLAN
    Step 1 - Turbo Swap
    -Install Turbo
    -Drop and Replace Oil and Coolant
    -New Valve Cover Gasket
    -New Plugs (BKR7E)
    So as mentioned earlier, getting the turbo installed in the car is top priority. The K04 is going to explode any day now. I’ll put new plugs in, I’m sure all the oil by car has been sucking in has ruined them. Last time I pulled my coilpacks out I noticed there is some oil leaking onto the plugs via the valve cover gasket. I’ll be replacing that now while I’m in the area. I’m sure new oil and coolant are recommended with a turbo install. Even if it’s not necessary my oil and coolant have been mixing slightly, so they need replacing. I have a fuel filter sitting in my trunk that I plan to install, it’s overdue.
    Step 2 - Ignition
    -New Coilpacks (2.0T FSI, red top)
    -Coilpack Adapters from INA
    -034 Carbon Coil Cover
    This is another area that just needs replacing, coilpacks are looking a little rough. Seems like most people have been happy with the results of the 2.0T coilpacks so I’ll give them a whirl. I think this setup looks pretty awesome too. I’ll be shooting to get this done within a couple weeks of the turbo swap.
    Step 3 - Fueling
    -440cc Injectors
    -Unitronic BT File
    -Fuel Pump (Walbro?)
    -034 PCV Replacement Kit
    Pretty straight forward. This is where I try and get some more power out of the turbo. I already run a Uni file so it makes sense to stick with them. Fuel pump I’m not too sure on. I could use some input on this one. PCV kit is just one of those things that I know is going to fail, I may as well get it done sooner rather than later.
    Misc
    -Exhaust
    -Intercooler
    -TIP
    -Methanol Injection
    I know that these are “necessary” parts. I understand the importance of having them in place. Maybe not so much the meth, I just want it. I’ll probably just keep my eyes peeled for these items to pop up in the classifieds or wait for group buys. I’ll pick them up as they become available, but they are the lower priority at the moment.
    I know this isn't the most exciting build, not by a long stretch. I'm going to try and document it as best I can regardless. I’ll photograph as much as I can. Progress won’t be overly quick. I have a budget to maintain, limited access to a proper garage and the weather here is not great for this type of work. It is what it is. More or less I just want to keep all my questions and posts contained to the one thread, lest I pollute our forum… I’m going to have a lot of questions and probably a hand full of issues. I’ll be reading lots of the other build threads over the next week. Feel free to comment as you wish. I enjoy everyone’s input.
    Kyle
    Mar 27 2005
    Tampa Bay Area
    I would move the misc stuff & Step 3 items up in priority. I am not sure i would run the GTRS with the Uni S2 file. I have this feeling you will be running things lean without the proper fueling and file. Again this isn't my motor, just looking out so you don't run into other issues.
    on 93 oct
    Feb 08 2011
    Murrieta
    Quote Originally Posted by EBG 18T View Post
    Should be moved up into #1 since the injectors/tuning should be done at the same time the turbo is put in.
    Senior Member Three Rings 613B6's Avatar
    Jul 29 2009
    2004 A4 6MT
    Street racing in Ottawa
    GTRS vote here!!
    New setup in the works...
    12.9@107mph | 290awhp 277awtq
    Stock block | Elim GTRS | Maestro 7 | Pump gas + washerfluid
    Dec 27 2009
    Edmonton/Alberta
    I was told by the turbo supplier that running it on the Uni S2 file would be fine for the time being. The turbo will just supply the boost requested by the file right? I dont run a MBC, so I won't be cranking the boost up anything. But the major reason for not doing it right away is cost honestly. I don't have the funds ready to reflash at the moment. I still hope to get this all done in the next couple months. It couldn't hurt to let the turbo break-in for a month at low boost anyhow. Plus its cold as balls and I don't want it over stressed.
    Kyle
    Oct 22 2005
    Reppin the Mitten.
    To simply put it...your turbo supplier is a retard.
    Can you do it? Possibly. Should you do it? Probably not. If your process is only a few days, then I'd say you are more or so Ok...few weeks of daily driving? Not such a good idea.
    In laymen terms your tune is requesting for an xx amount of air at xx psi. Your GTRS will provide A LOT more air at xx psi then your k03 will. More air + not enough injectors for fuel to compensate for the air = running lean. Running lean for too long = engine kaboom.
    But like I said...it's a recommendation. Good luck buddy, hope that helps.
    -Vince
    Jul 17 2008
    Ottawa Canada
    I would group as following.. the injectors and file is more important then spark plugs and fsi coils
    at that point, the order for step 2-3 isn't as important. I would however do fmic and exhaust before doing meth, fuel pump etc
    Step 1
    -gtrs
    -440cc Injectors
    -Unitronic BT File
    Step 2
    -New Plugs (BKR7E)
    Step 3
    Dec 27 2009
    Edmonton/Alberta
    Damn I'm becoming worried now. I was under the impression the file would still keep the turbo in check, mistakenly aparently. What if I did run a MBC and just kept the boost down? Would this eliminate, or at least lessen the chances of running lean? I suppose I could just unplug the N75 as well, if it came to that. Until I could get the file and injectors.
    Well it's good this is comming up now. I want to make sure I'm as ready as possible when this thing arrives. Alright well I guess I'll try to accelerate the injectors and reflash then. Put the coilpacks on hold. I was thinking the feul pump was more of a requirement. If not then I'll backburner that aswell.
    Alright thanks guys. I'll proceed on a slightly different route then.
    Kyle
