Results 1 to 9 of 9
    Active Member Two Rings careercadaver's Avatar
    May 25 2010
    Niles, MI
    careercadaver's 2000 Nogaro S4 - MI
    Picked up a 2000 Nogaro S4 with Alcantara Insets about a week ago and thus far I have been very happy with the car. There are a few things I will be changing out to better suit my preferences but overall the car is very nice and gets a lot of compliments. Here's how she sits now:
    RS6 Wheels
    Tein Basics
    JHM Trio Short Shifter Package
    NGK Spark Plugs
    JHM 4:1 center diff upgrade
    35% Tint
    Lots of service done, including timing belt and water pump, All 4 O2 Sensors, EGT Sensors, both rear wheel bearings and right front as well, accessory belt, all cam shaft seals and valve cover gaskets, both side lower control arms, both left side upper control arms, ABS module rebuilt, new power steering pump, new central locking pump, 1st and 2nd gear synchro's and shift collar, RS4 Pressure plate and custom 4 puck style clutch with VAST lightweight flywheel. All within the last 10K miles.
    Getting a bit of vibration over 60mph, I believe it is from warped rotors which I have heard are a common issue with OEM replacement rotors. I plan to swap out the rotors and pads for some drilled Stoptech Rotors and Hawk Pads and a set of Goodyear Eagle GT A/S Tires. Nothing too fancy for tires yet, saving for a Summer wheel and tire combo for the spring. If all goes as planned I'm thinking Linea Corse LC818's or maybe something BBS but I'm still researching to see what offset I'll be needing, wanting something pretty aggressive.
    Also, the Bose system has that came with the car has left something to be desired. I have a set of Focal Utopia Component Speakers I plan to swap in up front and I'm thinking maybe some Boston Acoustic Rear Door and Deck speakers for acoustic fill. I'd like to pick up a headunit here too, just gotta see what kinda cash I can get together. I've had a few Alpine units and been satisfied thus far but either way it will have to have Navigation to tempt me.
    Also, seeing an RS4 Grill in my future and maybe a front lip if I can find one something that's not too tacky. Hoping to get through the winter without spending too much on her.
    Some have my other cars prior to picking up the S4...
    2001 Subaru Impreza RS (Satin White)
    - Bakemono Mesh Fog Light Covers
    - JDM Tails
    - CNT Catback
    - Cobb CAI
    - WRX Limited Interior
    - WRX Black Carpet
    - TEIN Hood Dampers
    - Espelir Lowering Springs
    - Prodrive P1's w/ Hankook Ventus V12's
    2002 Lexus IS300
    -Tein CS Coilovers
    -TRD Yellow Race Sways
    -TRD Underbraces (Front and Rear)
    -TRD Rear Strut Tie Bar/ Ebay Front
    -19X9’ Ro_ja F1’s (+40 Offset)
    -Ray’s Locking Lug Nuts and Valve Stems
    -Carson Tuned Front and Side Skirts
    -Authentic TRD Rear Skirt
    -Seibon Carbon Hood w/ Painted Corners
    -Areocatch Hood Pin Set
    -Figs Hood Supports
    -Altezza Older Style Grille w/ Lexus "L"
    -Painted Calipers w/ Decals
    -Drilled and Slotted Rotors
    -Stoptech SS Brake Lines
    -Alpine IVA-W505
    -Focal Utopia FA 165W Component Speakers
    -Focal 400W/4 Amp
    -JDM Dark Chrome Tails
    -JDM Double Din Dash Kit
    Active Member Two Rings shinamura's Avatar
    May 22 2011
    Detroit, Michigan
    Hey bro, where is niles? i'm in the metro detroit area, just got some body work done on my b5 a4
    May 25 2010
    Niles, MI
    Niles is in SW lower Michigan, just over the border of South Bend, IN. I think we are about 3 hours away from one another.
    May 25 2010
    Niles, MI
    Finalizing a parts list for my Audio upgrade/overhaul this week. Thus far I have picked up:
    Alpine IVA-W505
    Focal Utopia (FA165W) Components
    Focal Solid 4 Amp
    Boston Acoustics SE35
    Boston Acoustic SE65RC
    Decided not to put a lot of money into the rear door and deck speakers as they are pretty much just acoustic fill at this stage. Still needing dynamat but overall I think I've got a decent start. I also have a set of JL 12W6V2's that I am considering making a custom box for. I still need an amo and capacitor for them but I'm going to run the RCA's to the truck so it's quick and easy should I decide to add them later.
    May 25 2010
    Niles, MI
    Got my Goodyear Eagle GT A/S's mounted this week. Swapping out TRE's as one was bad and I got a Black Friday deal on a Set and I planned to get the vehicle aligned this weekend. After that the stereo overhaul begins...
    I think I have all the pieces I am in need of short of a little dynamat and some speaker wire. Though I am a wondering what I am getting into trying to custom fit 6.5"X3"(depth) components in place of my door speakers. From what I have read the 6.5's "should" fit without issue but the depth is at a max and will likely require a little fitting/customization. At minimal I will get my deck speakers ran as well as my RCA's and Headunit. I'd like to do it all at once but with the weather starting to change I'm sure it will affect my ambition.
    I am also feeling the need for an alarm and I'd like to add remote start...Let the process begin I suppose...
    May 25 2010
    Niles, MI
    Stereo overhaul has gone well thus far. Though I have had a hick-up or two. The previous owner of my Alpine HU did not include all the harnesses and that cost a little time. Too, Crutchfield did not have the correct speaker sizes for the door speakers so I had to order the correct ones and do the whole bait and switch routine eith them. Ended up being able to fit 6.5's in the doors and rear deck:
    Side By Side Boston Acoustic and Bose Rear Door Speaker.
    Rear Door Speaker Installed.
    Rear Deck Speaker installed.
    Also, my effort to put the component set-up I have in the front doors will prove a bit challenging. It looks as though I will have to make a baffle on the outside of the door to accomidate the depth. As well the front door speakers are 4" and I'm trying to go 6.5" so it would require fab work either way. Still need to install an amp under a seat, not certain where the Bose amp is either so I'm going to have to do some digging to familiarize myself.
    Got the HU all wired in and everything worked well last night. Got in the car this morning and sor no apparent reason there is no power to the Alpine... :( I'm assuming maybe a fuse but I will not likely have time to check it until tomorrow afternoon. Here's an installed pic of the HU:
    Car needs a good cleaning after my endeavor, but at least the final product will look nice. :) Too I couldn't decide whether I wanted to dynamat the top of the metal deck lid or the underside toward the trunk. Might be pulling the deck lid again to keep my work as hidden as possible.
    Active Member Three Rings Ed Gein's Avatar
    Sep 21 2011
    is nonexistant
    Location, Location!
    You had some nice rides, I like the interior and gauges on that Lexus
    2008 Ocean Blue A4, Turbo, AWD
    REVO stage 2|2.5" test pipe|B8 DV|K&N drop in|NewSouth boost gauge
    May 25 2010
    Niles, MI
    Quote Originally Posted by Ed Gein View Post
    Thanks a lot man!! I miss the Lex every now and again but I plan to make my S4 far exceed what I did with the IS300.
    Been awhile since I updated this thread...
    I decided to make some custom baffles/pods for my door speakers as the front 3.25"-4" garbage Bose speakers were blown and flat out not cutting it. The baffles will accomidate my Focal Utopia 6.5" components. I'm going to wrap them in either carbon fiber or Alcantara suede asap and try and finish this audio set-up.
    I also picked up some StopTech rotors and Hawk HPS pads. Just waiting for a nice day to paint my calipers so I can hopefully do this all in one shot.
    Wheels aren't far out either. Not sure what I'm waiting on...just dragging my feet but i believe I'm going to go Miro 18X9.5 et40 all around. I know there will be some custom work and spacers, extended lug bolts, possible fender rolling involved but I have Falken 452's ready to roll for this set-up and I'd rather be able to rotate my tires as opposed to doing a staggered offset type of set-up.
    ...just picked up a podi guage pod off the V1 promotion they were running as well. Thinking a VEI boost guage in the near future as well...
    May 25 2010
    Niles, MI
    Mod bug got me again yesterday. Found a good deal on some BBS wheels and decided to grab them for the time being. They are RXII's 18X8.5 et32, think I'm going to put the Falken 452's I have in the FS section on this week or next. Here's a pic:
