Results 1 to 34 of 34
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Car at shop, helmholtz resonators being installed.
    Ok, so last weekend I installed a new stasis exhaust and loved the sound volume but not the drone. So I just dropped my car off at Goofy's Custom here in Eugene, and having them cut in a 34" long stainless resonator into the stasis. I am having just one installed right before the exhaust splits into the 2 x 2.5" sections. I have before pictures, and FFT resonance spectrums from recording my exhaust under several different loads earlier today. After I pick up the car in a few hours, I will record new sound clips and do another FFT analysis to have an exact measured difference in drone. I am keeping my fingers crossed because this is already close to $400 for all the materials and fabrication work.
    Eric
    Established Member Two Rings brundy's Avatar
    Jul 31 2008
    2006 Audi A4 2.0TQ 6MT
    Upstate NY
    What did you use to record the sound? What was the main frequency? Can you post the FFT?
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I used SignalScope from Faberacoustical. It is an iphone app that is $25, and works great. The only drawback is that the built in iphone mic has a low pass filter (which the software maker indicates as a reason to use an external mic if you have one. I didn't have an external mic so the readings that I get for <150 Hz will be artificially low. However, the resonance is still very visible at ~70-90 Hz and another one at between 150-200 hz. Depending on the rpms that I am at, the two peaks will float within those two peaks.
    OK, update. The thing ROCKS!!! Basically the "STASIS exhaust with 034 HFC" is close to the "stock exhaust with the 034 HFC". Seriously I don't think I can overstate how much better it sounds. The bad part is, the total system cost went from about a grand to around $1400 with the extra fab work, so it might be easier to just get the APR GenII with Sound Cancelling (if they offer it for the B7). Now if you didn't pay someone $100/hr, and you did it yourself, or if you already have the system or a similar one and you just want to fix the thing, than I say GO FOR IT ASAP. I used a 2" dead end stainless steel 304 pipe that is adjustable from 30" to about 40", and I can tune the thing to have pretty much zero drone, to having a little drone (if you wanted to,,,not me).
    I don't have any online image storage, so if someone wants to host the spectrums and pictures for before/after, just PM me and I will email you the photos. I am still moving the pipe longer and shorter trying to tune it exactly, as the sound varies depending on how long the chamber is, so I am not finished with my tailoring yet; but I am in love with the car again.
    - Eric
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    You can email them to me. Shanedrakeairforce@gmail.com
    I'll post them as soon as I get them
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Sent the fab images to you.
    I am at the bar watching the Duck game, so too busy to add the spectrums with the needed descriptions right now. Maybe at halftime or when I get home (if standing straight enough to want to surf the forums :-)
    Eric
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    I'll get the rest up in a bit, I have to admit the whole setup looks pretty good :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    BEFORE:
    AFTER:
    The loss seems fairly clear. Where do you place the phone for the sound test?
    -Shane Drake-
    >DRAKLOREs Build<
    Registered Member Four Rings drumnjuny's Avatar
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Items for Sale
    wow, that looks great!!
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Go ducks !!
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    Paul young, like on desperate housewives... Right? Lol
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Look great! Good to know it solved your problem. I went with a different method, got my shop to weld in a custom flange with a removable block off plate on one side of the exhaust.
    Your setup is similar to what they do with on a 350Z,
    B7 A4 GT28
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    My friend has that sane exhaust on that same color z lol
    -Shane Drake-
    >DRAKLOREs Build<
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Thanks guys. I am frankly amazed it is working so well. The 350Z setups are actually different, but work on the same principle. This is the whole argument between AWE and APR that showed up in another thread, where the there was a pretty fare amount of flame going back and forth about sound cancellation theory. Basically this is not a Helmholtz chamber, though it could be working as one in addition to its real intended purpose. The difference is in how the cancelation wave is generated. I will skip all the vague arguments about which is better or who has a bigger shop and just jump to the end.
    1. In a Helmholtz chamber the air in the throat of the chamber is oscillating back and forth because of the spring action within the chamber (the 350Z idea above, and what is used in AWE/Magnaflow/etc exhausts). If this is at 1/4 or 1/2 (or some 1/4 or 1/2 multiple), the two pressure waves eat each other's lunch and we are happy. Here, the sound in the exhaust is not needed as a driving function, the velocity of the gasses travelling across the connection produce the oscillation, and the volume of the chamber and the relative geometry of the connecting throat are the critical items to get it to produce the correct cancelation pressure wave.
    http://en.wikipedia.org/wiki/Helmholtz_resonance
    2. In a reactive silencer, the standing wave produced by the driving function in the exhaust tone is sitting pretty within a length of side passage. The distance travelled from the entrance to the end cap length of the chamber is 1/4 that of the driving wave, and again they eat lunch and we are happy. What I designed and built was a quarter wave length reactive silencer similar to what APR has licensed from CORSA, and is part of the famed NASA reference that shows up in forum posts regularly.
    http://www.universalaet.com/en/docs/...-silencers.pdf
    Everyone (including myself when I started this thread) keeps describing reactive silencers and Helmholtz chambers the same thing. They are not. But here is the catch, they both require to be tuned to specific frequencies (neither are broad band regardless of what any vendor tries to sell you), both both do the same thing, both suffer from changes in the temperature of the chamber, and both can do their job just as well.
    Now here is the part that fuels all the arguments, the Helmholtz chamber is potentially more sensitive to pressure and temperature fluctuations than the reactive silencer. So even though a correctly designed Helmholtz chamber will work 100% as well as a reactive silencer, it:
    1. Suffers from changes in the environment easier and won't work as well over as many conditions. Basically it is a touchy biatch and if it ain't happy, it don't go shopping. You could fix this by ensuring that the chamber temperature is always spot on in all times of the year, and tune it right, but it is just damn touchy.
    2. THIS IS IN MY OPINION THE BIG ONE - It doesn't need a driving function. In other words, it will produce the blowing across the beer bottle sound even if there is no sound to cancel, in which case it is ADDING TO THE EXHAUST NOISE in the absence of drone. Basically it becomes the drone when its evil twin is not around for it to have lunch with. Don't know if this is the cause of the reactive silencer being better or not, but it is my speculation that it is part of it.
    Happy holidays, and I am excited to see if the vendors chime in her and correct me or start biatch slapping each other again. :-) Come on, it is Sunday, I don't attend church and we need entertainment.
    - Eric
    Oct 29 2009
    Kitchener, On. Canada
    do you think doing what you did on an awe exhaust would yield noticeable results? I have awe quad tip with 034 HFC in my avant with a ridiculous amount of drone. I love how it sounds, but I'm thinking of getting rid of it because of the drone.
    06 B7 A4 2.0T Q6MT avant - BB
    http://foreignautomotive.ca/
    Mods:Uni stg2 HPFP 91oct, KMD HPFP, ER SMIC's w/034 hoses, 034 TIP, 034 HFC, Custom quad-tip, a4 sport suspension, RS4 rear sway, RNS-E, RS4 carbon trim pedals & shifter, S4 Recaros, AWE vent mount boost gauge, Black RS4 look grill, Votex front splitters & side skirts, Ti window trim, S4 mirrors, LLtek LED headlights, DDM HID Fogs, Black 19" O.Z. Ultraleggera
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Yup, sound cancelation works everywhere. BUTTT, it has to be tuned to your specific exhaust. So just record the drone, FFT the frequency, calculate the "rough" length, then have one installed that allows you to adjust +- about 5 inches each way, and you should be able to knock it out. Now here's the catch, you probably have at least 2 different low end peaks that are pissing your ears off, and the pipe length for one is going to be way the hell off of what is needed for the other. In my case, I have no idea how I am hitting both peaks ??? Maybe the change in exhaust dimensions made it no longer resonate at one peak, so that one didn't have to be treated so much, and then at the same time I was able to hit the one that was still there. At least this is my guess. A rough shot at it (and many hours looking at what people have done for everything from 4 bangers to V8 Porches), if you cut in a pipe that is adjustable from 28 - 38 inches, you will likely be able to get at least one of the little guys that are hurting your hard earned Audi! ;-)
    Hint #2, make the dead end portion uphill so you don't collect moisture in the pipe. I had mine shaped downward so that I can get a really long pipe end (total of 60") just for testing to see if I can reach down and hit the 80 Hz range for science. And now it is collecting water vapor in it :( So when I through the K04 on next month, I will take the downpipe reactive silencer combo to the shop and have them mandral bend the daddy up ! ;-)
    - Eric
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    Your welcome btw...
    Lol
    -Shane Drake-
    >DRAKLOREs Build<
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Oh snap. Thank you for posting the pictures. Forgive the tardy appreciation; I can be an asshat about remembering to say thanks sometimes!
    - Eric
    Oct 14 2009
    Okinawa Japan
    Items for Sale
    NP- anything that benefeits the community is worth the effort :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    One last update then we can let the thread die. This thing is much more sensitive to adjustments than I expected; I was moving the pipe back and forth a couple of inches at a time, but it is actually sensitive to 1/2" changes in length! So if you do it, expect to fine tune the little guy by doing plenty of crawling under the car to make small changes, then going for a drive, then crawling under the car, then going for a test drive, etc. I like doing this, so no biggy.
    Sky Capitan Out
    - Eric
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Oh ya, and my final adjusted length to kill the 2000 rpm drone is approximately 34".
    - Eric
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 15 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Don't mean to necrobump this thread, but where did you get the adjustable dead end 304 pipe, and why did it cost you close to $400? I can do dual 18" resonators after my y-pipe for $200 installed, but if this is a more potent way to eliminate drone then I'll go ahead and do this.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Quote Originally Posted by ericpaulyoung View Post
    Go ducks !!
    That was a crappy game...we didn't even show up!
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by NorcalPB View Post
    The muffler guy welded a short section with a dead end to it, that was swaged to fit over the open end of the branch resonator. That way you can adjust the length to get it perfect. It is surprising that small variations will make a noticeable difference. And given that the exact location of the branch tee, and setup you are running is going to be slight different, this adjustability is a must. I guess the other option would be to give the calculation your best shot and live with it, but I noticed a substantial difference in even small variations in overall length.
    Just make sure it runs up hill towards the end so it doesnt fill with condensate and screw your tuning up. Or you can do like I did and drill a 1/16th inch hole at the lowest point as a drain.
    Eric
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by Stewy View Post
    GO DUCKS!!
    Senior Member Three Rings baldy's Avatar
    May 11 2010
    A4 Avant, Touareg TDi, Yamaha R1
    BC
    Sorry for the bump.
    Eric, what was the final length that worked for you?
    Do you have the spreadsheet to calculate handy?
    Going to get a 3" version made for my avant... I can't take the drone anymore...lol
    OEM S3 K04..Unitronic!!!! Autotech HPFP..RS4 PRV..S3 injectors..RS4 LPFP Controller..3" DP..Neuspeed Exhaust..034 HFC..ER DSMIC's..034 Silicone IC and Inlet Hoses..OEM S3 DV Relocate..MANN Provent Catch Can...034 Breather Plate...RS4 Sway....255/35 Eagle F1's...H&R Sport Springs...Bilstein Sport...Cayenne 6-Pot 330mm front / S4 rears...HAWK HPS Pads...Goodrige SS Lines...NewSouth Ventgauge..Bose Mod..Aux-in..12" Sub in Fiberglass Box..HID Fogs
    Senior Member Three Rings borderline's Avatar
    Nov 15 2014
    Quebec/Canada (near MAINE/USA)
    Items for Sale
    Quote Originally Posted by baldy View Post
    Sorry for the bump.
    His final adjusted length to kill the 2000 rpm drone is approximately 34".
    I am working on this too. Branch is done but I need to find the exact length for my setup.
    A4 B7 2.0T w/JHM stage II.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Items for Sale
    holy thread revival
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    This is so cool.
    My respray thread
    Nov 15 2014
    Items for Sale
    Sorry for that guys!
    Senior Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Thanks for the bump. Something else for me to look at.
    2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - Unicorn rescue operation in progress.
    WTB: Mint condition silver B6 passenger fender.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t, E63 AMG
    San Diego, Ca
    Items for Sale
    hey guys, bringing up an old thread. how did you calculate the length for your 1/4 wave resonator? with my 1.8t I have recorded a frequency of 83-86hz using my Android phone. the RPM where this frequency is most annoying is at 2,750 RPM. with the calculations I've used they say I need a 1.04 meter 1/4 wave pipe length.
    2007 Mercedes E63 AMG - Nardo Grey, Pano, LTH X-Pipe, Res Del, ROW Box Mod, Programa ELM, UPD Arms
    2003 Audi A4 1.8t Q Avant - Maestro, 225TT Inj, TP, FMIC, Thermal R&D Exh, KW V3, BBK / Ferrodo DS2500
    1992 SC400 - LS2 6.0, LTH, Tomei 2-Way, KW V3, BattleVersion Arms
    1986 Toyota Corolla GT-S SOLD - 20 Valve, Haltech E8, Toda 272 8.5mm, Toda Cam Gears, Silkroad High Rise Headers, TRD 2-Way, TRD SS Race
    Established Member Three Rings A4B7Avant's Avatar
    Jun 07 2017
    2010 Camaro SS/RS 6M/T Maggie
    PA
    What formulae did you use?
    2008 A4 Avant SE Ibis White
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, HD Street Rod, Grumman Yankee AA1A, Norton Commando 750
    Indiana
    It's easy to calculate for a closed end pipe. Go to this link and use the formulas:
    http://www.physicsclassroom.com/clas...nd-Air-Columns
    The speed of sound is 340 meters/second or 1125 feet/second
    Nov 02 2007
    San Diego, Ca
    Items for Sale
    using the formula provided by that website this is what i came up with.
    speed = frequency wavelength
    wavelength = speed / frequency
    wavelength = (340 m/s) / (86 Hz)
    wavelength = 3.953488372093023 m
    Length = (1/4) Wavelength
    Length = (1/4) 3.953488372093023
    Length = 0.9883720930232558 m or 38.912287126899833822 inches
    some forums state you just need an RPM to calculate the frequency... if i did that i come up with
    f = RPM * pulses/rev * (1/60)
    f = 2750 rev/min * 2 pulses/rev * (1/60)
    f = 91.66666666666667 pulses/second = 91.66666666666667Hz
    wavelength = (340 m/s) / (91.66666666666667 Hz)
    wavelength = 3.709090909090909 m
    Length = (1/4) 3.709090909090909
    Length = 0.9272727272727272 m or 36.506800286327845129 inches
    https://www.performancetrucks.net/fo...-drone-489463/
    http://www.ls1gto.com/forums/showthread.php?t=449416
    http://www.mr2oc.com/208-aef-engine-...esonators.html
    number of cylinders 4 4
    Engine RPM 3500 2750
    Temp of the exh gas = 80
    Speed of sound (m/s)= 379
    Engine frequency (Hz)= 91.67
    Wavelength (m) = 4.13
    1/4 wavelength (m) 1.03
    (length of the branch resonator)
    so much conflicting information out there. it seems the difference is the speed of sound that is being used.
