Results 1 to 9 of 9
    Stage 3 Forum Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    JHM: Your B6-A4 3.0 OEM, Replacement, and Maintenance Parts Source
    JHMotorsports.com has everything that you need to keep your Audi A4 3 Liter running like new.
    We've added a lot of products to the site recently and we are continuing to add new parts as we find out what you guys are looking for.
    For example, check out THIS PAGE to browse our 3.0L V6 "Engine and Performance" section. That section has some of the more common parts we've added for the 3.0 so far - spark plugs, air filters, fuel filters, etc...
    NGK Laser Platinum Spark Plugs (OEM) for the 3.0 V6:
    K & N Air Filter for the B6-A4 3.0 V6:
    MANN Fuel Filter for the 2002 - 2003 B6-A4 3.0 V6:
    In that section, you'll also find our complete Timing Belt Kit for the B6-A4 3.0:
    Click HERE to purchase.
    If you have something you need that you don't see on our website, don't hesitate to email us with your parts request! Send requests to sales@jhmotorsports.com (or v8@jhmotorsports.com if we don't get back to your first request within two days).
    Jun 04 2008
    The Fastest Audis
    California
    Hey Everyone!
    For those of you who haven't noticed, we have a lot more maintenance and replacement products for the B6-A4 3.0L! Take a look at few of the new products we have for you!
    To start it off, we carry two different alternators for the 3.0L V6:
    Click Me For Remanufactured (Bosch) Alternator!
    Click Me For New (Valeo) Alternator!
    Don't forget to get your Alternator Belt and Tensioner replaced as well!
    Click Me For Continental Alternator (Accessory) Belt!
    Click Me For Belt Tensioner!
    Is your Breather Hose Assembly and PCV going bad? We offer a complete OEM replacement kit for the Crankcase Ventilation System on the 3.0L V6. This PCV hose system becomes brittle and weak over time. Whenever you are working around your intake manifold or attempting to remove it, you stand a strong chance of damaging this fragile hose system. Due to the intense temperatures these hoses are exposed to they are prone to collapse and often crumple in your hands.
    This kit comes with the following 3 pieces: 1 - Breather hose that contains the PCV valve, the crank case breather hose, and attaches to both valve covers. 1 - Breather hose that attaches to the crankcase baffle under the intake manifold and attaches to the breather hose that attaches to both valve covers. 1 - Breather hose (small, 90 degrees) that attaches the PCV valve to the intake manifold.
    NOTE: There are 3 different kits available for the 3.0L V6 due changes in the PCV System Setup. Make sure you select the correct option based on your VIN number.
    Click Me For Breather Hose And PCV Replacement Kit!
    If your Breather Hose is in excellent shape, but your PCV is bad, we sell the PCV separately, too!
    Click Me For PCV!
    Is your Power Steering Pump going bad? Making a loud noise or grinding? You may need a Power Steering Pump!
    Click Me For Power Steering Pump!
    Finally, as Summer temperatures kick into full gear make sure your 3L's cooling system is in top shape!
    Is your Radiator leaking, do you have busted or cracked fins?
    Click Me For Radiator! (Automatic)
    Click Me For Radiator! (Manual)
    Don't forget the Upper and Lower Radiator Hoses, which are a great item to replace at the same time as the radiator.
    Click Me For Lower Radiator Hose!
    Click Me For Upper Radiator Hose!
    Check out the rest of the products we sell for this platform HERE!
    Feel free to give us a call if you have any questions or would like help placing an order!
    Jun 04 2008
    The Fastest Audis
    California
    Hey 3 Liter guys!
    Just wanted to drop in and give a big thanks for all of the orders this weekend! Remember, if you do not see what you need on our website don't hesitate to give us a call because we are more than likely able to get it for you!
    Jun 04 2008
    The Fastest Audis
    California
    Hey Guys!
    Just wanted to let you guys know that we have recently added a bunch of replacement rotors for the B6-A4 3.0L! Check them out!
    You can find our selection of replacement rotors HERE!
    Feel free to contact us with any questions!
    Jun 04 2008
    The Fastest Audis
    California
    Hey Guys!
    Just wanted to say thanks for all of the orders!! We're still stocking 3 Liter products and adding new products weekly!
    Have a great holiday weekend!
    Jun 04 2008
    The Fastest Audis
    California
    Hey Guys!
    I just wanted to stop by and give a big thanks for all of the 3.0L orders lately! Remember, if there is something you need for your car and you do not see it on our website, don't hesitate to give us a call because we can get it for you!
    Senior Member Four Rings imnuts's Avatar
    Aug 12 2009
    Dolphin Grey Audi A4 3.0 Q 6MT
    PA
    Quote Originally Posted by Tech/Sales@JHM View Post
    Hey Guys!
    Would love to know when you're going to have the other 3.0 products that you've been working on listed on the website, like the tune, downpipes, etc. Already got my ECU flashed, but I'd like to know how much downpipes would cost.
    Retrieve your SKC for use with VCDS
    3.0 JHM Tuned, Zingo Airbox Mod, 6-spd, quattro, Vogtland Jr. Suspension, Single Xenon E-Codes, Apikol Snub, 034 Motor and Trans Mounts
    Jun 04 2008
    The Fastest Audis
    California
    Quote Originally Posted by imnuts View Post
    imnuts-
    As you already know, the JHM 3.0L Tune is available via call-in but I cannot give you an exact ETA that these products will be available on our website. We are working as fast as we can on finalizing these products. I know this sounds redundant, but I can assure that you guys will be the first to know once they are available and ready for purchase.
    -Jake
    Jun 04 2008
    The Fastest Audis
    California
    Hey Everyone!
    Thanks for all of the orders over the weekend! We always stock B6-A4 3.0L parts, so don't hesitate to let us know if you need anything!
