Results 1 to 18 of 18
    Veteran Member Four Rings AndyLien79's Avatar
    Jul 03 2011
    Fairfax, VA
    rear license plate holder/mount needed, where to buy?
    Hello all,
    I need a new rear license plate mount for my ride. The top left screw holder is missing so it's all jacked up now. When I tried to change out my plates tonight, it looked like that screw was bent so I ended up having to yank it out and it took the screw holder with it =(
    i know i suck at life
    sooo does anyone know where I can get another one or if there are any other options out there? Thanks in advance!
    Andy
    Picked up on 3/10/2015:
    2015 S4 P+ | Nogaro Blue | 6MT | Black/Silver Alcantara | Sports Diff | ADS | B&O | Tech Package | Carbon Atlas | High Gloss Package | Supercharged Badges | Rear Side Airbaggies | KW H.A.S. | SPC Control Arms | Vorsteiner V-FF 103 19x9.5 et40 Carbon Graphite | XPEL Ultimate | CQuartz Finest
    IG: alien79
    Established Member Four Rings MiracleWhips's Avatar
    Jun 02 2009
    San Francisco
    Photo of the destruction?
    Not sure many have dismantled the rear plate holder to know what you mean......
    Jul 03 2011
    Fairfax, VA
    here you go sir:
    notice the metal piece on the other side of the screw...that was in the plate holder
    so I either need a new plate holder or maybe one more of those metal pieces to replace?
    IG: alien79
    Senior Member Three Rings xbimmer06's Avatar
    Jan 23 2011
    '13 ML350, '14 Madone 7.9 Project One, 17 Top Fuel 9.8 sl
    El Paso, TX
    Hey man unfortunately looks like you might need to replace...here you go. Have taken mine off couple times already. Yours looks pretty screwed (pardon the pun) Part# 8T0827113A01C ($78.12)
    | STaSIS Tune & Pipes | Carbonio CAI | BFI Spacers | H&R OE Springs | EC Alu Kreuz | HFIC Pipe |
    | S4 Front Fascia | AWE Boost Gauge | RS4 Pedals | S4 Trunklid | S4 Mirrors |
    | S4 Black Optic Grille | S-line Side Blades | S-line FBSW | S-line Shift Knob | Aluoptic Spoiler Cap |
    | Audi Exclusive Door Runners | Votex Rear Diffuser | E-code Headlights | Heated Blind-Spot Mirrors |
    Jul 03 2011
    Fairfax, VA
    thanks xbimmer06,
    after about an hour, I was able to get the screw out. so since the top left has a hole in it now, I will probably just use the top right and bottom left holes to with the screws. So it will be held down with screws diagonally haha. ghetto i know, i wonder if there is anyway to cover up the two other holes while looking nice at the same time?
    IG: alien79
    Established Member Two Rings cdauks07's Avatar
    May 26 2008
    Bloomington, IN
    I lost one of my screw holders as well. My plate holder is luckily still good
    Senior Member Two Rings fredjones's Avatar
    Apr 24 2009
    Mobile, Al
    Man this would qualify for FMyLife for sure.
    2009 Audi A4 Prestige, Brilliant Black
    Mods: APR Stage 2, APR Downpipe, H & R Rear Sway Bar, License Plate LED.
    May 26 2008
    Bloomington, IN
    Hopefully you don't still need that plate. It's looks like a few stubborn plates I had to take off cars at the dealership I used to work for
    Jul 03 2011
    Fairfax, VA
    yeah going to put new plates on and I also had to order new license plate frames since one of them cracked from me yanking it out
    pics soon!
    IG: alien79
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Looks like somebody had an incredible hulk moment...
    2012 Q7 3.0T: graphite, prestige, S Line Plus, adaptive air suspension
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    The 'nuts' on the rear plate mount are known as speed nuts - it's kind of a clip nut, slips into an opening and slides into position.
    I pulled one out of my rear plate mount some time ago, and was able to replace it w/o purchasing a new plate mount.
    Here's a Speed Nut P/N used to install Under Seat Storage Bins - N 900 880 03 - don't know thread size (8-32?), think it will fit.
    Speed Nut P/N from DavidB8's DIY Under Seat Storage Bin Install some time ago
    New plate or press/flatten existing plate.
    Avoid The Hulk
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Jul 03 2011
    Fairfax, VA
    LOL!
    IG: alien79
    Jul 03 2011
    Fairfax, VA
    Quote Originally Posted by Greg Nelson View Post
    Avoid The Hulk
    Thanks Greg, will definitely look into this!
    IG: alien79
    Jul 03 2011
    Fairfax, VA
    all normal now, thanks guys!
    IG: alien79
    Apr 07 2007
    Mountain View, CA
    Much improved, Andy
    How did you 'straighten out' your plate - looks as if never happened.
    Cheers
    Established Member Two Rings Countryboy's Avatar
    Jun 05 2011
    2010 Toyota Tundra SR5 CrewMax 5.7L V8
    Edenton, NC
    Much improved, Andy
    Cheers
    Looks like new personalized plates. I think he said he hosed up the plate holder nut while changing the plates out.
    Apr 07 2007
    Mountain View, CA
    Quote Originally Posted by Countryboy View Post
    One way to fix hosed plates - pay the govt man for personalized plates
    Next for Andy is how to cut down the sides of his OEM plate holder so it doesn't protrude beyond the plate edge
    Jul 03 2011
    Fairfax, VA
    Countryboy is right, my old plate is still jacked up lol
    Greg - nice job on the cutting down the plate holder, looks good!
    IG: alien79
