hey all, my buddy and I are going to be doing a ton of maint on the 04 S4 come 11/15-11/16. Anyone who wants to come by, lend a hand, chill, lend some experiance and expertise would be awesome ;) feel free to PM me for a number and/or address if you want to cruise on by. I live in auburn. here is a list of what im doing and what Im going to pick up (ordering from JHM).
Service Im doing:
brake fluid flush
coolant drain, flush, and fill
change both cabin air filters
change engine air filter
change spark plugs
repair CV boots on front pass side (has started to seperate)
replace coolant overflow (yellowed and appears to have heat/ stress cracks and possible small leak)
fuel filter
8 x Spark plug, NGK 4-electrode (OEM) for B6/B7 S4
2 x Coolant - Antifreeze (Lifetime) OEM replacement - 1.5 Liter
1 x Cabin/Pollen Filter (Charcoal) for C5 all & B6/B7 all
1 x Air Filter for B6/B7 S4 and RS4 w 4.2L (K&N)
2 x Brake Fluid - DOT 4 Super Blue Racing (ATE) - 1 Liter
1 x Front Inner CV Boot Kit (New) for B6/B7 S4 and RS4
1 x Coolant Expansion Tank For B6/B7 S4 & RS4
1 x Cabin/Pollen Filter (Particulate) for C5 all & B6/B7 all
1 x Fuel Filter (OEM Audi) for B6/B7 S4 w 4 lines
1 x Front Outer CV Boot Kit (New) for B6/B7 S4 and RS4
THanks all!
PM me if you need to know how to fix your hinges on your B6/B7 A4, S4, or RS4 glove box
2004 S4 (Tip) - Dolphin Grey metalic
looking to buy 2 used Yokohama Avid Envigors - 245/40/18 see my add:Here
I swapped my fuel filter (B6 4 pronged one) and it wasn't too bad. I would suggest getting a squirt bottle filled with water of something to lube up the clips as mine were so gunked up they were super hard to get off initially. Other than that hope you dont mind smelling like fuel for the next few days.
Do yourself a favor and get an OEM Audi filter too, the shitty Hengst filter I got is making my pump squeal even worse than the old one was, so I'm going to replace it with and Audi one soon.
-CP
2004 A4 1.8TQ 6MT USP APR Stage 1 - Achtuning Snub - FSI Coils - BKR7EIX-11 (.04" gap) - 710N
Maintenance: 034 Silicon Breather - US Plastics Check Valves - Rev. D SJP - Rev. F PRV - Injector Seats - Coolant Flange
Issues: All control arms are shot - Shitty, poorly worn YK520s - Sloppy TREs - Godawful stock brakes
2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
Sorry i didnt catch you back. We ended up doing it tues. Axel went smooth...was an amazingly simple job! the snub mount...ugh! took forever...found screws and bolts missing from the previous owner and had some hang ups on small parts breaking on us :( we got it all fixed though and in! the 034 zero gap bracket made things more tricky..thats for sure!!!! took us 7 hours to do the axel, snub mount and belt. Drives WAY better. Can feel a little bit of a vibration at idle..but not much, and the mount still needs to be broken in, so I expect it.
