Results 1 to 16 of 16
    Jul 22 2010
    sweden
    4-Spoke Steering Wheel to 3 Spoke Multifunction Steering Wheel?
    Hi
    i have 4-spoke steering wheel without multifunction and want to change to 3-spoke Multifunction Steering Wheel
    is it easy to change Plug&Play?
    i have to buy a new airbag cable?
    any DIY
    thanks
    Audi A4 B8 2009
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    2007 MBZ CLK 350 Cabriolet
    Miami, FL
    Quote Originally Posted by huskul View Post
    Hi
    any DIY
    thanks
    Audi A4 B8 2009
    All this can be found by searching. But since your new....
    You will need a new airbag - three spoke and four spoke airbags are different. It should be plug and play as long as the new airbag is from a B8.
    audienthusiasts.com has a great steering wheel swap DIY.
    Welcome!
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion |
    Bi-Xenon Retrofit | LED Taillight Retrofit | S-Line Front & Rear Bumpers | S4 Alu Splitter | 19" Hartmann HTTRS MA:M | Vogtland Coilovers | APR/Carbonio Intake | Paddle Shifters | Gloss Black MMI surround | Yellow Fogs | LED Plate Lights | 20% Tint | VAG-Com
    Jul 22 2010
    sweden
    Welcome!
    thanks
    it is complete with airbag
    but I do not know which model it came from
    BR
    HusKul
    Veteran Member Four Rings Stubek's Avatar
    Feb 13 2004
    2011 A4 Avant
    Santa Clara, CA
    hit up alex@europrice on here, he can walk you through it all.
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, APR Stage 1
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Jan 20 2010
    Texas
    thanks
    BR
    HusKul
    If you can provide some part numbers, we could help narrow it down.
    Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, 10/17.5mm Spacers, ADS, Mirror with Compass
    Next Up: 4-Spoke Paddled Steering Wheel, Auto-On Headlights
    Jul 22 2010
    sweden
    hi
    I changed the steering wheel today and my slip ring has only 6-pin not 12-pin
    multi-function does not work
    my car are 2009 A4 B8
    cruise and trip control from stock
    is not it a little strange?
    Oct 27 2009
    Miami, FL
    hi
    I'm not quite sure what you are referring to when you say "slip ring"
    If the wheel/airbag is from a different year/model, you may need a harness to correct the pin/plug differences.
    Jul 22 2010
    sweden
    slip ring?
    I think i find what was wrong
    i have correct harness
    part: 8K0971589A
    "slip ring" part: 8K0953568E
    only 6-pin
    8K0953568G
    I hope that I may not replace more parts
    Jul 22 2010
    sweden
    Does anyone know the difference between them here
    Senior Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    I've got both types here and although I haven't tried to swap them you should be able to exchange the two. They do carry their own part numbers. Looks like you already have most of that figured out though.
    Once you got them swapped you will have to redo your steering angle sensor calibration. Make sure the ring is centred before you start. You will get all types of errors including ESP.
    Mods:Votex spoiler, tint, Clear Bra, S4 replicas, Audi winter and trunk mat,mud flaps, Dipstick, oil pan heater, KW V2's, AWE Dual Exhaust, Votex valance, AWE FMIC, Eurocode IC pipe, PIAA fog lights,Vag Com, APR Stage 2, E-Codes, trunk mount emergency triangle, LED plate bulbs, Audi compressor and tire repair kit, RS4 Pedal set, Power Folding Mirrors, S4 steering wheel, heated rear seats, ski pass through.......
    www.audienthusiasts.com
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Quote Originally Posted by DavidB8 View Post
    I have a 3-spoke wheel (black leather, used, from UK). 3-spoke Airbag (Kamut Beige) ordered from EuroPrice, when arrives wheel will be re-wrapped to match, all perforated.
    Question: when folks refer to "multifunction" here, does that mean the stalks on the steering column and/or the Tip shift paddles.
    I have '09 P+ with stalks, not adding shifter paddles.
    Thanks
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. Modified Votex Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Nov 06 2009
    Multifunction refers to the buttons on the steering wheel. There are models in the rest of the world that don't come with them.
    Apr 07 2007
    Mountain View, CA
    Thanks David, I thought I'd read that some while ago, wasn't sure.
    Shame some ROW's don't have - Usually ROW has the goodies we want
    Cheers
    Nov 06 2009
    I guess the difference is ROW can get the goodies but don't always have them ;)
    Active Member Two Rings xbimmer06's Avatar
    Jan 23 2011
    MB ML350
    El Paso, TX
    Wheel is SOLD everyone, thanks for everything.
    | STaSIS Exhaust | Carbonio CAI | BFI Spacers | H&R OE Springs | HFIC Pipe |
    | HOEN Fogs w A4L Housings | AWE Boost Gauge | RS4 Pedals | S4 Side Mirrors |
    | S4 Trunklid | S-line Side Blades | S-line Steering Wheel | S-line Shift Knob |
    | Aluoptic Eurogear Spoiler Cap | Exclusive Door Runners | Votex Rear Diffuser |
    Active Member Two Rings dame drizzo's Avatar
    Sep 15 2009
    2011 Infiniti G37x
    Staten Island, NY
    When I did the swap the car didn't recognize the steering wheel ie paddle shifters didn't work, horn, etc. Had to take pins out of old airbag and retro fit with with new airbag. It's a dangerous process and I don't suggest doing it yourself. I have s5 w/ dsg paddles on mine. Steering wheel is very inexpensive off eBay.
    2009 Audi A4 b8 2.0. TOTAL LOSS
    2010 Audi A4 B8 2.0 Ibis White - Custom FMIC, Borg Warner EFR, RAI MOTORSPORT Custom Tubular Turbo Manifold(wrapped), Custom RAI MOTORSPORT 3" FULL turbo back exhaust, RAI MOTORSPORT Downpipe, RAI MOTORSPORT Midpipe, UNITRONIC STAGE 3 ECU, HOTCHKIS Sway Bars ( f&r), Audi S5 Steering w/DSG Paddle Shifters, Lusch CF fog light grilles, H&R Coilovers, Stage 3 Water/Meth SNOW, 19" Stasis w/ Yokohama Advan 255/40/19 -
    FIRST (only) AUDI B8 WITH EFR
