I also want a fairly quickly spooling set-up that is fun to drive around town. So this means no crazy high boost or completely built motors where I'm shooting for high numbers. I also want to have a motor that is fairly easy to replace which is why I'm going the 12v route. I'm also planning on funding this swap mostly from the sale of my built 1.8t stuff.My plan is to take the car all apart and do the swap this winter.
Here the plans for the parts:
Engine:
-12v VR6
-C2 Motorsports 8.5:1 headgasket spacer
-ARP Head studs
-ARP Rod bolts
-New Timing Chains
Clutch/Flywheel:
-Southbend Stage 4 7A clutch
- 034 Longitudinal VR6 swap flywheel
Forced Induction:
- HTA3582r .82a/r
- ATP 12v VR6 Exhaust manifold
- 034 Longitudinal 12v VR6 Intake manifold
- Precision 600hp intercooler
- Synapse 50mm wastegate
- Synapse BOV
- VR6 Throttle body
Fueling:
- 1260cc injectors (E85)
- Walbro>Bosch 044 inline
- Aeromotive FPR
- -6an lines from pump to rail
- 034 12v VR6 Billet fuel rail
Electronics:
- 034 IIC Standalone
- 034 Wideband
- AEM Uego Wideband
- Phormula KS-4 Knock analyser
VR6 Swap parts:
- 01E/01A to VR6 adapter plate
- 034 VR6 swap starter
- Phaeton VR6 oil pan
- 12v VR6 valve cover out of MKIV Jetta
- Custom motor mounts
I think thats pretty much it as far as the parts go. I'll update it as I go along because I'm sure there are things I'm forgetting.
..... 15k on Street Built Engine
