2001 Silver S4 currently has 138K on it.
Currently running GIAC 93 tune, AWE S-FLO intake, Draintake mod, AWE twin 2 exhaust, Vogtland CO's, Sterns ADJ control arms, AWE DTS and all maintaince 150% uptdate.
Time line is to have this up and tuned by June/July 2012.
All final assembly and installtion will be completed by Athans Motors.
Vendors used for parts:
Audis4parts:
For lots of the little parts on the engine build. Bryan's the man.
034motorsports:
Head gaskets, intake gaskets, head bolts, aux water pump delete, bi-pipes red crinckle, billet fuel rail drop in kit here shortly.
The Build:
Engine:
2.7 block bored out to 2.8
2.8L crank
JE pistons
Crower Rods
All new bearing
2.8 Heads fully re-built
Full Super tech valve train, Iconel exhaust valves
new lifters, guides etc.
3 degree valve job
2.8 Cams
Compression dropping HG's should put me at 9.1-1 compression
Heads were completed by VE Motorsports
Bottom end was completed by SDP Motorsports
Turbo setup:
GT2868(GT28RS Hybrids with HTA 68mm
compressor wheels/billet aluminum) turbos
with stainless steel v-banded Tial 0.64 turbine
housings
ARD Schedule 10 stainless Tubular exhaust
manifolds with merge collectors and v-banded
tial discharges to turbine inlets
3" downpipes with test-pipe tail sections/all
v-bandeds(2 ea)
Turbosmart Comp 40 wastegates, 17psi(2)
Wastegate dump tubes(2)
Wastegate hardware(fittings, plugs, clamps)
9' of 3/16" silicone wastegate hosing
3/16" brass tees(2)
2' of 1/2" firesleeving
turbocharger inlet piping(aluminum/4-pieces)
2" silicone couplers(3" long each) qty. 2
40-60 clamps(4)
50-70 clamps(4)
1/8" NPT-3/16" barbed fittings(2)
2.5"'x2.25" silicone reducing couplers(2)
2" silicone coupler/4" long(1)
coolant feed lines to turbos(2)
oil feed lines to turbos(2)
12mmx-4AN oil feed fittings(2)
T25 turbo oil feed restrictors/-4AN inlet(2)
T25 oil return line gaskets(2)
M8x1.25x16mm oil line flange bolts(4)
12mm oil line crush washers(4)
14mm coolant line crush washers(8)
v-band clamps from turbos to manifolds(2)
v-band clamps from turbos to downpipes(2)
v-band clamps from downpipes to tails(2)
o2 sensor bung plug(1)
exhaust manifold gaskets to heads(2)
exhaust manifold nuts to heads(18)
1/4"x11' zip ties(qty. 10)
powdercoating on turbo compressors; ceramic
coating on: headers, downpipes, discharge
tubes, turbine housings, compressor inlet
piping
SMIC's:
Wagner
Clutch:
Leaning towards Tilton twin disc
Mounts:
Sterns tranns
Sterns Engine
Apikol dif mount
Fuel pump setup:
Will most likely be a new custom setup.
Fueling/tuning:
EPL or something else??
Meth:
Aquamist.
Most if not all engine censors will be replaced as well.
I will update as we make progress.
Here are just a few pics to get things started.
If so...good luck on the build man!
