034 Motorsport RS4 INLET PACKAGE
For over a year now we have been trying to get an affordable Y-pipe solution to replace the overly expensive and unobtainable cast RS4 Y-pipe. 034 Motorsport has once again stepped up to the Carbon Fibre plate and produced an amazing quality piece. As a tribute to Audizine veterans we are going to run a special on the entire package. You will need to run RS4 silicone hose pair and the RS4 replica inlet pipes.
PRODUCT INFO: RS4 Carbon Fibre Y-PIPE - $795 USD
Replace your OEM Audi Y-Pipe with 034Motorsport's Carbon Fiber B5 RS4 Y-Pipe Replica for the 2.7T! Eliminate a potential bottleneck in the 2.7T motor while spicing up your engine bay with gorgeous carbon-fiber.
Engineered utilizing CAD software to ensure perfect fitment and optimal flow. Manufactured from high-quality carbon fiber and automotive-grade resin to provide a long-lasting finish and excellent durability.
034Motorsport's Carbon Fiber Y-Pipe is designed for direct bolt-on installation. Fits all 2.7T equipped B5 S4, C5 A6, and C5 Allroad models.
NB: 034Motorsport Carbon Fiber Y-Pipes are currently built-to-order, and may have a lead time of 3-4 weeks. Installation requires the use of RS4 inlet hoses.
PRODUCT INFO: RS4 Y-hose Pair - Silicone - $135 USD
Y - Pipe hose pair for RS4 Y-pipe and RS4 Inlet pipes, a direct replica of OEM RS4 hoses but in reinforced high temperature silicone for long life and abuse resistance.
Replaces OEM part numbers 078133241G and 078133241H.
[img]http://www.034motorsport.com/oscthumbwm/w/600/h/600/q/95/f/jpg/fltr/wmi|phpThumb/watermarks/034watermark|C|20|0/hash/bbbb2edef660739a6071ab5a4f8a869f/src/images/RS4%20Y-pipe%20hose%20set.jpg[/img
PRODUCT INFO: Inlet Pipe Set, RS4 Replica - NOW TEST FIT BEFORE SHIPPING
Note, we are now test fitting all our pipe sets on a 2.7t motor with RS4 turbos before we ship each pipe set to ensure a perfect fit.
Finally, a readily available, affordable RS4 intake pipe solution for putting RS4 K04 turbos on the 2.7t.
We took matters into our own hands and have manufactured replica intake pipes that are improved over OEM units. The restrictive, redundant flow straightener has been removed, and also the tapered turbo sealing flange has been improved to seal with a smoother surface free of slag like the OE pipes are known for.
Manufactured from mild steel with a heavy duty painted enamel finish, these pipes are an exact fit for OEM, every detail even down to the vacuum routing and mounting bracket we've duplicated precisely.
REGULAR PRICING :
RS4 Carbon Fibre Y-pipe = $795 USD + shipping
RS4 Y-hose Pair = $135 USD + shipping
RS4 Inlet pipe set = $360 USD + shipping
AUDIZINE PRICING :
RS4 Carbon Fibre Y-pipe = $780 USD SHIPPED!
RS4 Carbon Fibre Y-pipe + RS4 Y-pipe Pair = $909 USD SHIPPED!
RS4 Carbon Fibre Y-pipe + RS4 Y-pipe Pair + RS4 Inlet kit = $1229 USD SHIPPED!
This pricing is only available for 10 people so jump on the list:
- E
- 2
If you are ready to order call 510.275.4775 or Email US!
