Page 2 of 12 FirstFirst 1234 ... LastLast
Results 41 to 80 of 443
  1. #41
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    X2 on what Mike said. Hearing an audible bubbling is normal. Problem is without hearing it on yours I couldn't hazard a guess as too if it's normal or not. Like Mike said, a leakdown test will be a better indicator of what's really going on.
  2. #42
    Senior Member Four Rings jaychen's Avatar
    Feb 19 2011
    Brisvegas, AUS
    On a leak down test does each cylinder have to be at TDC for it to work correctly?
  3. #43
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Phoenix, Arizona area
    Yes it does becaues the valves need to be closed and the piston need to be at the top.
  4. #44
    Jan 24 2010
    melbourne australia
    Are you comparing these cylinder pressures with hot or cold engine?
    96 A4 1.8TQ
    FRANKEN TURBO K03-073, 1 BAR CHIP, SUPERTECH VALVES, PORT N POLISH, JE PISTONS, SCAT RODS, 034 MANIFOLD & FMIC, FIDANZA FW & SOUTHBEND STG 3, BILSTEIN & H&R, 3IN EXHAUST, CUSTOM AIR BOX, APR DV, DBA SLOTTED, RED STUFF.
  5. #45
    Feb 08 2011
    Quote Originally Posted by bmarshall View Post
    He has already answered that, check post #7.
    Yes motor was done hot and it was cranked atleast 10 times to ensure max pressure was read.
  6. #46
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    I can't wait to see end results of this thread....keep us posted
    1998 Audi A4 built 1.8t Quattro--Eurodyne Maestro---870cc tune---Custom Elim Gt3076---on E85 Gas---044 Bosch Drop in fuel pump---Street tuned by me---402awhp 387tq---12.1@118mph on 19" wheels
    2003 Audi Avant 1.8t Quattro 5speed--Eurodyne Maestro--k04 tuned on 630cc injectors--19" Staggered iForged Daytona Wheels
  7. #47
    Feb 19 2011
    Brisvegas, AUS
    Next line of action is :
    replace Camshaft position sensor
    try to crank, if it runs then
    check for codes
    if it doesn't start or run
    leak down test
    pull motor.
  8. #48
    Senior Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    If your cam sensor code returns after replacing it, then there's a good chance your timing is off.
  9. #49
    Jul 27 2010
    Queensland, Australia
    Quote Originally Posted by jaychen View Post
    Replace camshaft position sensor
    Clear codes, do leak down test
    if it doesn't run
    check cam timing, do leak down test and if necessary, strip down motor.
    Fixed :D
    99.5 A4 1.8TQ MT (AJL)
    PSI concepts 520 turbo kit w/Trust 20G 3' Comp housing | Custom TIP | Maestro 7 + Audi V8 MAF + Siemens Deka 630cc injectors + 034 motorsports billet 044 pump(to be installed) | Gizzmo IBC-R EBC @ 18psi | |ICM Delete| JHM SSK | Complete Stern mount kit | Custom BBK by Wilwood, 332mm rotors + 6 pot dynalite calipers | Koni coilovers |
    More goodies and engine rebuild soon . . .
  10. #50
    Feb 19 2011
    Brisvegas, AUS
    Haha thanks danny
  11. #51
    Feb 19 2011
    Brisvegas, AUS
    SO i replaced my camshaft position sensor, it did nothing.
    I haven't had access to a VAG-COM yet so will wait to see if the code is gone.
    Here are some pictures of my timing belt though, what are your thoughts. One set of marks is way off, another is on..
    While I was bored the other day with nothing much to do, I refurbished my grill :)
  12. #52
    Senior Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    Not sure what your trying to show with the marks being off between the cam gear and the VC notch. But the those marks should line up or within 1/2 tooth WHEN the crank pulley mark and lower timing belt cover mark are also lines up. You'll have to use a flash light to look down the front of the engine to see the notch in the crank pulley and the raised line on the front of the timing belt cover. You can also look into the window on the top of the bell of the transmission. There should be a visible mark on the flywheel there lines up with an arrow or notch on the housing. I could not find a photo of either of these nor could I locate the AZ DIY for B5 A4s.
    If the crank and the cams are not correctly in time within 1-2 teeth, its guaranteed you have bent valves. That does explain why you would get low compression but does not explain why you would get decent wet compression. I would bet that you'll be pulling the head off this car before its running correctly again.
  13. #53
    Feb 19 2011
    Brisvegas, AUS
    I'm trying to show that there are two separate lines on my belt and cam gear and that one set of the lines, they are lined up. On the other set, they are slightly off.
    Ill start pulling the front off my car tonight and get more photos. Hopefully I can be back on the road before Christmas
  14. #54
    Mar 15 2008
    Syracuse, NY
    I'm pretty sure those lines are only for installation. If you keep turning the motor over, eventually they will line up. But they will not line up every time the engine turns over.
  15. #55
    Jun 30 2008
    Erie, Pennsylvania
    I don't see in any of your photos where anything is lining up with the notch on the valve cover. Which photo was taken with the crank set to TDC (notch in engine plastic front cover)?
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
    Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *On Loan to 01audia4*
  16. #56
    Feb 19 2011
    Brisvegas, AUS
    I was referring to the variances between the mark on the actual timing belt and the cam gear. Not between anything else. Over the next few days ill post photos of the timing between the crank, cam gear and vc.
  17. #57
    Jun 30 2008
    Erie, Pennsylvania
    Yeah, the mark on the belt means nothing, just an aid the tech used when installing it. Once it goes around once, it's meaningless. Crank mark is plenty visible by just popping the hood. No need to tear into anything.
  18. #58
    Feb 19 2011
    Brisvegas, AUS
    Wouldn't it be easier to see if the belt had jumped on the cam gear though, I just 'assumed' the belt would be more likely to jump on the cam gear than crank.I can understand what you're saying.. It just made sense in my head.
  19. #59
    Jan 24 2010
    melbourne australia
    Are the photos of the cam gear at TDC? If so you have the gear around the wrong way! There is a recent post on this, although you have to break the key off the wheel to get it on the wrong way.
    96 A4 1.8TQ
  20. #60
    Mar 15 2008
    Syracuse, NY
    Its more likely the belt would jump the crank pulley. There is far less teeth to belt down there then up top.
  21. #61
    Mar 27 2010
    My build thread near the bottom of the page is where it was posted http://www.audizine.com/forum/showth...d-(pics)/page4 Although if he has the side with no writing facing forward, he should be OK.
  22. #62
    Feb 19 2011
    Brisvegas, AUS
    Ok,
    So it looks like my timing is off.
    These photos are taken when the crank is TDC and cyl 1 is right at the top of the revolution.
    The actual mark on the cam gear from factory was almost half the way around eg 180 degrees away from the mark on the vc.
  23. #63
    Active Member Two Rings rockersteady's Avatar
    Apr 10 2011
    Sydney Australia
    You are most likely still 360 degrees away from TDC firing stroke. Turn the crank one more turn clockwise looking from front and you can see IF the pulley has slipped.
    TDC1 on crank and TCD1 firing on cam (both in and EX closed) sets of marks will line up
    99.5 QTM, Eurospec 2lt, Apikol SMIC, Miltek 2.75, 034 HFC, CM 240mm fx400 x 6, koni CO's, Stoptech BB, SP56R, stealth V8maf in stock airbox, Maestro 7 tuned from 630cc base. 044 intank , WB/EGT cockpit monitored
  24. #64
    Mar 27 2010
    Sounds like it's right on, like rockersteady said, you've got either 1) compression or 2) exhaust stroke. Just don't get them mixed up if you're rebuilding your engine lol.
  25. #65
    Feb 19 2011
    Brisvegas, AUS
    Lol yep, rocker was right on. So timing isn't the issue.
    I was hoping that would explain its inability to start, hopefully the internals hold the answer.
  26. #66
    Active Member Two Rings cory.smith's Avatar
    Dec 20 2010
    Ft. Worth TX
    Just by looking at the timing thing, I've got a feeling that this build thread is gonna be fun.
    -Cory
  27. #67
    Feb 19 2011
    Brisvegas, AUS
    Have faith Cory.
    Fault code:
    00515 - Camshaft Position (Hall) Sensor (G40): Open or Short to Plus
    Possible Causes
    Wiring to Camshaft Position (Hall) Sensor (G40) faulty
    Camshaft Position (Hall) Sensor (G40) Installation faulty
    Camshaft Timing Out of Specification
    Possible Solutions
    Check Wiring to Camshaft Position (Hall) Sensor (G40)
    Check/Replace Camshaft Position (Hall) Sensor (G40)
    Check Camshaft Timing
    Check/Replace Engine Control Module
    I have replaced the camshaft position sensor and checked timing obviously. I am yet to check wiring but I was told that if the cam chain has skipped a tooth it throws this code as well?
  28. #68
    Jan 24 2010
    melbourne australia
    Unplug the sensor and check with a multimeter the 5volt supply and signal ground wire. You can buzz all 3 wires to the ecu pins aswell.
    96 A4 1.8TQ
  29. #69
    Feb 19 2011
    Brisvegas, AUS
    So I just did that B, I got 12v, 5v and a ground at the plug.
    I then buzzed them through to the pins at the ecu harness. Everything was fine although my ground buzzed through to two different pins?
    I have attached photos.
    I haven't re-checked for codes since I put the new Camshaft Position Sensor in yet so I would like to see if the code is still there.
    Another weird thing is that I cannot audibly hear my fuel pump priming when the key hits the acc notch.. Any ways to test the pump or do I just get a new one and be done with it?
  30. #70
    Feb 19 2011
    Brisvegas, AUS
    So I swapped the old K04 chip out of my ECU and put the stock one back in and wallah.
    Throttle body made some noise, fuel pump primed, turn the key and it started first go.
    It was not healthy by any means but its definitely a good start.
  31. #71
    Veteran Member Three Rings gmx's Avatar
    Mar 01 2008
    '00 1.8TQMS
    Sydney, AU
    Good news
    Was VAGCOM communicating with the ECU easily or intermittent no response from controller?
    Is the chip a socket or straight replacement onto the board? I had similar issues when the tuner's replacement socket&chip was not making proper contact. (No priming, no TB adaption/noise etc).
    00 A4 1.8TQ MT (AJL)
    JHM SSK
    17*8 BBS RK | Vogtland GT 575F/675R | H-Sport Sways |
    GT2871R Elim | Maestro tuned AJL| 034 3" HFC | Milltek | 034 TIP
    3090lbs
  32. #72
    Feb 19 2011
    Brisvegas, AUS
    not sure about vagcom GMX but it was a socket+chip, no fault of the installer though.. it was already in there from a previous owner.
  33. #73
    Mar 27 2010
    Don't feel too bad about that, if it's any consolation, if I had a nickel for every time I had made a worse assumption than you did over the last 18 years I spent learning to work on cars I'd be shitting on Donald Trump.
  34. #74
    May 31 2005
    Dallas
    Ok,
    Did you ever recheck or turn the motor one more time because those pics are showing your like 4-5 teeth off
  35. #75
    Jan 24 2010
    melbourne australia
    Second that. Get that cam/valve cover off and check it properly.
    96 A4 1.8TQ
  36. #76
    Feb 19 2011
    Brisvegas, AUS
    That was at the top of exhaust stroke, one more turn of the crank bought the cam gear around spot on with the notch on the vc. I am going to pull the vc today though anyway. Im just happy it started, now i can actually start the rebuild.
  37. #77
    Feb 19 2011
    Brisvegas, AUS
    http://vimeo.com/30826863
    a short video explaining how bad my idle is, you can hear how it sounds like there is no oil in the head or the big end bearings are gone.
    look at my vac reading as well.. that is after pressure testing as well, no leaks anywhere.
  38. #78
    May 31 2005
    Dallas
    I couldn't see the video via my phone but i will check it when i get home, What codes are you getting now after replacing the cam sensor?
  39. #79
    Feb 19 2011
    Brisvegas, AUS
    I haven't done a scan yet, Saturday morning is the earliest the car can be scanned. I don't own a VAG-COM or a cable, a buddy of mine does and he has been helping me out with this all alot so he said he will pop by on the weekend.
  40. #80
    Mar 15 2008
    Syracuse, NY
    I watched the video. Its hard to believe it will even stay running with no vacuum. Do you have to keep your foot on the gas peddle? Pressure test the system. I would bet you have a leak somewhere, PCV, intake manifold, vacuum lines. If you still have the oem cloth cover vacuum lines, get some silicon hose. The oem lines will crack inside the cloth and you won't be able to see it.
    Read these:
    http://www.audizine.com/forum/showth...st-Leak-Tester
    http://www.audizine.com/forum/showth...ng-Boost-Leaks
    What you're looking for is not really a boost leak, but a plain leak somewhere after the throttle body. So if you wanted to, you could connect up pressurized air to the throttle body and pressurize just the manifold,head,motor. IIRC, put the engine at #1 TDC when testing. If the boost/vacuum gauge is correctly connected to the intake manifold (most ppl tee into the vacuum line going from the IM to the FPR), you can use this as the gauge while pressurizing the system to determine what pressure it is at (<20psi) and if you are leaking somewhere. Either have someone else watch it or move the gauge under the hood while testing. GL
