Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 443
  1. #321
    Senior Member Four Rings jaychen's Avatar
    Feb 19 2011
    Nth Dakota
    Thanks Mitch. Maybe he could ask if they could email him the file, then he could pass it on to me. That would definitely work
  2. #322
    Active Member Two Rings Gbomer's Avatar
    Mar 04 2010
    Sydney, Australia
    now.. i know there are more photo's.. so post em
    99 A4 1.8TQ
    |GIAC 1.1 bar| KW V3's | H&R Front and Rear Sways| Solid rear sway links| EBC GreenS| FMIC|
    | SPARE 1.8T in pieces ready for BAT |
  3. #323
    Feb 19 2011
    Nth Dakota
    Got seat time kunce.
  4. #324
    Senior Member Four Rings redline380's Avatar
    Oct 30 2008
    2000 Chevy 3500 454 w/9'2" boss vplow
    St. Cloud, Minnesota
    lookin awefully good! I certainly approve. but where did that black oil dipstick come from? you paint yourelf or where you buy it? my orange one is killing my green/black theme
    Look dad, it's the good stuff, none of that pussy skoal- Joe Dirt
  5. #325
    Mar 04 2010
    Sydney, Australia
    gawd that looks shmick.. how much time do you have on your hands to get all this work done
    99 A4 1.8TQ
  6. #326
    Feb 19 2011
    Nth Dakota
    haha still studying fulltime and working 25hrs a week.. just make time bro.
    I just painted that bad boy.. I figured it would look pretty out of place being orange..
    Thanks guys.
  7. #327
    Senior Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    1983 Toyota Cressida, now new and improved w 401,000 km (AKA the shitmobile)
    I'd suggest looking into a .64 A/R turbine housing. The .82 housings really don't add much in terms of power, but they do increase spool 500+ RPM.
  8. #328
    Feb 19 2011
    Nth Dakota
    Yeh , I know I should..
    I will try hang around the local jap import forums to see if i can find one cheap since SR20's are T25...
    It wont be going on a for a little while yet, stil need new oil lines, alter my dump pipe, engine needs to be run in, send my cable back to CTapp..
  9. #329
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Phoenix, Arizona area
    Quote Originally Posted by jaychen View Post
    Just make sure you get the right T25 exhaust housing, Garrett offers a different style T25 housing for the Nissan's.
  10. #330
    Feb 19 2011
    Nth Dakota
    I will.
    Mike,
    I have a slight problem..
    When I measured my clutch kit for you, obviously it was within the spec to be able to use a stock height throwout bearing, my engine builder had to chop about 1/4'' - 1/2'' off every flywheel bolt because they were too long.
    Now , I suspect my overall stack height is shorter than OEM, does this now mean that my input shaft is not going to reach all the way inside the flywheel?
    Where can I find a spacer to space my clutch kit back out to use OEM length flywheel bolts? Do I need to do this?
    edit: email me if need be..
  11. #331
    Feb 08 2011
    I will.
    Mike,
    The bolt length doesn't really have anything to do with the stack height, it has to do with how thick the flywheel is where the bolts go thru it. Stack height for the flywheel has to do with how thick it is from the back side of the flywheel where it mounts to the crank flange and the top of the flywheel were the PP is going to sit. So you really want to measure the whole thing with the flywheel, PP and TOB all stacked on top of each other.
    Was it OEM bolts that he cut or aftermarket and is it a OEM flywheel or aftermarket flywheel? Because you cant use OEM bolts on a aftermarket flywheel since most aftermarket single mass flywheels have a thinner center section where the bolts to thru the flywheel which means it uses shorter bolts. The ARP bolts I use on the 1.8t aftermarket flywheels is only .8" long under the head and the CM bolts that come with their A4 1.8t flywheels are 1" under the head.
  12. #332
    Senior Member Two Rings s3apra4's Avatar
    May 07 2011
    A bunch of wheels and random audi parts... Oh Yeah and a stroked B5.
    Houston,TX
    There is something about Clean engines with polished parts.
    Looks SICK!
    I could eat off it!
    ~Joshua
    JE Pistons / Pauter rods / 2.0l / GT3582R / 034 tubular manifold / 034 EFI IIc / Apikol IM / Ev14 1000cc / Cat 3658's / supertech valve's 1mm oversized exhaust / street density motor mounts / track density tranny mounts / H&R Coilovers / 034 Exhaust /Stop Tech 332 BBK / RS4 Pump in tank to 044 in 034 surge tank /034 300mm Rear Brake Kit
  13. #333
    Feb 19 2011
    Nth Dakota
    Quote Originally Posted by s3apra4 View Post
    Looks SICK!
    I could eat off it!
    Haha i hear you buddy ..
    Love clean shit in the engine bay. Glad your car is nearly done!
  14. #334
    May 07 2011
    Houston,TX
    Thanks! As am I after 2 years.
    Now if we could just get parts shipped to Australia faster you would be running too.
    ~Joshua
  15. #335
    Feb 19 2011
    Nth Dakota
    Ha yep..
    Throwing the motor in on Saturday, run in Saturday night through the mountains.. Come home at 2am, drop oil and let it drain.. then continue to run it in over the next week and then one final oil change before I throw the turbo on and switch to Maestro
  16. #336
    May 07 2011
    Houston,TX
    Thats what im talking about! Get that shit done. Oh, and there must be many pictures.
    ~Joshua
  17. #337
    Feb 19 2011
    Nth Dakota
    Haha I will try. I am usually so concerned on getting the work finished that I don't take any pics during the install.
    I will take HEAPS during this time around.
  18. #338
    Dec 05 2007
    Too lazy to Google it, so how do your polish your mani to look like that? Is it as simple as metal polish and a buffer tool bit for a power drill. I picked that up to clean up my exhaust, and wondering does the same process apply to polish the mani. Thanks!
    I hate it when my car acts like a little bitch, treating me like the bitch
  19. #339
    Feb 19 2011
    Nth Dakota
    I wish it was that simple.
    What I did was pick up:
    2 x 60grit sanding wheel for a die grinder
    2 x 120grit sanding wheel for a die grinder
    240 non grit sanding paper
    320 non grit sanding paper
    P400 wet and dry
    P600 wet and dry
    P1200 wet and dry
    P2000 wet and dry
    Start sanding with the die grinder, moving up in grits.. then when you finish the 2000, then you polish it ..
    These are the only photos I took during polishing my comp cover..
  20. #340
    Dec 05 2007
    Def looks nice. I just copy & pasted your post, sent it to myself as a PM, and threw it into my folder of crap (lots of usefull stuff I like to save there). I'm def going to do this later on. Looks super clean .
  21. #341
    Feb 19 2011
    Nth Dakota
    Haha ok nice..
    Perhaps you could send me a PM or email me some of the useful things you have saved.. I really should do that myself but never get around to it.. then I am frantically searching for the info when I need it, and 9/10 I never find it.
    Did you make any headway on that GT2871R file from that guy?
  22. #342
    Dec 05 2007
    Dan said he has a file he can send you. Didn't you read your thread? lol. I didn't even bother to follow through after I seen that post.
    Quote Originally Posted by Sales@RAI View Post
    I can send you the 830 file I have. There is no difference between them, just how the Injectors are set up, which you just have to go into the injector wizard and click on the "630cc" button
    Also, you still need me to pick up those parts for you?
  23. #343
    Feb 19 2011
    Nth Dakota
    Yeh I read that, so it turns out they are just injector specific files in the end?
    If thats the case, I have all those anyway..
    I do need those parts.. just waiting on a few things.. Will contact you in the next few days if that's ok.
  24. #344
    Feb 19 2011
    Nth Dakota
    Beautiful weather to drop the motor back in! Scored a free Ramset 18v Impact driver as well!
  25. #345
    Mar 04 2010
    Sydney, Australia
    Loves the street garage !!!
    99 A4 1.8TQ
  26. #346
    Feb 19 2011
    Nth Dakota
    Neighbours love it too lol 18v impact driver at 7am
  27. #347
    Senior Member Two Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Looking good!
    99.5 1.8Q > Built
    My Build http://www.audizine.com/forum/showth...-8-build-Enjoy
    FOR SALE:
    Tial 38mm wastegate (Great condition)
    ATP (t3) Mani (Great Condition - No cracks)
  28. #348
    Senior Member Four Rings flynnr's Avatar
    Sep 22 2008
    1969 chevelle SS 454 convertible
    Minnesnowta (Roch)
    so why is that tiny turbo on the car in the pics you just posted??
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
  29. #349
    Feb 19 2011
    Nth Dakota
    Because Maestro is NOT PnP for Australian users.. So I am going to run the car in on stock tune + stock turbo + stock FPR and injectors, then swap it all out to the GT28 and maestro stuff once the motor is healthy and 'safe'.
  30. #350
    Dec 05 2007
    ^Smart move!
  31. #351
    Jul 27 2010
    Queensland, Australia
    Someone's happy today.
    99.5 A4 1.8TQ MT (AJL)
    PSI concepts 520 turbo kit w/Trust 20G 3' Comp housing | Custom TIP | Maestro 7 + Audi V8 MAF + Siemens Deka 630cc injectors + 034 motorsports billet 044 pump(to be installed) | Gizzmo IBC-R EBC @ 18psi | |ICM Delete| JHM SSK | Complete Stern mount kit | Custom BBK by Wilwood, 332mm rotors + 6 pot dynalite calipers | Koni coilovers |
    More goodies and engine rebuild soon . . .
  32. #352
    Mar 04 2010
    Sydney, Australia
    Quote Originally Posted by spindoctor View Post
    So his taken it for a spin i gather ?
    99 A4 1.8TQ
  33. #353
    Jul 27 2010
    Quote Originally Posted by Gbomer View Post
    Popped in at his place to help out with this reinstallation and did a check over. Primed the engine and started very quickly. Jesse's a happy bloke.
    Jesse's gonna ask about the hydraulic lifters to you guys. Its noisy but i pointed him to this:-
    https://s3.amazonaws.com/fcp-pdf-files/audi-vw-valve.pdf
    We take this opportunity to confirm to you, that best practice for engines using hydraulic lifters, as recommended by Federal-Mogul and OE, is to ensure that new hydraulic lifters are fitted at the same time as any new valves are fitted. All parts should be installed in conditions of pristine cleanliness to ensure successful working. Each follower should be coated with an extreme pressure cam lubricant as used on the lobes. Finally, old engine oil must be drained and replaced with both new oil, and filter, as old dirty oil will contaminate the new lifters, leading to early malfunction.
    The hydraulic followers should be allowed to “settle” for a MINIMUM of 30 minutes, after the complete installation, this to allow the excessive oil in the hydraulic lifter to drain. If this step is not complied with, some valves will probably make contact with the piston crown. This leads to an immediate and violent fracture in the cotter groove, on start up or soon after, possibly during the test run. OE further recommend that the engine should be allowed to “settle” for a MINIMUM of 30 minutes when the repair is ready, then cranked over carefully for TWO complete cycles by hand, this to check for valve to piston contact. Ideally, we would recommend that the engine should be left overnight before restarting for the first time after the repair.
    What do you guys normally do with a freshly built head?
  34. #354
    Feb 19 2011
    Nth Dakota
    As Danny has asked.. there is something that is NOISY in the head.. It sounds like lifters or cam chain tensioner but it was really quite noticeable.. It kind of has me worried.
    Short knocking video..
  35. #355
    Active Member Two Rings Risky Bizkit's Avatar
    Dec 06 2011
    Brisbane - Australia
    HORRAH! why does it sound so throaty?! you not hooked up the exhaust yet?!
    Now you just needs to replace that tiny SMIC!
    P.S i liked the "and its that easy" hand gesture after it started first time lol.
    -George
    Audi A4 B7 1.8T Quattro S-Line - PSi Concepts TD05-18G - Milltek Cat Back Exhaust - ER Sport FMIC - BMC CDA - Cat Delete - Custom Code - Bosch 040 - Bosch EV14 550cc - EBC RedStuff Pads + Ultimax rotors.
  36. #356
    Oct 06 2004
    Minnesota
    Do you have an oil pressure gauge?
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    '01 Audi Allroad 2.7T - Wheels and nothing else!
    '12 Ford F-150- The workhorse
  37. #357
    Feb 19 2011
    Nth Dakota
    Quote Originally Posted by A4Rob View Post
    Nope.. Should I try and get one rigged up before driving the car?
  38. #358
    Veteran Member Three Rings Aliel's Avatar
    Feb 26 2005
    '99 Audi A4 1.8TQM
    Tirana, Albania
    How long did you leave it running after the first start? When I changed my camshaft chain tensioner after the first start there was a loud ticking noise from the head. After running for 30 mins or so it quieted down because the lifter got filled with oil. Hopefully it's just that.
  39. #359
    Feb 08 2011
    Did you prime the system to allow the brand new lifters to pump up before you started the motor?
    turn engine over by hand at least once, then let engine sit for 24 hours (ideally) before starting. Failure to comply can cause valve / piston contact in some applications.
  40. #360
    Feb 19 2011
    Nth Dakota
    Quote Originally Posted by M-Hood View Post
    Yes.
    Cranked by hand atleast 2 - 4 times then we took out fuse #28 and cranked again for atleast 5-10 seconds on each pass.
