    Active Member Two Rings rgiles675's Avatar
    Feb 12 2008
    Grand Rapids, Michigan
    Adjusting H&R Rear Coilovers
    Just wanted to say FML. My rear H&R coilovers need to be adjusted. Does anyone know any tricks to this? It's looking like I have to take the springs out to do this
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We use a cut down wrench. Requires more effort, but it at least clears everything and makes adjusting it doable on the car.
    www.purems.com
    San Diego, CA | mike@purems.com | Twitter! | Facebook
    San Diego's only Audi/VW Specialist Workshop
    Registered Member One Ring WideB5's Avatar
    Jan 30 2012
    Mishawaka, In
    Just went through this on my Avant - its not that bad - even if you have to pull them to free them up (I did). You may be lucky enough to free them up in the car with spanner wrenches and the suspension unloaded. Good Luck
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    ^^ +1
    Unload the suspension, hit them with some liquid wrench, and spin them down/up with a spanner wrench. If you have to remove them I would suggest coating the threads in anti-seize in case you need to make future adjustments.
    Good luck!
    Jason
    Senior Member Three Rings Davect06607's Avatar
    Apr 07 2007
    Bridgeport, Ct
    I placed the adjustment peice on the top of the spring, works beautifully.
    '05 S4 6mt- Jhm 93 tune, Jhm IM Spacers, H&R c/o's, 034 Density Motor & Trans mounts, Hotchkiss Sway Bars f&r, Apikol snub & R.Differential mounts, 034 snub bracket, Jhm LW rotors w/ Hawk HPS, K&N, Piggies, FI Catback w/ 8" resonators, S.S. brake lines, 034 Density strut mounts, 034 MAF Hose, 034 adj. endlinks, RNSE, JHM Solid ss.
